查看: 13390|回复: 9
初玩Arduino之OLED屏循环显示图片
    发表于 2014-11-12 09:06:34 | 显示全部楼层 |阅读模式
    简介:一个通过Arduino在128 64 OLED屏上循环显示图片的小程序
    用到的设备:
    128 64 OLED屏
    Bettle(兼容Arduino Leonard)
    一、生成图模
    1、用Photoshop创建一个大小为128 64的灰度图像
    2、内容编译完成后,选择图像-模式,改为位图并拼合图层
    3、文件-另存为1Bit的BMP格式
    4、在取模软件(后边下载)的设置中,选中字节倒序选项
    5、打开刚才保存的图像文件
    6、点黑白反转图像
    7、点C51格式,然后就看见正文的16进制发生变化了。
    8、右下方的十六进制即为图模,需要把这些字符复制到程序源码中。
    程序源代码:
    1. #include "stdio.h"
    2. #include "stdlib.h"
    3. #include "U8glib.h"
    4. U8GLIB_SH1106_128X64 u8g(U8G_I2C_OPT_NONE);        // I2C / TWI
    5. static unsigned char yingjitongxun1[] PROGMEM = {
    6. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    7. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    8. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    9. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    10. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    11. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    12. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    13. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    14. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    15. 0x00,0x00,0x00,0x78,0xC0,0x07,0xE0,0x01,0x00,0xFF,0x81,0x07,0xE0,0x01,0x00,0x00,
    16. 0x00,0x00,0x00,0x7C,0xF0,0x0F,0xF8,0x07,0x80,0xFF,0xE0,0x0F,0xF8,0x03,0x00,0x00,
    17. 0x00,0x00,0x00,0x3C,0x38,0x1E,0x1C,0x07,0x80,0x03,0x70,0x1C,0x1C,0x07,0x00,0x00,
    18. 0x00,0x00,0x00,0x36,0x10,0x1C,0x0C,0x06,0x80,0x01,0x30,0x18,0x0C,0x06,0x00,0x00,
    19. 0x00,0x00,0x00,0x37,0x00,0x1C,0x0E,0x06,0x80,0x01,0x38,0x18,0x0E,0x06,0x00,0x00,
    20. 0x00,0x00,0x80,0x3B,0x00,0x1C,0x0E,0x06,0xC0,0x01,0x18,0x18,0x06,0x06,0x00,0x00,
    21. 0x00,0x00,0xC0,0x39,0x00,0x0E,0x0E,0x03,0xC0,0x01,0x1C,0x18,0x07,0x06,0x00,0x00,
    22. 0x00,0x00,0xC0,0x38,0x00,0x07,0xBC,0x03,0xC0,0x1E,0x1C,0x18,0x07,0x06,0x00,0x00,
    23. 0x00,0x00,0xE0,0x18,0xE0,0x03,0xF8,0x00,0xC0,0x7F,0x0C,0x18,0x03,0x06,0x00,0x00,
    24. 0x00,0x00,0x70,0x18,0xE0,0x07,0xFC,0x01,0xC0,0x70,0x0C,0x1C,0x03,0x07,0x00,0x00,
    25. 0x00,0x00,0x38,0x1C,0x00,0x0F,0xC7,0x03,0x00,0x70,0x0C,0x1C,0x03,0x07,0x00,0x00,
    26. 0x00,0x00,0xF8,0x7F,0x00,0x0E,0x83,0x03,0x00,0x60,0x0E,0x8C,0x03,0x03,0x00,0x00,
    27. 0x00,0x00,0xFC,0x7F,0x00,0x8E,0x03,0x03,0x00,0x60,0x0E,0x8C,0x03,0x03,0x00,0x00,
    28. 0x00,0x00,0x00,0x0C,0x00,0x8E,0x01,0x03,0x00,0x70,0x0C,0x0E,0x83,0x03,0x00,0x00,
    29. 0x00,0x00,0x00,0x0C,0x02,0x8E,0x83,0x63,0x10,0x70,0x0C,0x06,0x83,0x01,0x00,0x00,
    30. 0x00,0x00,0x00,0x0C,0x07,0x87,0xC3,0xF1,0x38,0x3C,0x1C,0x07,0xC7,0x01,0x00,0x00,
    31. 0x00,0x00,0x00,0x0E,0xFE,0x03,0xFF,0xF0,0xF0,0x1F,0xF8,0x01,0x7E,0x00,0x00,0x00,
    32. 0x00,0x00,0x00,0x0E,0xF8,0x00,0x3E,0x70,0xC0,0x07,0xF0,0x00,0x3C,0x00,0x00,0x00,
    33. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    34. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    35. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    36. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    37. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    38. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    39. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    40. 0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    41. 0x00,0x00,0x00,0x60,0x00,0x00,0x07,0x00,0x10,0xFC,0x7F,0x20,0x00,0x00,0x00,0x00,
    42. 0x00,0x00,0x00,0x60,0x00,0x80,0xFF,0x03,0x38,0xFC,0x7F,0x70,0xFC,0x3F,0x00,0x00,
    43. 0x00,0x00,0x00,0xE0,0x00,0xC0,0xFF,0x03,0x70,0x20,0x1C,0x60,0xFC,0x1F,0x00,0x00,
    44. 0x00,0x00,0xF0,0xFF,0xFF,0xE0,0x80,0x01,0xE0,0xF0,0x0F,0xE0,0x60,0x18,0x00,0x00,
    45. 0x00,0x00,0xF0,0xFF,0x7F,0x78,0xC0,0x00,0x60,0xC0,0x03,0x40,0x70,0x18,0x00,0x00,
    46. 0x00,0x00,0x38,0x00,0x00,0xFC,0xFF,0x0F,0x40,0xFE,0x7F,0x00,0x30,0x18,0x00,0x00,
    47. 0x00,0x00,0x38,0x20,0x08,0xE8,0xFF,0x0F,0x00,0xFE,0x3F,0x00,0x30,0x1C,0x00,0x00,
    48. 0x00,0x00,0x18,0x30,0x38,0x00,0x00,0x0C,0x00,0xC6,0x30,0x7E,0x30,0x0C,0x00,0x00,
    49. 0x00,0x00,0xD8,0x31,0x18,0x00,0x00,0x0E,0x00,0xC6,0x30,0x3E,0x30,0x0C,0x00,0x00,
    50. 0x00,0x00,0x98,0x31,0x1C,0xF0,0xFF,0x0F,0x3E,0xFE,0x3F,0x30,0x30,0x0C,0x00,0x00,
    51. 0x00,0x00,0x9C,0x31,0x0C,0xF0,0xFF,0x07,0x3E,0xFF,0x3F,0x30,0xFF,0x0D,0x00,0x00,
    52. 0x00,0x00,0x9C,0x31,0x0E,0x00,0x00,0x06,0x30,0xC3,0x18,0x30,0xFF,0x0D,0x00,0x00,
    53. 0x00,0x00,0x8C,0x31,0x06,0x00,0x00,0x06,0x30,0xC3,0x18,0x30,0x18,0x0E,0x00,0x00,
    54. 0x00,0x00,0x8C,0x31,0x07,0xF8,0xFF,0x07,0x38,0xFF,0x1F,0x38,0x18,0x06,0x00,0x00,
    55. 0x00,0x00,0x8C,0x33,0x03,0xF8,0xFF,0x07,0x18,0xFF,0x1F,0x98,0x18,0x06,0x00,0x00,
    56. 0x00,0x00,0x8E,0x83,0x01,0x00,0x06,0x00,0x18,0x63,0x18,0xD8,0x18,0x06,0x00,0x00,
    57. 0x00,0x00,0x86,0xC0,0x01,0x64,0x0E,0x06,0x98,0x61,0x1C,0xF8,0x0C,0x16,0x00,0x00,
    58. 0x00,0x00,0x06,0xC0,0x00,0x6E,0x1C,0x0E,0x98,0x61,0x0F,0x3C,0x0C,0x16,0x00,0x00,
