查看: 1634|回复: 0
[教程] 【一网打尽】Lesson 9 Screen04
  • 签到天数: 242 天
    发表于 2015-3-26 16:17:26 | 显示全部楼层 |阅读模式
    Raspberry Pi
    Lesson 9 Screen04
      The Screen04 lesson builds on Screen03, by teaching how to manipulate text. It is assumed you have the code for theLesson 8: Screen03 operating system as a basis.
    Contents
    • 1 String Manipulation
    • 2 Division
    • 3 Number Strings
    • 4 Format Strings
    • 5 Convert OS
      Variadic functions look much less intuitive in assembly code. Nevertheless, they are useful and powerful concepts.
      Being able to draw text is lovely, but unfortunately at the moment you can only draw strings which are already prepared. This is fine for displaying something like the command line, but ideally we would like to be able to display and text we so desire. As per usual, if we put the effort in and make an excellent function that does all the string manipulation we could ever want, we get much easier code later on in return. Once such complicated function in C programming is sprintf. This function generates a string based on a description given as another string and additional arguments. What is interesting about this function is that it is variadic. This means that it takes a variable number of parameters. The number of parameters depends on the exact format string, and so cannot be determined in advance.
      The full function has many options, and I list a few here. I've highlighted the ones which we will implement in this tutorial, though you can try to implement more.
    The function works by reading the format string, and then interpreting it using the table below. Once an argument is used, it is not considered again. The return value of the function is the number of characters written. If the method fails, a negative number is returned.
    Table 1.1 sprintf formatting rules[td]
    SequenceMeaning
    Any character except %Copies the character to the output.
    %%Writes a % character to the output.
    %cWrites the next argument as a character.
    %d or %iWrites the next argument as a base 10 signed integer.
    %eWrites the next argument in scientific notation using eN to mean ×10[size=0.85em]N.
    %EWrites the next argument in scientific notation using EN to mean ×10[size=0.85em]N.
    %fWrites the next argument as a decimal IEEE 754 floating point number.
    %gSame as the shorter of %e and %f.
    %GSame as the shorter of %E and %f.
    %oWrites the next argument as a base 8 unsigned integer.
    %sWrites the next argument as if it were a pointer to a null terminated string.
    %uWrites the next argument as a base 10 unsigned integer.
    %xWrites the next argument as a base 16 unsigned integer, with lowercase a,b,c,d,e and f.
    %XWrites the next argument as a base 16 unsigned integer, with uppercase A,B,C,D,E and F.
    %pWrites the next argument as a pointer address.
    %nWrites nothing. Copies instead the number of characters written so far to the location addressed by the next argument.
      Further to the above, many additional tweaks exist to the sequences, such as specifying minimum length, signs, etc. More information can be found at sprintf - C++ Reference.
      Here are a few examples of calls to the method and their results to illustrate its use.
    Table 1.2 sprintf example calls[td]
    Format StringArgumentsResult
    "%d"13"13"
    "+%d degrees"12"+12 degrees"
    "+%x degrees"24"+1c degrees"
    "'%c' = 0%o"65, 65"'A' = 0101"
    "%d * %d%% = %d"200, 40, 80"200 * 40% = 80"
    "+%d degrees"-5"+-5 degrees"
    "+%u degrees"-5"+4294967291 degrees"
      Hopefully you can already begin to see the usefulness of the function. It does take a fair amount of work to program, but our reward is a very general function we can use for all sorts of purposes.
    2 Division
      Division is the slowest and most complicated of the basic mathematical operators. It is not implemented directly in ARM assembly code because it takes so long to deduce the answer, and so isn't a 'simple' operation.
      While this function does look very powerful, it also looks very complicated. The easiest way to deal with its many cases is probably to write functions to deal with some common tasks it has. What would be useful would be a function to generate the string for a signed and an unsigned number in any base. So, how can we go about doing that? Try to devise an algorithm quickly before reading on.
      The easiest way is probably the exact way I mentioned in Lesson 1: OK01, which is the division remainder method. The idea is the following:
    • Divide the current value by the base you're working in.
    • Store the remainder.
    • If the new value is not 0, go to 1.
    • Reverse the order of the remainders. This is the answer.
