TA的每日心情 | 开心 2015-2-14 07:12 |
签到天数: 4 天 连续签到: 1 天 [LV.2]偶尔看看I
上網查了有關超音波的東西
發現超音波竟然可以測量溫度
自己也去查了不少
要如何用python寫出他的超音波測量溫度的公式呢@@?
只找到這公式
Vs =331+ 0.6 t°
我去查也只有測量距離的
想要改成測量溫度
有人能幫個忙嘛!!
以下是我網站抓的程式
# ultrasonic_1.py
# Measure distance using an ultrasonic module
# Author : Matt Hawkins
# Date : 09/01/2013
# Import required Python libraries
import time
import RPi.GPIO as GPIO
# Use BCM GPIO references
# instead of physical pin numbers
GPIO.setmode(GPIO.BCM)
# Define GPIO to use on Pi
GPIO_TRIGGER = 23
GPIO_ECHO = 24
print "Ultrasonic Measurement"
# Set pins as output and input
GPIO.setup(GPIO_TRIGGER,GPIO.OUT) # Trigger
GPIO.setup(GPIO_ECHO,GPIO.IN) # Echo
# Set trigger to False (Low)
GPIO.output(GPIO_TRIGGER, False)
# Allow module to settle
time.sleep(0.5)
# Send 10us pulse to trigger
GPIO.output(GPIO_TRIGGER, True)
time.sleep(0.00001)
start = time.time()
while GPIO.input(GPIO_ECHO)==0:
start = time.time()
while GPIO.input(GPIO_ECHO)==1:
stop = time.time()
# Calculate pulse length
elapsed = stop-start
# Distance pulse travelled in that time is time
# multiplied by the speed of sound (cm/s)
distance = elapsed * 34000
# That was the distance there and back so halve the value
distance = distance / 2
print "Distance : %.1f" % distance
# Reset GPIO settings
GPIO.cleanup()