    59. 0x00,0x00,0x03,0x60,0x00,0x66,0x98,0x0D,0xBE,0x61,0x07,0x1C,0x0C,0x36,0x00,0x00,
    60. 0x00,0x00,0xFB,0xFF,0x1F,0x73,0xC0,0x0C,0xF7,0x00,0x00,0x0E,0x0C,0x16,0x00,0x00,
    61. 0x00,0x80,0xF9,0xFF,0x9F,0xF3,0xFF,0x9C,0xE3,0xFF,0x1F,0x04,0x0C,0x1E,0x00,0x00,
    62. 0x00,0x80,0x01,0x00,0x00,0xE0,0x7F,0x80,0x01,0xFF,0x0F,0x00,0x0E,0x0C,0x00,0x00,
    63. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    64. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    65. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    66. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    67. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    68. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    69. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
    70. };
    71. static unsigned char bh4mfe2[] PROGMEM = {
    72. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    73. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    74. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    75. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    76. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    77. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    78. 0x00,0x58,0x1E,0x0E,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    79. 0x00,0x26,0x22,0x11,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    80. 0x00,0x01,0xA2,0x00,0x05,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    81. 0x00,0x01,0x21,0x01,0x05,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    82. 0x00,0x01,0x1F,0x86,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    83. 0x80,0x01,0x09,0x88,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    84. 0x00,0x01,0x09,0x48,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    85. 0x00,0x31,0x51,0x4C,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    86. 0x00,0x8E,0xB0,0x23,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    87. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    88. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    89. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    90. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    91. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    92. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    93. 0x00,0x00,0xF8,0x0F,0x38,0xC0,0x01,0x3C,0x78,0x80,0x87,0xFF,0xF3,0x7F,0x00,0x00,
    94. 0x00,0x00,0xF8,0x3F,0x38,0xC0,0x00,0x3E,0x78,0x80,0x87,0xFF,0xF3,0x7F,0x00,0x00,
    95. 0x00,0x00,0x38,0x38,0x38,0xE0,0x00,0x1E,0x78,0xC0,0x83,0x03,0x70,0x00,0x00,0x00,
    96. 0x00,0x00,0x38,0x30,0x38,0xE0,0x00,0x1B,0x78,0xC0,0x83,0x03,0x70,0x00,0x00,0x00,
    97. 0x00,0x00,0x18,0x30,0x18,0xE0,0x80,0x1B,0x78,0x60,0x83,0x01,0x30,0x00,0x00,0x00,
    98. 0x00,0x00,0x18,0x38,0x18,0xE0,0xC0,0x1D,0xD8,0xE0,0x83,0x01,0x30,0x00,0x00,0x00,
    99. 0x00,0x00,0x1C,0x38,0x1C,0x60,0xE0,0x1C,0xDC,0xB0,0xC3,0x01,0x38,0x00,0x00,0x00,
    100. 0x00,0x00,0x1C,0x1C,0x1C,0x60,0x60,0x1C,0xDC,0xB0,0xC1,0x01,0x38,0x00,0x00,0x00,
    101. 0x00,0x00,0xFC,0x0F,0xFC,0x7F,0x70,0x0C,0xCC,0x98,0xC1,0x7F,0xF8,0x0F,0x00,0x00,
    102. 0x00,0x00,0xFC,0x1F,0xFC,0x7F,0x38,0x0C,0xCC,0x98,0xC1,0x7F,0xF8,0x0F,0x00,0x00,
    103. 0x00,0x00,0x0C,0x3C,0x0C,0x70,0x1C,0x0E,0xCC,0xCC,0xC1,0x00,0x18,0x00,0x00,0x00,
    104. 0x00,0x00,0x0E,0x38,0x0E,0x70,0xFC,0x3F,0x8E,0xCD,0xE1,0x00,0x1C,0x00,0x00,0x00,
    105. 0x00,0x00,0x0E,0x38,0x0E,0x30,0xFE,0x3F,0x8E,0xC7,0xE1,0x00,0x1C,0x00,0x00,0x00,
    106. 0x00,0x00,0x0E,0x38,0x0E,0x38,0x00,0x06,0x8E,0xC3,0xE0,0x00,0x1C,0x00,0x00,0x00,
    107. 0x00,0x00,0x0E,0x1C,0x0E,0x38,0x00,0x06,0x86,0xC3,0xE0,0x00,0x1C,0x00,0x00,0x00,
    108. 0x00,0x00,0x0E,0x1E,0x0E,0x38,0x00,0x06,0x86,0xE1,0xE0,0x00,0x1C,0x00,0x00,0x00,
    109. 0x00,0x00,0xFE,0x0F,0x06,0x38,0x00,0x07,0x06,0xE0,0x60,0x00,0xFC,0x0F,0x00,0x00,
    110. 0x00,0x00,0xFF,0x01,0x07,0x38,0x00,0x07,0x07,0xE0,0x70,0x00,0xFE,0x0F,0x00,0x00,
    111. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    112. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    113. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    114. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    115. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    116. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    117. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    118. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    119. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    120. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    121. 0xC0,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x3E,0x7C,0x1F,0x00,0xF8,0x00,0x00,
    122. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    123. 0x00,0x20,0x84,0x80,0x10,0x22,0x40,0x88,0x00,0x00,0x00,0x00,0x84,0x00,0x02,0x04,
