查看: 3027|回复: 0
用51单片机给led点阵屏显示文本
  • 签到天数: 4 天
    发表于 2014-10-14 16:04:34 | 显示全部楼层 |阅读模式
    该实验所用的点阵屏为金涵电子公司的点阵屏,  该屏幕内置控制卡,并且已经做好了相关的控制协议, 所以对于51单片机就是把相关的协议指令通过串口发送给该控制卡,即可显示对应的文本。  本实验以显示“1234”为例,代码如下
    #include "reg52.h"
    #include "string.h"
    #define uchar unsigned char
    #define uint unsigned int
    #define CTRL 2
    #define CNT  42
    sbit key1 = P3^4;
    sbit led1 = P1^1;
    char dat;
    int flag;
    uchar sendData(char *string);
    uchar   request[] = {         0xAA, 0xA5 ,0x2C, 0x00, 0x01, 0x01, 0x12, 0x34, 0xB0, 0xA1,
                                                      0x10, 0x03, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00,
                                                      0x00, 0x01, 0x00, 0x00, 0x01, 0x00, 0x14, 0x00, 0xE8, 0x03,
                                                     0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x14, 0x00,
                                                       0xFF, 0xFF, 0x04, 0x00, 0xB0, 0xA1, 0xF7, 0xFE, 0x00 ,0x00,
                                                      0x5A, 0x55
    void TimerInit();
    uchar sendData(uchar *date)
                    int i,j;
                    int count=0;
                    int sum=0;
                    uchar ctrl[2]={0};
                    uchar cnt[2]={0};
                    uchar text[8]={0};
                    while((*date) != '\0' )
                            text[count++] = *date;
                    //        sum = sum *10 +((*date) - 48);
                            date++;
                    sum = 40+count;
                    ctrl[0] = sum;
                    cnt[0] = count;
                    for(i=44,j=0; i<count+44; i++,j++)
                            request = text[j];
                    request[CTRL] = sum;
                    request[CNT] = count;
                    for(i=0; i<52; i++)
                                    ES = 0;
                                    SBUF = request;
                                    while(!TI);
                                    TI = 0;
                                    ES = 1;
    return 0;
    void TimerInit()
            TMOD = 0x20;
            TH1 = 0xfd;
            TL1 = 0xfd;
            TR1 = 1;
            REN = 1;
            SM0 = 0;
            SM1 = 1;
            EA  = 1;
            ES = 1;
    void delay(uint xms)
            uint i,j;
            for(i=xms; i>0; i--)
            for(j=110; j>0; j--);
    void main()
            int i;
            led1 = 1;
            P0 = 0;
            TimerInit();
            while(1)
                    if(flag == 1)
                            flag = 0;
                            sendData("1234");
                    /*if(key1 == 0)
                            delay(10);
                            if(key1==0)
                                    flag = 0;
                                    //sendData("1");
                            for(i=0; i<52; i++)
                                    ES = 0;
                                    SBUF = re;
                                    while(!TI);
                                    TI = 0;
                                    ES = 1;
    void timer0() interrupt 4
            RI = 0;
            dat = SBUF;
            flag = 1;
    GMT+8, 2025-1-9 20:29 , Processed in 0.118172 second(s), 15 queries , MemCache On.
