查看: 1398|回复: 0
[教程] 【一网打尽】Raspberry Pi Course Week 4 – Day 5 (File Manipulation)
  • 签到天数: 242 天
    发表于 2015-3-28 12:52:07 | 显示全部楼层 |阅读模式
    Create a file hello.txt by using the following command.
    $ touch hello.txt
    Confirm that the file has been created successfully by listing the files.
    $ ls
    To create a copy of this file, enter the following.
    $ cp hello.txt hellocopy.txt
    List the files to confirm that a copy of the file has been created.
    $ ls
    Remove the hellocopy.txt file by entering the following delete command.
    $ rm hellocopy.txt
    List the files again to confirm that the file has been removed.
    $ ls
    The terminal will blindly carry out your commands without asking you to confirm the file to delete.  If you want to be prompted when you delete a file enter the following.
    $ rm -i hello.txt
    Press N because there is an additional trick left.  Enter the following but this time you will press the tab file.
    $ rm -i he<PRESS TAB>
    This should complete the file in the command line to read.
    $rm -i hello.txt
    Press Y to delete the file.
    When create files it is always nice to keep things organised.  A directory will do just the job.  Enter the following.
    $ mkdir myfiles
    Create a file.
    $ touch suntimebox.txt
    List the files and folders to confirm that they have been created.
    $ ls -lF
    Move the suntimebox.txt file into the myfiles directory.
    $ mv suntimebox.txt myFiles
    List the files and folders again and take note that the suntimebox.txt file is missing.
    $ ls -lF
    It is missing from the current directory because it was moved into the myFiles directory.  Enter the following.
    $ cd myFiles
    $ ls -lF
    The file should appear in the directory that was created.  Enter the following.
    $ cd ..
    Enter the pwd command to confirm your locations.
    $ pwd
    Confirm that you are in the /home/pi directory and enter the following.
    $ rm myFiles
    The output displays that you cannot remove ‘myFiles’ because it is a directory.  This is because a flag is needed.  Enter the following command.
    $ rm myFiles -r
    This will attempt to remove any files inside the myFiles directory before removing it.
    GMT+8, 2024-11-19 13:43 , Processed in 0.106906 second(s), 15 queries , MemCache On.