    124. 0x00,0x70,0xCE,0xC1,0x39,0x77,0xE0,0xDC,0x01,0x00,0x00,0x00,0xCE,0x01,0x07,0x0E,
    125. 0x00,0x30,0xC6,0xC0,0x18,0x33,0x60,0xCC,0x00,0x00,0x00,0x00,0xC6,0x00,0x03,0x06,
    126. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    127. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    128. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    129. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    130. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    131. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    132. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    133. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    134. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    135. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
    136. };
    137. static unsigned char zhengnengliang3[] PROGMEM = {
    138. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    139. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    140. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    141. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    142. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    143. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,0x00,0x38,0x00,0x00,0x00,
    144. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x00,0x00,0x38,0x00,0x00,0x00,
    145. 0x00,0x00,0xF0,0xFF,0x7F,0xF0,0xFF,0x7F,0x00,0x18,0x00,0x00,0x18,0x00,0x00,0x00,
    146. 0x00,0x00,0xF8,0xFF,0x3F,0xF8,0xFF,0x3F,0x00,0x1C,0x00,0x00,0x18,0x00,0x00,0x00,
    147. 0x00,0x00,0x00,0x38,0x00,0x00,0x38,0x00,0xF8,0xFF,0x7F,0x00,0x18,0x00,0x00,0x00,
    148. 0x00,0x00,0x00,0x38,0x00,0x00,0x38,0x00,0xF8,0xFF,0x3F,0x00,0x18,0x00,0x00,0x00,
    149. 0x00,0x00,0x00,0x18,0x00,0x00,0x18,0x00,0x18,0x00,0x30,0x00,0x1C,0x00,0x00,0x00,
    150. 0x00,0x00,0x00,0x18,0x00,0x00,0x18,0x00,0x18,0x00,0x30,0x00,0xFC,0x1F,0x00,0x00,
    151. 0x00,0x00,0x00,0x18,0x00,0x00,0x18,0x00,0x1C,0x00,0x30,0x00,0xFC,0x1F,0x00,0x00,
    152. 0x00,0x00,0xFC,0xFF,0x3F,0xFC,0xFF,0x3F,0x8C,0xFF,0x39,0x00,0x0C,0x00,0x00,0x00,
    153. 0x00,0x00,0xFE,0xFF,0x3F,0xFE,0xFF,0x3F,0x8C,0xFF,0x18,0x00,0x0C,0x00,0x00,0x00,
    154. 0x00,0x00,0x00,0x1E,0x00,0x00,0x1E,0x00,0x8C,0xC1,0x18,0x00,0x0C,0x00,0x00,0x00,
    155. 0x00,0x00,0x00,0x3E,0x00,0x00,0x3E,0x00,0x8C,0xC1,0x18,0x00,0x0E,0x00,0x00,0x00,
    156. 0x00,0x00,0x00,0x37,0x00,0x00,0x37,0x00,0x8E,0xC1,0x18,0x00,0x0E,0x00,0x00,0x00,
    157. 0x00,0x00,0x80,0x73,0x00,0x80,0x73,0x00,0xCE,0xC0,0x1C,0x00,0x06,0x00,0x00,0x00,
    158. 0x00,0x00,0xC0,0x71,0x00,0xC0,0x71,0x00,0xC6,0x7F,0x1C,0x00,0x06,0x00,0x00,0x00,
    159. 0x00,0x00,0xE0,0xE0,0x00,0xE0,0xE0,0x00,0xC6,0x7F,0x0C,0x00,0x06,0x00,0x00,0x00,
    160. 0x00,0x00,0xF0,0xC0,0x01,0xF0,0xC0,0x01,0xC6,0x00,0x0C,0x00,0x07,0x00,0x00,0x00,
    161. 0x00,0x00,0x3C,0xC0,0x07,0x3C,0xC0,0x07,0xC6,0x00,0x0C,0x00,0x07,0x00,0x00,0x00,
    162. 0x00,0x00,0x1F,0x00,0x1F,0x1F,0x00,0x1F,0x07,0x00,0x8C,0xFF,0xFF,0x1F,0x00,0x00,
    163. 0x00,0x80,0x07,0x00,0x8E,0x07,0x00,0x0E,0x03,0xE0,0x87,0xFF,0xFF,0x1F,0x00,0x00,
    164. 0x00,0x00,0x01,0x00,0x08,0x01,0x00,0x08,0x03,0xC0,0x03,0x00,0x00,0x00,0x00,0x00,
    165. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    166. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    167. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    168. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    169. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    170. 0x00,0x00,0x00,0x00,0x00,0x83,0x03,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,
    171. 0x00,0x08,0x00,0x00,0x03,0xC3,0x01,0x00,0x00,0x00,0x1C,0x18,0x00,0x00,0x00,0x00,
    172. 0x00,0x38,0x18,0x80,0x03,0xC7,0x00,0x00,0x00,0x00,0x6E,0x1C,0x02,0xFC,0xFF,0x01,
    173. 0x00,0x1C,0x0C,0x00,0xE7,0xFF,0x87,0xFF,0xFF,0x07,0x67,0xCC,0x07,0x0E,0xC0,0x01,
    174. 0x00,0xEC,0xFF,0x07,0xE7,0xFF,0x83,0xFF,0xFF,0x07,0xE3,0xFC,0x01,0xFE,0xFF,0x01,
    175. 0x00,0xE6,0xFF,0x03,0x06,0x18,0x03,0x00,0x07,0xC0,0xFF,0x3C,0x00,0x06,0xC0,0x00,
    176. 0x00,0x07,0x06,0x00,0x02,0x1C,0x03,0x00,0x03,0xC0,0xFF,0x0D,0x02,0xFE,0xFF,0x00,
    177. 0x80,0x03,0x07,0x00,0xE0,0xFF,0x03,0x00,0x03,0x40,0xC0,0x0C,0x06,0x00,0x00,0x00,
    178. 0xC0,0xFB,0xFF,0x07,0xE0,0xFF,0x03,0x00,0x03,0x00,0x00,0x0E,0xE6,0xFF,0xFF,0x07,
    179. 0xE0,0xFB,0xFF,0x07,0x60,0x0C,0x00,0x87,0x03,0xC0,0x7F,0xFE,0xE3,0xFF,0xFF,0x07,
    180. 0x70,0x83,0x01,0xE0,0x33,0x0C,0x00,0x87,0x03,0xC0,0x7F,0xFC,0x03,0x00,0x00,0x00,
    181. 0xA0,0xC3,0x01,0xE0,0xF3,0xFF,0x03,0x83,0xFF,0xC1,0x60,0x00,0x00,0xFF,0xFF,0x00,
    182. 0xA0,0xC1,0x00,0x00,0xFB,0xFF,0x03,0x83,0xFF,0xC0,0x70,0x06,0x80,0xC1,0xC1,0x00,
    183. 0x80,0xE1,0xFF,0x01,0x83,0x07,0x03,0x83,0x01,0xC0,0x3F,0x87,0x80,0xFF,0xFF,0x00,
    184. 0x80,0xE1,0xFF,0x80,0xC3,0x87,0x01,0x83,0x01,0xC0,0x3F,0xC7,0x81,0xC1,0x60,0x00,
