查看: 4652|回复: 7
Ad7298 arduino 模块
  • 签到天数: 13 天
    发表于 2014-10-27 16:56:43 | 显示全部楼层 |阅读模式
    参考inel 伽利略的AD模块,做了一款兼容Arduino的AD模块,有图有例程。
    AD模块
    AD模块
    应用程序
    应用程序
    慵懒
    2019-7-13 19:58
  • 签到天数: 1818 天
    [LV.Master]伴坛终老
    发表于 2014-10-27 19:47:07 | 显示全部楼层
    不错。就是例程的文字确实看不清了。
  • 签到天数: 222 天
    [LV.7]常住居民III
    发表于 2014-10-28 09:20:11 | 显示全部楼层
    楼主把例程的文本文档发一下吧,截图看不清楚呢!
  • 签到天数: 13 天
     楼主| 发表于 2014-10-28 12:45:45 | 显示全部楼层
    单个通道的读写程序:
    1. #include <SPI.h>
    2. unsigned char  receiveBuffer[2] = {0, 0}; //receive data buffer
    3. unsigned short value = 0; //
    4. unsigned short convData;//conversion data,remove the hight 4 bits for channel inforamtion
    5. float volts = 0;   //displayed voltage
    6. unsigned char ch; //voltage Channel
    7. float vRef=2.5;
    8. char   tempString [12]  = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
    9. #define CS 10
    10. void setup() {
    11. //for debug
    12.   Serial.begin(9600);
    13.   //set up the  SPI protocol ref to the AD7298 datasheet
    14.   SPI.setBitOrder(MSBFIRST);
    15.   SPI.setDataMode(SPI_MODE2);
    16.   SPI.begin();
    17. }
    18. void loop() {
    19.
    20.   //the 1st cycle,write cycle
    21.   digitalWrite(CS, LOW);
    22.   SPI.transfer(0xA0); //the first Byte
    23.   SPI.transfer(0x00); //the last byte
    24.   digitalWrite(CS,HIGH);
    25.   delay(10);
    26.
    27. //the 2nd cycle,wait for conversion cycle
    28.   digitalWrite(CS, LOW);
    29.   SPI.transfer(00);
    30.   SPI.transfer(00);
    31.   digitalWrite(CS,HIGH);
    32.   delay(10);
    33.    //the 3rd cycle,read voltage from the assigned channel in the write cyle
    34.
    35.   digitalWrite(CS, LOW);
    36.   receiveBuffer[0]=SPI.transfer(00);
    37.   receiveBuffer[1]=SPI.transfer(00);
    38.   digitalWrite(CS,HIGH);
    39.   //analysis the data for display
    40.   value = ((unsigned short)receiveBuffer[0] << 8) + receiveBuffer[1];
    41.   convData = value & 0x0FFF; //adc raw data value
    42.   ch = (value & 0xF000) >> 12; //adc channel raw data
    43.   volts = 2*((float)convData * vRef) / 4096; //
    44.
    45.   Serial.print("rawdata=");
    46.   itoa(convData, tempString, 10);
    47.   Serial.println(tempString);
    48.
    49.   Serial.print("THE Vin0 input Voltage is:");
    50.   Serial.print(volts,4);
    51.
    52.   Serial.println('\n');
    53.   delay(1000);
    54. }
  • 签到天数: 13 天
     楼主| 发表于 2014-10-31 09:20:23 | 显示全部楼层
    Board layout 截图
    板子布局
    板子布局
  • 签到天数: 1341 天
    发表于 2014-10-31 22:39:57 | 显示全部楼层
    板子上绿色的是个高大上的跳线帽么?
  • 签到天数: 13 天
     楼主| 发表于 2014-11-1 17:33:28 | 显示全部楼层
    是为了兼容3.3v  5v spi接口
    GMT+8, 2024-12-23 02:40 , Processed in 0.167041 second(s), 27 queries , MemCache On.
