查看: 5002|回复: 0
求助,香蕉派Android系统烧写后启动不了
    郁闷
    2014-11-27 21:43
    发表于 2014-11-27 23:10:29 | 显示全部楼层 |阅读模式
    在官方下了一个4.2和4.4的都烧写了,4.2卡在logo,4.4的就一直黑屏,烧写都没有报错,请问大家是怎么烧写的?或者用的什么镜像?我的是存储卡是TF+卡套,这个有影响吗?烧写其他系统正常
    4.4的TTL输出
    HELLO! BOOT0 is starting!
    boot0 version : 3.0.0
    dram size =1024
    card boot number = 0
    card no is 0
    sdcard 0 line count 0
    [mmc]: SD/MMC Card: 4bit, capacity: 15193MB
    [mmc]: vendor: Man 0x00035344 Snr 0x0378ad37
    [mmc]: product: SL16G
    [mmc]: revision: 8.0
    sdcard 0 init ok
    The size of uboot is 0x000a8000.
    sum=0xe7d369eb
    src_sum=0xe7d369eb
    Succeed in loading uboot from sdmmc flash.
    Ready to disable icache.
    Jump to secend Boot.
    [      0.184]
    U-Boot 2011.09-rc1 (Jul 08 2014 - 07:29:52) Allwinner Technology
    [      0.191]version: 1.1.0
    [      0.194]pmbus:   ready
    [      0.299]PMU: AXP209
    [      0.301]PMU: AXP20x found
    [      0.304]PMU: bat ratio = 0
    [      0.310]PMU: dcdc2 1400
    [      0.321]PMU: pll1 912 Mhz
    boot_clock = 912
    dcdc2_vol = 1400
    dcdc3_vol = 1250
    ldo2_vol = 3000
    ldo3_vol = 2800
    ldo4_vol = 2800
    power_start = 0
    storage_type = -1
    usb_recovery = 1
    find power_sply to end
    battery: reg value=30
    vbus dc exist, limit to dc
    fel key old mode
    run key detect
    no key found
    no key input
    dram_para_set start
    dram_para_set end
    [      0.443]DRAM:  1 GiB
    relocation Offset is: 35b23000
    DRV_DISP_Init: opened
    [      0.651]fetch script data boot_disp.output_type fail
    [      0.656]fetch script data boot_disp.output_mode fail
    [      0.661]fetch script data boot_disp.auto_hpd fail
    [      0.666]lcd0_para.lcd_used=1
    workmode = 0
    MMC:     0
    SUNXI SD/MMC: 0
    Man 035344 Snr 0378ad37
    SL16G
    8.0
    ---------------MMC version 4.0---------------
    ---------------mmc->clock 50000000-----------
    ---------------mmc->bus_width 4--------------
    boot0 capacity: 0KB,boot1 capacity: 0KB
    [      0.719]sunxi flash init ok
    In:    serial
    Out:   serial
    Err:   serial
    --------fastboot partitions--------
    -total partitions:11-
    -name-        -start-       -size-
    bootloader  : 1000000       1000000
    env         : 2000000       1000000
    boot        : 3000000       1000000
    system      : 4000000       2e000000
    data        : 32000000      28000000
    misc        : 5a000000      1000000
    recovery    : 5b000000      2000000
    cache       : 5d000000      28000000
    databk      : 85000000      10000000
    private     : 95000000      1000000
    UDISK       : 96000000      0
    base bootcmd=run setargs_mmc boot_normal
    bootcmd set setargs_mmc
    key 0
    recovery key high 6, low 4
    cant find fstbt value
    to be run cmd=run setargs_mmc boot_normal
    WORK_MODE_BOOT
    board_status_probe
    [      0.810]battery low power with dc or ac, should charge longer
    rtc disable
    set next system normal
    OSAL_CCMU_MclkOnOff,Fail to get clk name from clk id [0].
    DRV_DISP_Exit: closed
    [      4.575]power off
    axp20_set_power_off
    GMT+8, 2025-1-19 22:26 , Processed in 0.107073 second(s), 15 queries , MemCache On.