    185. 0x80,0x01,0x70,0x80,0x71,0xF6,0x81,0xC3,0x01,0x60,0x30,0xFB,0x80,0xFF,0x7F,0x00,
    186. 0x80,0x01,0x38,0x80,0x3D,0xF6,0x80,0xC1,0x01,0x60,0x30,0x3F,0x00,0xC0,0x00,0x00,
    187. 0xC0,0x80,0x1C,0x80,0x09,0x07,0x80,0xC1,0x00,0xE0,0x3F,0x03,0x00,0xE0,0x00,0x00,
    188. 0xC0,0xC0,0x0F,0xE0,0x03,0x07,0x80,0xC1,0x00,0xE0,0x3F,0x03,0xC1,0xFF,0x7F,0x00,
    189. 0xC0,0x80,0x07,0xF0,0x0F,0x00,0x80,0xC1,0x00,0x60,0x98,0x83,0x01,0x60,0x00,0x00,
    190. 0xC0,0x00,0x0F,0x38,0xFE,0xFF,0xF9,0xFF,0xFF,0x71,0x98,0x83,0x01,0x60,0x00,0x00,
    191. 0xC0,0x00,0x1E,0x10,0xF0,0xFF,0xF8,0xFF,0xFF,0x31,0x9F,0xFF,0xF8,0xFF,0xFF,0x01,
    192. 0xE0,0x00,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x0E,0xFF,0xF8,0xFF,0xFF,0x01,
    193. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    194. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    195. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    196. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    197. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    198. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    199. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    200. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    201. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
    202. };
    203. static unsigned char yuanguang4[] PROGMEM = {
    204. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    205. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    206. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    207. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    208. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    209. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    210. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    211. 0x00,0x00,0x30,0x00,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x00,
    212. 0x00,0x03,0x30,0x00,0x00,0x0F,0xC0,0xBF,0xFF,0x07,0x00,0x00,0x80,0x7F,0x0C,0x00,
    213. 0x00,0xC7,0xFF,0x07,0x80,0x07,0xC0,0xBF,0xFF,0x87,0xFF,0xFF,0xC7,0x7F,0xFE,0x01,
    214. 0x00,0xCE,0xFF,0x07,0xC0,0x0F,0x00,0x86,0x31,0x86,0xFF,0xFF,0x07,0x06,0xFF,0x01,
    215. 0x00,0x0E,0x18,0x00,0xE0,0x1C,0x00,0xC6,0x31,0x06,0x00,0x07,0x00,0x83,0xC3,0x00,
    216. 0x00,0xC4,0xFF,0x03,0x78,0x38,0x00,0xC7,0xFF,0x07,0x00,0x03,0x00,0xC3,0x61,0x00,
    217. 0x00,0xC0,0xFF,0x03,0x1C,0xF0,0x00,0xC3,0xFF,0x03,0x00,0x03,0x00,0xE3,0xFF,0x07,
    218. 0x00,0x00,0x18,0x00,0x0F,0xE0,0x03,0xC3,0x18,0x03,0x00,0x03,0x80,0xE1,0xFF,0x03,
    219. 0xE0,0xF7,0xFF,0xE7,0xFF,0xFF,0xE7,0xCF,0x18,0x03,0x87,0x03,0xC0,0x9F,0x19,0x03,
    220. 0xE0,0xF3,0xFF,0xC7,0xFD,0x3F,0xE3,0xCF,0xFF,0x03,0x87,0x03,0xC0,0xDF,0x18,0x03,
    221. 0x00,0x03,0x00,0x40,0x00,0x00,0x00,0xE3,0xFF,0x03,0x83,0xFF,0xE1,0xD8,0xFF,0x03,
    222. 0x00,0xC3,0xFF,0x01,0x00,0x00,0x80,0x03,0x1C,0x00,0x83,0xFF,0xF0,0xCC,0xFF,0x03,
    223. 0x00,0xE3,0xFF,0x01,0xFF,0x7F,0x80,0x01,0x0C,0x00,0x83,0x01,0xE0,0xCC,0x98,0x03,
    224. 0x80,0x63,0xC0,0x00,0xFF,0x7F,0x80,0xE1,0xFF,0x03,0x83,0x01,0xE0,0xCC,0x8C,0x01,
    225. 0x80,0xE1,0xFF,0x00,0x03,0x70,0x80,0xFF,0xFF,0x81,0xC3,0x01,0xC0,0xEC,0xFF,0x01,
    226. 0x80,0x69,0xC0,0x80,0x03,0x30,0x80,0x0F,0x0C,0x80,0xC1,0x01,0xC0,0xEC,0xFF,0x01,
    227. 0x80,0xEF,0xFF,0x80,0x03,0x30,0xE0,0x0F,0x0E,0x80,0xC1,0x00,0x60,0x64,0x8C,0x01,
    228. 0x80,0xE7,0xFF,0x80,0x01,0x30,0xF8,0x01,0x06,0x80,0xC1,0x00,0xE0,0x37,0x8C,0x01,
    229. 0xE0,0x31,0x60,0x80,0x01,0x30,0x38,0xFC,0xFF,0x81,0xC1,0x00,0xE0,0x37,0xC4,0x00,
    230. 0xC0,0x30,0x7C,0x80,0xFF,0x3F,0x00,0xFC,0xFF,0xF9,0xFF,0xFF,0x61,0x38,0xC6,0x00,
    231. 0x40,0x30,0x38,0x80,0xFF,0x3F,0x00,0x00,0x00,0xF8,0xFF,0xFF,0x61,0x1C,0xF6,0x00,
    232. 0x00,0x00,0x00,0xC0,0x01,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x70,0x00,
    233. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    234. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    235. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    236. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    237. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    238. 0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    239. 0x00,0x38,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x00,0x18,0x00,0x00,
    240. 0x00,0x18,0x38,0x00,0xFE,0xFF,0x87,0xC1,0xFF,0x03,0x00,0x03,0x00,0x1C,0x00,0x00,
    241. 0x00,0xEC,0xFF,0x0F,0xFE,0xFF,0x83,0xC7,0xFF,0x03,0x07,0x03,0x03,0x0C,0xFF,0x0F,
    242. 0x00,0xEE,0xFF,0x0F,0x06,0x03,0x03,0x0F,0x00,0x00,0x06,0x83,0x03,0x0C,0xFF,0x0F,
    243. 0x00,0x06,0x18,0x00,0x07,0x03,0x03,0x0E,0x00,0x00,0x0E,0xC3,0x01,0x2C,0xE0,0x00,
    244. 0x00,0x07,0x18,0x00,0x03,0x03,0x03,0x04,0x00,0x00,0x8C,0xE3,0x80,0x6D,0xE0,0x00,
    245. 0x80,0xE7,0xFF,0x07,0x83,0x83,0x03,0x00,0x00,0x00,0x9C,0x73,0xC0,0x6E,0x60,0x00,
    246. 0xC0,0xE3,0xFF,0x07,0xFF,0xFF,0x03,0xF0,0xFF,0x07,0x88,0x21,0xC0,0x36,0x60,0x00,
