查看: 3355|回复: 4
打印 上一主题 下一主题
低价出一个TFT触摸屏和zedboard配件
    无聊
    2016-12-23 14:05
  • 签到天数: 7 天
    跳转到指定楼层
    楼主
    发表于 2015-1-11 17:32:06 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    15元出一个TFT触摸屏,功能完好,需要的联系QQ 2638823746
    还有一个zedboard上面的 mpod模块,50块钱
    The Digilent PmodHB3 2A H-Bridge Module (the HB3) is an ideal solution for robotics and other applications where logic signals are used to drive small to medium-sized DC motors.
    The HB3 works with power supply voltages from 2.5V to 5V, but is normally operated at 3.3V as this is the supply voltage on most Digilent system boards.
    The HB3 is designed to work with either Digilent programmable logic system boards or embedded control system boards. Most Digilent system boards, such as the Nexys, Basys, or Cerebot, have 6-pin connectors that allow the HB3 to plug directly into the system board or to connect via a Digilent 6-pin cable.
    • 2A H-bridge circuit for voltages up to 12V
    • Two 2-pin screw terminal blocks for connection to motor
    • Small size (0.8" x 1.20")
    • Ships with a 6" 6-pin cable and a 6-pin header
    举报
  • 签到天数: 773 天
    发表于 2015-1-12 09:14:33 | 只看该作者
    帮顶一下。
    举报
    发表于 2015-1-13 14:56:00 | 只看该作者
    什么驱动IC……?
    举报
  • 签到天数: 181 天
    [LV.7]常住居民III
    发表于 2015-1-19 10:27:51 | 只看该作者
    这个模块是干嘛用的?
    举报
    无聊
    2016-12-23 14:05
  • 签到天数: 7 天
     楼主| 发表于 2015-1-19 16:41:42 | 只看该作者
    小鹏 发表于 2015-1-19 10:27
    这个模块是干嘛用的?
    zedboard的电机控制模块
    举报
    站长推荐上一条 3/5 下一条
    【预约|参会享"豪"礼】2025慕尼黑上海设备展
    查看 »
    GMT+8, 2025-4-29 16:05 , Processed in 0.150457 second(s), 26 queries , MemCache On.
