查看: 1698|回复: 0
[教程] 【一网打尽】Raspberry Pi Course Week 4 – Day 4 (File Navigation)
  • 签到天数: 242 天
    发表于 2015-3-28 12:50:50 | 显示全部楼层 |阅读模式
    To navigate the file system you will need to know a few commands.  To locate where you are in the file system enter the following.
    $ pwd
    /home/pi
    This will display you Present Working Directory:
    Enter the following.
    $ cd /
    Enter the pwd command.
    $ pwd
    The terminal will display a / meaning that you are at the root of the file system.
    Enter cd home
    This command will change the directory to the home folder.  Enter the pwd command to confirm this.
    /home
    Enter the following command.
    $ cd pi
    Confirm the directory by enter the pwd command.
    $ pwd
    /home/pi
    Move back a directory by enter the following.
    cd ..
    This will move back a directory.  Make sure you have a space after the cd command.  Confirm this by entering the pwd command.
    $ pwd
    You can also jump directly down the file system without going into each folder.
    $ cd /
    Followed by this.
    $ cd /home/pi
    This command will jump directly down to the pi folder.
    GMT+8, 2024-11-19 13:44 , Processed in 0.102763 second(s), 15 queries , MemCache On.