    247. 0xE0,0x73,0x0C,0x03,0xFF,0xFF,0xE1,0xF3,0xFF,0x07,0x80,0x01,0xC0,0x36,0x60,0x00,
    248. 0x60,0x33,0x0C,0x83,0x83,0x81,0xE1,0x83,0x31,0xE0,0xFF,0xFF,0x63,0x1E,0x60,0x00,
    249. 0x20,0x33,0x0C,0x83,0x83,0x81,0x01,0x83,0x31,0xE0,0xFF,0xFF,0x63,0x06,0x70,0x00,
    250. 0x00,0xF3,0xFF,0x83,0x81,0x81,0x01,0x83,0x39,0x00,0x38,0x06,0x40,0x07,0x70,0x00,
    251. 0x80,0xF3,0xFF,0x83,0xC1,0xC1,0x81,0xC3,0x18,0x00,0x18,0x06,0x00,0x03,0x30,0x00,
    252. 0x80,0x21,0x06,0x80,0xFF,0xFF,0x80,0xC3,0x18,0x01,0x18,0x06,0x00,0x03,0x30,0x00,
    253. 0x80,0x31,0x06,0xC0,0xFF,0xFF,0x80,0x61,0x18,0x03,0x1C,0x06,0x80,0x07,0x30,0x00,
    254. 0x80,0x71,0x03,0xC0,0xC0,0xC0,0x80,0x71,0x98,0x01,0x0E,0x07,0x80,0x0F,0x38,0x00,
    255. 0x80,0xE1,0x03,0xC0,0xC0,0xC0,0x80,0x3D,0xF8,0x01,0x06,0x07,0xC0,0x0D,0x38,0x00,
    256. 0x80,0xC1,0x03,0x60,0xC0,0xC0,0x80,0x0D,0xF8,0x00,0x07,0x83,0xC0,0x1C,0x38,0x00,
    257. 0xC0,0xE0,0x0F,0x60,0xE0,0xE0,0xE0,0x03,0x00,0xC0,0x03,0x83,0xE1,0x08,0x18,0x00,
    258. 0xC0,0x7C,0xFE,0x30,0x60,0x60,0x70,0x0F,0x00,0xFA,0x00,0xFF,0x71,0x00,0x18,0x00,
    259. 0xC0,0x1E,0xF8,0x19,0x60,0x7E,0x38,0xFE,0xFF,0x71,0x00,0xFF,0x38,0xC0,0x1F,0x00,
    260. 0xC0,0x04,0x80,0x18,0x60,0x3E,0x10,0xF0,0xFF,0x10,0x00,0x00,0x10,0x80,0x0F,0x00,
    261. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    262. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    263. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    264. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    265. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    266. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    267. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
    268. };
    269. static unsigned char wudeng5[] PROGMEM = {
    270. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    271. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    272. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    273. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    274. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    275. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    276. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    277. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,0x00,0x00,0x00,
    278. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x03,0x03,0x30,0x00,0x00,0x00,0x00,
    279. 0x00,0x00,0x00,0x00,0xFF,0xFF,0x07,0x00,0x03,0x00,0xC7,0xFF,0x07,0x00,0x00,0x00,
    280. 0x00,0x00,0x00,0x00,0xFF,0xFF,0x83,0xFF,0xFF,0x07,0xCE,0xFF,0x07,0x00,0x00,0x00,
    281. 0x00,0x00,0x00,0x00,0x80,0x01,0x80,0x01,0x03,0x06,0x0E,0x18,0x00,0x00,0x00,0x00,
    282. 0x00,0x00,0x00,0x00,0x80,0x01,0xC0,0xBE,0xFB,0x06,0xC4,0xFF,0x03,0x00,0x00,0x00,
    283. 0x00,0x00,0x00,0x00,0x80,0x01,0xC0,0x80,0x01,0x07,0xC0,0xFF,0x03,0x00,0x00,0x00,
    284. 0x00,0x00,0x00,0x00,0xC0,0x01,0x00,0xBE,0x7D,0x00,0x00,0x18,0x00,0x00,0x00,0x00,
    285. 0x00,0x00,0x00,0xE0,0xFF,0xFF,0x07,0x98,0x01,0xE0,0xF7,0xFF,0x07,0x00,0x00,0x00,
    286. 0x00,0x00,0x00,0xE0,0xFF,0xFF,0x07,0xFE,0xFF,0xE0,0xF3,0xFF,0x07,0x00,0x00,0x00,
    287. 0x00,0x00,0x00,0x00,0xE0,0x03,0xC0,0x0F,0x70,0x00,0x03,0x00,0x00,0x00,0x00,0x00,
    288. 0x00,0x00,0x00,0x00,0x60,0x03,0xC0,0x3F,0x3E,0x00,0xC3,0xFF,0x01,0x00,0x00,0x00,
    289. 0x00,0x00,0x00,0x00,0x70,0x03,0x40,0xFC,0x0F,0x00,0xE3,0xFF,0x01,0x00,0x00,0x00,
    290. 0x00,0x00,0x00,0x00,0xB8,0x03,0x00,0xFE,0x0F,0x80,0x63,0xC0,0x00,0x00,0x00,0x00,
    291. 0x00,0x00,0x00,0x00,0x98,0x01,0xF0,0xBF,0xFF,0x83,0xE1,0xFF,0x00,0x00,0x00,0x00,
    292. 0x00,0x00,0x00,0x00,0x9C,0x01,0xF1,0x61,0xF8,0x81,0x69,0xC0,0x00,0x00,0x00,0x00,
    293. 0x00,0x00,0x00,0x00,0x8E,0x81,0xC3,0xFF,0x7F,0x80,0xEF,0xFF,0x00,0x00,0x00,0x00,
    294. 0x00,0x00,0x00,0x80,0x87,0x81,0xC1,0xFF,0x3F,0x80,0xE7,0xFF,0x00,0x00,0x00,0x00,
    295. 0x00,0x00,0x00,0xC0,0xC3,0x81,0x01,0x1C,0x30,0xE0,0x31,0x60,0x00,0x00,0x00,0x00,
    296. 0x00,0x00,0x00,0xF0,0xC0,0xFF,0x00,0x0E,0x30,0xC0,0x30,0x7C,0x00,0x00,0x00,0x00,
    297. 0x00,0x00,0x00,0x38,0x80,0x7F,0xF0,0x07,0x1F,0x40,0x30,0x38,0x00,0x00,0x00,0x00,
    298. 0x00,0x00,0x00,0x10,0x00,0x00,0xE0,0x00,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    299. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    300. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    301. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    302. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    303. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    304. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    305. 0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x01,0x00,0x00,0x00,
    306. 0x00,0x00,0x80,0x03,0x00,0xF8,0xFF,0x7F,0xF0,0xFF,0x3F,0xC0,0x01,0x00,0x00,0x00,
    307. 0x00,0x00,0x80,0x01,0x00,0xF8,0xFF,0x7F,0x00,0x30,0x00,0xC0,0xF0,0xFF,0x00,0x00,