      For example:
    Table 2.1 Example base 2 conversion[td]
    ValueNew ValueRemainder
    137681
    68340
    34170
    1781
    840
    420
    210
    101
      So the answer is 100010012
      The unfortunate part about this procedure is that it unavoidably uses division. Therefore, we must first contemplate division in binary.
      For a refresher on long division expand the box below.
      To implement division in assembly code, we will implement binary long division. We do this because the numbers are stored in binary, which gives us easy access to the all important bit shift operations, and because division in binary is simpler than in any higher base due to the much lower number of cases.
            1011 r 1   1010)1101111     1010          11111       1010         1011        1010           1
      This example shows how binary long division works. You simply shift the divisor as far right as possible without exceeding the dividend, output a 1 according to the poisition and subtract the number. Whatever remains is the remainder. In this case we show 11011112 ÷ 10102 = 10112remainder 12. In decimal, 111 ÷ 10 = 11 remainder 1.
      Try to implement long division yourself now. You should write a function, DivideU32 which divides r0 by r1, returning the result in r0, and the remainder in r1. Below, we will go through a very efficient implementation.
    function DivideU32(r0 is dividend, r1 is divisor)
    set shift to 31
    set result to 0
    while shift ≥ 0
    if dividend ≥ (divisor << shift) then
    set dividend to dividend - (divisor << shift)
    set result to result + 1
    end if
    set result to result << 1
    set shift to shift - 1
    loop
    return (result, dividend)
    end function
      This code does achieve what we need, but would not work as assembly code. Our problem comes from the fact that our registers only hold 32 bits, and so the result of divisor << shift may not fit in a register (we call this overflow). This is a real problem. Did your solution have overflow?
      Fortunately, an instruction exists called clz or count leading zeros, which counts the number of zeros in the binary representation of a number starting at the top bit. Conveniently, this is exactly the number of times we can shift the register left before overflow occurs. Another optimisation you may spot is that we compute divisor << shift twice each loop. We could improve upon this by shifting the divisor at the beginning, then shifting it down at the end of each loop to avoid any need to shift it elsewhere.
      Let's have a look at the assembly code to make further improvements.
    .globl DivideU32
    DivideU32:
    result .req r0
    remainder .req r1
    shift .req r2
    current .req r3
    clz shift,r1
    lsl current,r1,shift
    mov remainder,r0
    mov result,#0
    divideU32Loop$:
    cmp shift,#0
    blt divideU32Return$
    cmp remainder,current
    addge result,result,#1
    subge remainder,current
    sub shift,#1
    lsr current,#1
    lsl result,#1
    b divideU32Loop$
    divideU32Return$:
    .unreq current
    mov pc,lr
    .unreq result
    .unreq remainder
    .unreq shift
    clz dest,src stores the number of zeros from the top to the first one of registerdest to register src
      You may, quite rightly, think that this looks quite efficient. It is pretty good, but division is a very expensive operation, and one we may wish to do quite often, so it would be good if we could improve the speed in any way. When looking to optimise code with a loop in it, it is always important to consider how many times the loop must run. In this case, the loop will run a maximum of 31 times for an input of 1. Without making special cases, this could often be improved easily. For example when dividing 1 by 1, no shift is required, yet we shift the divisor to each of the positions above it. This could be improved by simply using the new clz command on the dividend and subtracting this from the shift. In the case of 1 ÷ 1, this means shift would be set to 0, rightly indicating no shift is required. If this causes the shift to be negative, the divisor is bigger than the dividend and so we know the result is 0 remainder the dividend. Another quick check we could make is if the current value is ever 0, then we have a perfect division and can stop looping.
    .globl DivideU32
    DivideU32:
    result .req r0
    remainder .req r1
    shift .req r2
    current .req r3
    clz shift,r1
    clz r3,r0
    subs shift,r3
    mov remainder,r0
    mov result,#0
    divideU32Loop$:
    blt divideU32LoopContinue$
    add result,result,#1
    subs remainder,current
    lsleq result,shift
    beq divideU32Return$
    divideU32LoopContinue$:
    subs shift,#1
    lsrge current,#1
    lslge result,#1
    bge divideU32Loop$
    divideU32Return$:
    .unreq current
    mov pc,lr
    .unreq result
    .unreq remainder
    .unreq shift
    Copy the code above to a file called 'maths.s'.
