查看: 2195|回复: 0
[教程] 【一网打尽】Raspberry Pi Course Week 1 – Day 2.0 (The Hardware)
  • 签到天数: 242 天
    发表于 2015-3-27 13:08:12 | 显示全部楼层 |阅读模式
    The Raspberry Pi is made up of very similar components that you will find in many PC’s, Laptops and even some modern phones.  Each of these devices support a some type of input, either a keyboard, touchscreen or both, a way of processing that input, a method of displaying the output and a way to store data.
    Take a look at the Raspberry Pi below.  It has 2 USB ports as possible input devices which could be a mouse or a keyboard.  A 700mhz ARM11 processor which can process and perform calculators on the information that is sent to it and an HDMI output and RCA Video output.  There is also an SD card slot which will enable a user to save their data and load the operating system.
    Raspberry Pi Hardware
    The main components are
    1. 700mhz ARM11 processor.
    2. USB 2.0 ports for mouse/keyboard/wi-fi and bluetooth adapters.
    3. The Ethernet port for plugging into a hardwired network.
    4. HDMI OUT for plugging into a TV or monitor. (Note the audio output also uses HDMI).
    5. Micro USB power input for powering the Raspberry Pi.
    6. SD Card slot which will contain the operating system and additional data.
    7. GPIO headers for connecting external devices such as robotic arms.
    8. RCA video out for older TV’s.
    9. Audio out to an external amplifier.
    The Raspberry Pi foundation have released a number of different version of the Raspberry Pi.  To find out more select a box below.
    The model B version was released with additional memory and a dual USB connector. Model A only featured 256mb of RAM and didn’t have an Ethernet connection. The technical specifications for model B are below.
    A Broadcom BCM2835 Processor
    700 Mhz ARM Processor
    512 MB RAM
    Dual core VideoCore IV multimedia Co-Processor for processing graphics
    1x Ethernet connection for connecting to a network
    2x USB Connectors for using a mouse, keyboard etc
    HDMI visual & audio output to a TV or monitor
    Composite RCA output an older style TV
    3.5mm jack for audio output
    SD card for data storage
    Download the PDF file for Day 2.1 – The Raspberry Pi Raspberry-Pi-Course-Week-1-–-Day-2.1-Model-B.pdf (106.54 KB, 下载次数: 0)
    GMT+8, 2024-11-19 13:41 , Processed in 0.111341 second(s), 16 queries , MemCache On.