    308. 0x00,0x00,0xC0,0x01,0x00,0x00,0x03,0x07,0xF8,0xFF,0x7F,0xC0,0xF0,0xFF,0x00,0x00,
    309. 0x00,0x00,0xE0,0xFF,0x7F,0x00,0x03,0x03,0x18,0x30,0x60,0xC0,0x02,0x0E,0x00,0x00,
    310. 0x00,0x00,0xE0,0xFF,0x7F,0x80,0x03,0x03,0xEC,0xBB,0x6F,0xD8,0x06,0x0E,0x00,0x00,
    311. 0x00,0x00,0x70,0x8C,0x71,0x80,0x03,0x03,0x0C,0x18,0x70,0xEC,0x06,0x06,0x00,0x00,
    312. 0x00,0x00,0x38,0x86,0x31,0x80,0x81,0x03,0xE0,0xDB,0x07,0x6C,0x03,0x06,0x00,0x00,
    313. 0x00,0x00,0x1C,0xC6,0x31,0x80,0x81,0x03,0x80,0x19,0x00,0x6C,0x03,0x06,0x00,0x00,
    314. 0x00,0x00,0x0E,0xC3,0x30,0x80,0x81,0x01,0xE0,0xFF,0x0F,0xE6,0x01,0x06,0x00,0x00,
    315. 0x00,0x00,0x8F,0xE3,0x38,0xFE,0xFF,0x7F,0xFC,0x00,0x07,0x66,0x00,0x07,0x00,0x00,
    316. 0x00,0x00,0x84,0x61,0x18,0xFE,0xFF,0x3F,0xFC,0xE3,0x03,0x74,0x00,0x07,0x00,0x00,
    317. 0x00,0x00,0xC0,0x70,0x18,0xC0,0x80,0x01,0xC4,0xFF,0x00,0x30,0x00,0x03,0x00,0x00,
    318. 0x00,0x00,0xE0,0x30,0x18,0xC0,0xC0,0x01,0xE0,0xFF,0x00,0x30,0x00,0x03,0x00,0x00,
    319. 0x00,0x00,0x70,0x38,0x1C,0xE0,0xC0,0x01,0xFF,0xFB,0x3F,0x78,0x00,0x03,0x00,0x00,
    320. 0x00,0x00,0x38,0x1C,0x0C,0x70,0xC0,0x00,0x1F,0x86,0x1F,0xF8,0x80,0x03,0x00,0x00,
    321. 0x00,0x00,0x1C,0x0C,0x0C,0x30,0xC0,0x00,0xFC,0xFF,0x07,0xDC,0x80,0x03,0x00,0x00,
    322. 0x00,0x00,0x0E,0x0E,0x0E,0x38,0xC0,0x00,0xFC,0xFF,0x03,0xCC,0x81,0x03,0x00,0x00,
    323. 0x00,0x00,0x07,0x07,0x06,0x1C,0xC0,0x00,0xC0,0x01,0x03,0x8E,0x80,0x01,0x00,0x00,
    324. 0x00,0x00,0x82,0x03,0x07,0x0F,0xE0,0x00,0xE0,0x00,0x03,0x07,0x80,0x01,0x00,0x00,
    325. 0x00,0x00,0xC0,0xF1,0x83,0x07,0xE0,0x00,0x7F,0xF0,0x81,0x03,0xFC,0x01,0x00,0x00,
    326. 0x00,0x00,0x80,0xF0,0x01,0x01,0x60,0x00,0x0E,0xF0,0x00,0x01,0xF8,0x00,0x00,0x00,
    327. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    328. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    329. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    330. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    331. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    332. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    333. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
    334. };
    335. static unsigned char mingdi6[] PROGMEM = {
    336. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    337. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    338. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    339. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    340. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    341. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    342. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    343. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x01,0x00,0x00,0x38,0x00,0x00,0x00,
    344. 0x00,0x00,0x00,0x70,0x00,0xF0,0xFF,0xFF,0xC0,0x00,0x00,0x00,0x30,0x00,0x00,0x00,
    345. 0x00,0x00,0x00,0x30,0x00,0xF8,0xFF,0x7F,0xC0,0xC0,0x7F,0xF8,0xFF,0x7F,0x00,0x00,
    346. 0x00,0x00,0x00,0x30,0x00,0x18,0x00,0x00,0xE0,0xC0,0x7F,0xF8,0xFF,0x7F,0x00,0x00,
    347. 0x00,0x00,0x00,0x30,0x00,0x18,0x00,0x04,0x60,0xE0,0x60,0x18,0x00,0x60,0x00,0x00,
    348. 0x00,0x00,0x00,0x38,0x00,0x18,0x01,0x0E,0xFC,0x6F,0x70,0x18,0x00,0x70,0x00,0x00,
    349. 0x00,0x00,0xA0,0x38,0x04,0x98,0x03,0x07,0xFE,0x6F,0x70,0xDC,0xFF,0x77,0x00,0x00,
    350. 0x00,0x00,0x60,0x18,0x0E,0x1C,0x87,0x03,0x30,0x6E,0x30,0xE0,0xFF,0x07,0x00,0x00,
    351. 0x00,0x00,0x70,0x18,0x0E,0x0C,0xCE,0x01,0x38,0x66,0x30,0x00,0x0E,0x00,0x00,0x00,
    352. 0x00,0x00,0x30,0x18,0x0C,0x0C,0xFC,0x00,0x18,0x66,0x30,0x80,0x0F,0x0C,0x00,0x00,
    353. 0x00,0x00,0x38,0x18,0x1C,0x0C,0x78,0x00,0x18,0x37,0x30,0xF8,0x0D,0x0F,0x00,0x00,
    354. 0x00,0x00,0x18,0x1C,0x1C,0x0C,0x78,0x00,0x0C,0x33,0x38,0x3E,0x9C,0x03,0x00,0x00,
    355. 0x00,0x00,0x1C,0x1C,0x18,0x0C,0xFE,0x00,0x9E,0x33,0x18,0x04,0xFF,0x01,0x00,0x00,
    356. 0x00,0x00,0x0E,0x0C,0x18,0x0E,0xC7,0x01,0xBC,0x31,0x18,0xC0,0xF9,0x01,0x00,0x00,
    357. 0x00,0x00,0x06,0x0C,0x38,0x86,0x83,0x03,0xF8,0x30,0x18,0x7C,0x98,0x01,0x00,0x00,
    358. 0x00,0x00,0x07,0x0C,0x38,0xF6,0x81,0x07,0xE0,0x38,0x18,0x1E,0x9E,0x01,0x00,0x00,
    359. 0x00,0x80,0x03,0x0E,0x38,0x66,0x00,0x03,0xF0,0x19,0x18,0x82,0x9F,0x03,0x00,0x00,
    360. 0x00,0x00,0x00,0x0E,0x08,0x26,0x00,0x01,0xB8,0xFB,0x1F,0xE0,0x19,0x07,0x00,0x00,
    361. 0x00,0x00,0x00,0x0E,0x00,0x06,0x00,0x00,0x9E,0xF9,0x0F,0x7C,0x18,0x0E,0x00,0x00,
    362. 0x00,0x00,0x00,0x06,0x00,0xFF,0xFF,0x9F,0x0F,0x18,0x0C,0x0F,0x0C,0x1E,0x00,0x00,
    363. 0x00,0x00,0xF0,0x07,0x00,0xFF,0xFF,0x1F,0x03,0x18,0x00,0xC3,0x0F,0x08,0x00,0x00,
    364. 0x00,0x00,0xE0,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x03,0x00,0x00,0x00,
    365. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    366. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    367. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    368. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    369. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    370. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,