    3 Number Strings
      Now that we can do division, let's have another look at implementing number to string conversion. The following is pseudo code to convert numbers from registers into strings in up to base 36. By convention, a % b means the remainder of dividing a by b.
    function SignedString(r0 is value, r1 is dest, r2 is base)
    if value ≥ 0
    then return UnsignedString(value, dest, base)
    otherwise
    if dest > 0 then
    setByte(dest, '-')
    set dest to dest + 1
    end if
    return UnsignedString(-value, dest, base) + 1
    end if
    end function
    function UnsignedString(r0 is value, r1 is dest, r2 is base)
    set length to 0
    do
    set (value, rem) to DivideU32(value, base)
    if rem > 10
    then set rem to rem + '0'
    otherwise set rem to rem - 10 + 'a'
    if dest > 0
    then setByte(dest + length, rem)
    set length to length + 1
    while value > 0
    if dest > 0
    then ReverseString(dest, length)
    return length
    end function
    function ReverseString(r0 is string, r1 is length)
    set end to string + length - 1
    while end > start
    set temp1 to readByte(start)
    set temp2 to readByte(end)
    setByte(start, temp2)
    setByte(end, temp1)
    set start to start + 1
    set end to end - 1
    end while
    end function
      In a file called 'text.s' implement the above. Remember that if you get stuck, a full solution can be found on the downloads page.
    4 Format Strings
      Let's get back to our string formatting method. Since we're programming our own operating system, we can add or change formatting rules as we please. We may find it useful to add a %b operation that outputs a number in binary, and if you're not using null terminated strings, you may wish to alter the behaviour of %s to take the length of the string from another argument, or from a length prefix if you wish. I will use a null terminator in the example below.
      One of the main obstacles to implementing this function is that the number of arguments varies. According to the ABI, additional arguments are pushed onto the stack before calling the method in reverse order. So, for example, if we wish to call our method with 8 parameters; 1,2,3,4,5,6,7 and 8, we would do the following:
    • Set r0 = 5, r1 = 6, r2 = 7, r3 = 8
    • Push {r0,r1,r2,r3}
    • Set r0 = 1, r1 = 2, r2 = 3, r3 = 4
    • Call the function
    • Add sp,#4*4
      Now we must decide what arguments our function actually needs. In my case, I used the format string address in r0, the length of the format string in r1, the destination string address in r2, followed by the list of arguments required, starting in r3 and continuing on the stack as above. If you wish to use a null terminated format string, the parameter in r1 can be removed. If you wish to have a maximum buffer length, you could store this in r3. As an additional modification, I think it is useful to alter the function so that if the destination string address is 0, no string is outputted, but an accurate length is still returned, so that the length of a formatted string can be accurately determined.
      If you wish to attempt the implementation on your own, try it now. If not, I will first construct the pseudo code for the method, then give the assembly code implementation.
    function StringFormat(r0 is format, r1 is formatLength, r2 is dest, ...)
    set index to 0
    set length to 0
    while index < formatLength
    if readByte(format + index) = '%' then
    set index to index + 1
    if dest > 0
    then setByte(dest + length, '%')
    otherwise if readByte(format + index) = 'c' then
    if dest > 0
    then setByte(dest + length, nextArg)
    otherwise if readByte(format + index) = 'd' or 'i' then
    set length to length + SignedString(nextArg, dest, 10)
    otherwise if readByte(format + index) = 'o' then
    set length to length + UnsignedString(nextArg, dest, 8)
    otherwise if readByte(format + index) = 'u' then
    set length to length + UnsignedString(nextArg, dest, 10)
    otherwise if readByte(format + index) = 'b' then
    set length to length + UnsignedString(nextArg, dest, 2)
    otherwise if readByte(format + index) = 'x' then
    set length to length + UnsignedString(nextArg, dest, 16)
    otherwise if readByte(format + index) = 's' then
    set str to nextArg
    while getByte(str) != '\0'
    if dest > 0
    then setByte(dest + length, getByte(str))
    set str to str + 1
    loop
    otherwise if readByte(format + index) = 'n' then
    setWord(nextArg, length)
    end if
    otherwise
    if dest > 0
    then setByte(dest + length, readByte(format + index))
    end if
    loop
    return length
    end function
    Although this function is massive, it is quite straightforward. Most of the code goes into checking all the various conditions, the code for each one is simple. Further, all the various unsigned integer cases are the same but for the base, and so can be summarised in assembly. This is given below.
