查看: 5405|回复: 3
香蕉派R1的Openwrt镜像应急包
    发表于 2014-11-14 10:04:07 | 显示全部楼层 |阅读模式
    说明:
    This firmware build supports Lamobo-R1 board(BananaPi R1).
    We have an image that has been configured to provide, please refer this link:http://elastos.org/elorg_common/Lamobo-R1/2014-11-13//openwrt-sunxi-Lamobo-R1-sdcard-vfat-ext4-configured.img.
    (the login username/password are root/root.)
    1.How to make a bootable sdcard (using a configured image)
    Lamobo R1 accepts TF-card. Make sure your TF-card is bigger than 512MB. A configured firmware (is named “openwrt-sunxi-Lamobo-R1-sdcard-vfat-ext4-configured.img”) can be burned to, by using:
    $ sudo dd if=openwrt-sunxi-Lamobo-R1-sdcard-vfat-ext4-configured.img of=/dev/sdX bs=1MB
    2. How to make a bootable sdcard by using general image:
    The general image is “openwrt-sunxi-Lamobo-R1-sdcard-vfat-ext4.img”, which is directly built from source code, and not be configured. If you like configure your router from chaos, you have to do some steps to fix switch driver loading bug.
    Because switch driver has not integrate as kmod-*. You have to load “.ko” modules by manual. following steps should be done:
    1) Copy drivers (all kernel modules had been saved in a folder “kernel-modules”) to Operwrt modules directory(for this case, it is “/lib/modules/3.14.18″).
    $ cd build_dir/target-arm_cortex-a8+vfpv3_uClibc-0.9.33.2_eabi/linux-sunxi/linux-3.14.18/
    $ cp kernel-modules/* ${OPENWRT_IMAGE_DISK}/lib/modules/3.14.18/
    2) Install kernel modules
    You can install by manual:
    insmod stmmac.ko
    insmod swconfig.ko
    insmod b53_common.ko
    insmod b53_mdio.ko
    Or, write an auto-loaded script in ${OPENWRT_IMAGE_DISK}/etc/modules.d, as below:
    $ cd ${OPENWRT_IMAGE_DISK}/etc/modules
    $ cat > b53-switch
    stmmac
    swconfig
    b53_common
    b53_mdio
    3. Install OpenWrt packages
    OpenWrt packages is released on: http://elastos.org/elorg_common/Lamobo-R1/2014-11-13/packages. You can change opkg.conf(/etc/opkgopkg.conf) content to below:
    src/gz chaos_calmer_base http://elastos.org/elorg_common/Lamobo-R1/2014-11-13/packages/base
    src/gz chaos_calmer_luci http://elastos.org/elorg_common/Lamobo-R1/2014-11-13/packages/luci
    src/gz chaos_calmer_management http://elastos.org/elorg_common/Lamobo-R1/2014-11-13/packages/management
    src/gz chaos_calmer_packages http://elastos.org/elorg_common/Lamobo-R1/2014-11-13/packages/packages
    src/gz chaos_calmer_routing http://elastos.org/elorg_common/Lamobo-R1/2014-11-13/packages/routing
    src/gz chaos_calmer_telephony http://elastos.org/elorg_common/Lamobo-R1/2014-11-13/packages/telephony
    And then, update opkg database:
    $ opkg update
    Bug list:
    1. WiFi driver (rtl8192cu) can not work properly
    I sorry for this feature: rtl8192cu kernel module can be loaded, but it can not been listed out the interface (for example: wlan0) by using “ifconfig -a”. This bug is continues researching.
    下载自:http://kingone.elastos.org/2014/11/13/this-firmware-build-supports-lamobo-r1-boardbananapi-r1/
    百度网盘分享链接:
    链接: http://pan.baidu.com/s/1nt9NuBn 密码: 1vt3
  • 签到天数: 1771 天
    [LV.Master]伴坛终老
    发表于 2014-11-14 10:28:10 | 显示全部楼层
    搬得很神速
  • 签到天数: 430 天
    发表于 2014-11-14 10:55:29 | 显示全部楼层
    终于出来了,这个星期天有得玩了
  • 签到天数: 886 天
    发表于 2014-11-16 13:39:34 | 显示全部楼层
    下载了,多谢分享!
    GMT+8, 2024-12-19 18:41 , Processed in 0.149881 second(s), 21 queries , MemCache On.