    371. 0x00,0x00,0x00,0x00,0x03,0x00,0x01,0x00,0x00,0x00,0x07,0xE0,0x80,0x03,0x00,0x00,
    372. 0x00,0x00,0x30,0x00,0x03,0x80,0x03,0x00,0x00,0x00,0x03,0x60,0xC0,0x01,0x00,0x00,
    373. 0x00,0x00,0x70,0xFC,0x7F,0x80,0x01,0x00,0xF8,0xFB,0x3F,0xF0,0xDF,0xFF,0x00,0x00,
    374. 0x00,0x00,0xE0,0xFC,0x7F,0xC0,0x01,0x00,0xF8,0xF9,0x3F,0xF0,0xFF,0xFF,0x00,0x00,
    375. 0x00,0x00,0xE0,0x80,0x01,0xE0,0xFF,0x7F,0x98,0x19,0x30,0x98,0x71,0x06,0x00,0x00,
    376. 0x00,0x00,0x40,0xFC,0x3F,0xE0,0xFF,0x7F,0x8C,0xD9,0x18,0x9C,0x3D,0x0E,0x00,0x00,
    377. 0x00,0x00,0x00,0xFC,0x3F,0x70,0x8C,0x71,0x8C,0xD9,0x19,0x8E,0x1B,0x0C,0x00,0x00,
    378. 0x00,0x00,0x00,0x80,0x01,0x38,0x86,0x31,0x8C,0x9D,0x1B,0x04,0x18,0x00,0x00,0x00,
    379. 0x00,0x00,0x7E,0xFF,0x7F,0x1C,0xC6,0x31,0xCC,0x0C,0x19,0x00,0x18,0x00,0x00,0x00,
    380. 0x00,0x00,0x3E,0xFF,0x7F,0x0E,0xC3,0x30,0xCC,0x0C,0x0F,0xF8,0xFF,0x1F,0x00,0x00,
    381. 0x00,0x00,0x30,0x00,0x00,0x8F,0xE3,0x38,0xCC,0x0C,0x07,0xF8,0xFF,0x1F,0x00,0x00,
    382. 0x00,0x00,0x30,0xFC,0x1F,0x84,0x61,0x18,0xC6,0x0C,0x00,0x18,0x1C,0x0C,0x00,0x00,
    383. 0x00,0x00,0x30,0xFE,0x1F,0xC0,0x70,0x18,0xC6,0xFC,0x3F,0x18,0x0C,0x0C,0x00,0x00,
    384. 0x00,0x00,0x38,0x06,0x0C,0xE0,0x30,0x18,0xC6,0xFE,0x3F,0x18,0x0C,0x0C,0x00,0x00,
    385. 0x00,0x00,0x18,0xFE,0x0F,0x70,0x38,0x1C,0x7E,0x00,0x18,0xFC,0xFF,0x0F,0x00,0x00,
    386. 0x00,0x00,0x98,0x06,0x0C,0x38,0x1C,0x0C,0x7E,0x00,0x18,0xFC,0xFF,0x0F,0x00,0x00,
    387. 0x00,0x00,0xF8,0xFE,0x0F,0x1C,0x0C,0x0C,0x7F,0xFF,0x1B,0x0C,0x0E,0x06,0x00,0x00,
    388. 0x00,0x00,0x78,0xFE,0x0F,0x0E,0x0E,0x0E,0x03,0xFF,0x1F,0x0C,0x0E,0x06,0x00,0x00,
    389. 0x00,0x00,0x1E,0x03,0x06,0x07,0x07,0x06,0x00,0x00,0x0C,0x0C,0x06,0x06,0x00,0x00,
    390. 0x00,0x00,0x0C,0xC3,0x07,0x82,0x03,0x07,0x00,0x00,0x0C,0xFC,0xFF,0x07,0x00,0x00,
    391. 0x00,0x00,0x04,0x83,0x03,0xC0,0xF1,0x03,0x00,0xC0,0x0F,0xFE,0xFF,0x07,0x00,0x00,
    392. 0x00,0x00,0x00,0x00,0x00,0x80,0xF0,0x01,0x00,0x80,0x07,0x06,0x00,0x07,0x00,0x00,
    393. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    394. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    395. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    396. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    397. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    398. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    399. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
    400. };
    401. static unsigned char gps7[] PROGMEM = {
    402. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    403. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    404. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    405. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    406. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    407. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    408. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    409. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    410. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0xFF,0x0F,0x00,0x00,
    411. 0x00,0x00,0x00,0x3E,0xF0,0x1F,0x80,0x0F,0xF8,0xFF,0x1F,0xF0,0xFF,0x0F,0x00,0x00,
    412. 0x00,0x00,0x80,0xFF,0xF1,0x7F,0xE0,0x7F,0xF8,0xFF,0x1F,0x30,0x00,0x0C,0x00,0x00,
    413. 0x00,0x00,0xE0,0xC1,0x70,0x70,0xF0,0x30,0x00,0x0E,0x1C,0xF0,0xFF,0x0F,0x00,0x00,
    414. 0x00,0x00,0xE0,0x40,0x70,0xE0,0x70,0x20,0x00,0x0E,0x1C,0xF0,0xFF,0x0F,0x00,0x00,
    415. 0x00,0x00,0x70,0x00,0x30,0xE0,0x38,0x00,0x00,0x06,0x0C,0x38,0x00,0x06,0x00,0x00,
    416. 0x00,0x00,0x38,0x00,0x30,0xE0,0x38,0x00,0x00,0x06,0x0C,0xF8,0xFF,0x07,0x00,0x00,
    417. 0x00,0x00,0x38,0x00,0x38,0x60,0x78,0x00,0x00,0x06,0x0C,0xF8,0xFF,0x07,0x00,0x00,
    418. 0x00,0x00,0x18,0x00,0x38,0x70,0xF0,0x01,0x00,0x06,0x0C,0x30,0x0C,0x00,0x00,0x00,
    419. 0x00,0x00,0x1C,0x00,0x38,0x38,0xE0,0x07,0x00,0x07,0x0E,0x38,0x0C,0x00,0x00,0x00,
    420. 0x00,0x00,0x1C,0xFC,0xF8,0x1F,0xC0,0x0F,0x00,0x07,0x06,0xFC,0xFF,0x0F,0x00,0x00,
    421. 0x00,0x00,0x1C,0x7E,0xF8,0x07,0x00,0x1F,0x00,0xE3,0x07,0xFE,0xFF,0x07,0x00,0x00,
    422. 0x00,0x00,0x1C,0x60,0x1C,0x00,0x00,0x1C,0x00,0xE3,0x03,0x07,0x06,0x00,0x00,0x00,
    423. 0x00,0x00,0x1C,0x60,0x1C,0x00,0x00,0x38,0x00,0x03,0x80,0x03,0x06,0x00,0x00,0x00,
    424. 0x00,0x00,0x1C,0x70,0x1C,0x00,0x00,0x18,0x00,0x03,0x00,0xFD,0xFF,0x03,0x00,0x00,
    425. 0x00,0x00,0x3C,0x70,0x1C,0x00,0x04,0x1C,0x80,0x03,0x00,0xFC,0xFF,0x03,0x00,0x00,
    426. 0x00,0x00,0x78,0x78,0x1C,0x00,0x1F,0x0E,0x80,0x03,0x00,0x00,0x07,0x00,0x00,0x00,
    427. 0x00,0x00,0xF0,0x3F,0x0C,0x00,0xFC,0x07,0x80,0x01,0x00,0x00,0x03,0x00,0x00,0x00,
    428. 0x00,0x00,0xC0,0x0F,0x0E,0x00,0xF0,0xC1,0xFF,0xFF,0x8F,0xFF,0xFF,0x0F,0x00,0x00,