    .globl FormatString
    FormatString:
    format .req r4
    formatLength .req r5
    dest .req r6
    nextArg .req r7
    argList .req r8
    length .req r9
    push {r4,r5,r6,r7,r8,r9,lr}
    mov format,r0
    mov formatLength,r1
    mov dest,r2
    mov nextArg,r3
    add argList,sp,#7*4
    mov length,#0
    formatLoop$:
    subs formatLength,#1
    movlt r0,length
    poplt {r4,r5,r6,r7,r8,r9,pc}
    ldrb r0,[format]
    add format,#1
    teq r0,#'%'
    beq formatArg$
    formatChar$:
    teq dest,#0
    strneb r0,[dest]
    addne dest,#1
    add length,#1
    b formatLoop$
    formatArg$:
    movlt r0,length
    ldrb r0,[format]
    add format,#1
    teq r0,#'%'
    beq formatChar$
    teq r0,#'c'
    moveq r0,nextArg
    ldreq nextArg,[argList]
    addeq argList,#4
    beq formatChar$
    teq r0,#'s'
    beq formatString$
    teq r0,#'d'
    beq formatSigned$
    teq r0,#'u'
    teqne r0,#'x'
    teqne r0,#'b'
    teqne r0,#'o'
    beq formatUnsigned$
    b formatLoop$
    formatString$:
    ldrb r0,[nextArg]
    teq r0,#0x0
    addeq argList,#4
    beq formatLoop$
    add length,#1
    teq dest,#0
    strneb r0,[dest]
    addne dest,#1
    add nextArg,#1
    b formatString$
    formatSigned$:
    mov r0,nextArg
    ldr nextArg,[argList]
    add argList,#4
    mov r1,dest
    mov r2,#10
    bl SignedString
    teq dest,#0
    addne dest,r0
    add length,r0
    b formatLoop$
    formatUnsigned$:
    teq r0,#'u'
    moveq r2,#10
    teq r0,#'x'
    moveq r2,#16
    teq r0,#'b'
    moveq r2,#2
    teq r0,#'o'
    moveq r2,#8
    mov r0,nextArg
    add argList,#4
    mov r1,dest
    bl UnsignedString
    teq dest,#0
    addne dest,r0
    add length,r0
    b formatLoop$
    5 Convert OS
      Feel free to try using this method however you wish. As an example, here is the code to generate a conversion chart from base 10 to binary to hexadecimal to octal and to ASCII.
      Delete all code after bl SetGraphicsAddress in 'main.s' and replace it with the following:
    mov r4,#0
    loop$:
    ldr r0,=format
    mov r1,#formatEnd-format
    ldr r2,=formatEnd
    lsr r3,r4,#4
    push {r3}
    push {r3}
    push {r3}
    push {r3}
    bl FormatString
    add sp,#16
    mov r1,r0
    ldr r0,=formatEnd
    mov r2,#0
    mov r3,r4
    cmp r3,#768-16
    subhi r3,#768
    addhi r2,#256
    cmp r3,#768-16
    subhi r3,#768
    addhi r2,#256
    cmp r3,#768-16
    subhi r3,#768
    addhi r2,#256
    bl DrawString
    add r4,#16
    b loop$
    .section .data
    format:
    .ascii "%d=0b%b=0x%x=0%o='%c'"
    formatEnd:
      Can you work out what will happen before testing? Particularly what happens for r3 ≥ 128? Try it on the Raspberry Pi to see if you're right. If it doesn't work, please see our troubleshooting page.
      When it does work, congratulations, you've completed the Screen04 tutorial, and reached the end of the screen series! We've learned about pixels and frame buffers, and how these apply to the Raspberry Pi. We've learned how to draw simple lines, and also how to draw characters, as well as the invaluable skill of formatting numbers into text. We now have all that you would need to make graphical output on an Operating System. Can you make some more drawing methods? What about 3D graphics? Can you implement a 24bit frame buffer? What about reading the size of the framebuffer in from the command line?
      The next series is the Input series, which teaches how to use the keyboard and mouse to really get towards a traditional console computer.
    GMT+8, 2025-2-19 07:06 , Processed in 0.115426 second(s), 15 queries , MemCache On.