    429. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xFF,0xFF,0xCF,0xFF,0xFF,0x07,0x00,0x00,
    430. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    431. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    432. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    433. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    434. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    435. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    436. 0x00,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    437. 0x00,0x00,0x03,0x00,0x30,0x18,0x00,0x60,0x30,0x00,0x06,0x30,0x00,0x00,0x07,0x00,
    438. 0x00,0x00,0x07,0x00,0x38,0x18,0x00,0x63,0x38,0x00,0x06,0x38,0x00,0x00,0x03,0x00,
    439. 0x80,0xFF,0xFF,0x07,0x1C,0x38,0x00,0x63,0x18,0x00,0x06,0x30,0x00,0x00,0x03,0x00,
    440. 0x80,0xFF,0xFF,0x07,0x0C,0x18,0x00,0x73,0xFC,0x0F,0xC6,0xFF,0x0F,0x00,0x03,0x00,
    441. 0x80,0x01,0x00,0x07,0xCE,0xFF,0x07,0x33,0xFC,0xC7,0xFF,0xFF,0x8F,0xFF,0xFF,0x03,
    442. 0x80,0x01,0x00,0x07,0xE7,0xFF,0x83,0x33,0x06,0xC0,0x7F,0x42,0x86,0xFF,0xFF,0x03,
    443. 0xC0,0x01,0x00,0x83,0x07,0x00,0x80,0x31,0x27,0x00,0x63,0x6E,0x86,0x81,0x01,0x03,
    444. 0xC0,0xFE,0x7F,0xC3,0x87,0xC1,0x81,0xB1,0x7B,0x00,0x03,0xE3,0x80,0x81,0x01,0x03,
    445. 0x00,0xFE,0x7F,0xE0,0x83,0xC1,0x81,0xF1,0xF1,0x00,0xC3,0xC1,0xC1,0x81,0x81,0x03,
    446. 0x00,0x80,0x01,0xE0,0x83,0xC1,0x80,0xB9,0xE0,0x00,0xE3,0x80,0xC3,0x80,0x81,0x03,
    447. 0x00,0xC0,0x01,0x60,0x83,0xC1,0xC0,0x19,0xC0,0x81,0x6B,0x00,0xC1,0xC0,0x81,0x01,
    448. 0x00,0xC6,0x01,0x00,0x83,0x61,0x00,0x18,0x80,0x80,0x2F,0x00,0xC0,0xC0,0x81,0x01,
    449. 0x00,0xC7,0x00,0x80,0xC3,0x61,0x00,0x00,0x00,0xC0,0xEF,0xFF,0xC1,0xFF,0xFF,0x01,
    450. 0x00,0xC3,0x7F,0x80,0xC3,0x61,0x80,0xFF,0xFF,0xF0,0xE1,0xFF,0xE1,0xFF,0xFF,0x01,
    451. 0x80,0xC3,0x7F,0x80,0xC1,0x31,0x80,0xFF,0x7F,0xB0,0x01,0x0E,0xE0,0xC0,0xC0,0x01,
    452. 0x80,0xC7,0x00,0x80,0xC1,0x31,0x80,0x19,0x63,0x80,0x01,0x06,0x00,0xC0,0x00,0x00,
    453. 0xC0,0xE7,0x00,0x80,0xC1,0x39,0xC0,0x18,0x63,0xC0,0x00,0x06,0x00,0xE0,0x00,0x00,
    454. 0xC0,0xEE,0x00,0x80,0xC1,0x18,0xC0,0x18,0x63,0xC0,0x00,0x06,0x00,0xE0,0x00,0x00,
    455. 0x60,0x7C,0x00,0xC0,0x01,0x18,0xC0,0x18,0x63,0xC0,0x00,0x06,0x00,0x60,0x00,0x00,
    456. 0x70,0xF8,0xFF,0xC1,0xFD,0xFF,0xF9,0xFF,0xFF,0xC1,0xFC,0xFF,0x01,0x60,0x00,0x00,
    457. 0x18,0xC0,0xFF,0xC0,0xFC,0xFF,0xF9,0xFF,0xFF,0xF9,0xFC,0xFF,0x01,0x60,0x00,0x00,
    458. 0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0x00,0x00,0x70,0x00,0x00,
    459. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    460. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    461. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    462. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    463. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    464. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    465. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
    466. };
    467. int page = 0;
    468. int max_pages = 7;
    469. void draw(void) {
    470.   // graphic commands to redraw the complete screen should be placed here
    471.   switch(page){
    472.     case 1:  u8g.drawXBMP( 0, 0,128, 64, yingjitongxun1);  break;
    473.     case 2:  u8g.drawXBMP( 0, 0,128, 64, bh4mfe2);  break;
    474.     case 3:  u8g.drawXBMP( 0, 0,128, 64, zhengnengliang3);  break;
    475.     case 4:  u8g.drawXBMP( 0, 0,128, 64, yuanguang4);  break;
    476.     case 5:  u8g.drawXBMP( 0, 0,128, 64, wudeng5);  break;
    477.     case 6:  u8g.drawXBMP( 0, 0,128, 64, mingdi6);  break;
    478.     case 7:  u8g.drawXBMP( 0, 0,128, 64, gps7);  break;
    479.   }
    480.   Serial.println(page);
    481. }
    482. void setup(void) {
    483.   Serial.begin(9600);
    484. }
    485. void loop(void) {
    486.   // picture loop
    487.   u8g.firstPage();
    488.   do {
    489.     draw();
    490.   } while( u8g.nextPage() );
    491.   page==max_pages?page=0:page++;
    492.   delay(2000);
    493. }
    评分
    参与人数 1声望 +5 与非币 +10 收起 理由
    shaoziyang + 5 + 10 很给力!
    查看全部评分
    慵懒
    2015-8-5 08:38
  • 签到天数: 12 天
    发表于 2014-11-12 10:09:06 | 显示全部楼层
    多谢楼主分享!
  • 签到天数: 3747 天
    连续签到: 60 天
    [LV.Master]伴坛终老
    发表于 2014-11-12 12:45:49 | 显示全部楼层
    还不错,适合做个mp3哈!
  • 签到天数: 709 天
    发表于 2014-11-12 18:52:36 | 显示全部楼层
    不错  顶一个吧
  • 签到天数: 1617 天
    [LV.Master]伴坛终老
    发表于 2014-11-14 21:16:21 | 显示全部楼层
    赞一个。
  • 签到天数: 728 天
    发表于 2014-11-19 12:40:36 | 显示全部楼层
    顶一个
    发表于 2015-12-2 10:00:54 | 显示全部楼层
    软件呢,楼主呢
  • 签到天数: 886 天
    发表于 2015-12-2 10:58:27 | 显示全部楼层
    代码好长
  • 签到天数: 827 天
    发表于 2015-12-8 00:13:45 | 显示全部楼层
    你的OLED是IIC引脚?
  • 签到天数: 660 天
    发表于 2016-12-10 00:05:31 | 显示全部楼层
    GMT+8, 2024-12-21 01:15 , Processed in 0.205041 second(s), 35 queries , MemCache On.
