Hardware Specification of Banana ProTM |
Soc | Allwinner® A20(sun 7i) |
CPU | ARM® Cortex™-A7 Dual-Core1GHz (ARM v7 instruction set) |
GPU | Mali400MP2 Complies with OpenGL ES 2.0/1.1 (hardware acceleration support) |
SDRAM | 1GB DDR3 (shared with GPU) |
Power | 5V @ 2A via MicroUSB (DC in Only) and/or MicroUSB (OTG) |
PMU | AXP209 |
Features |
Low-level perpherials | 40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, CAN, I2S, SPDIF, LRADC, ADC, LINE-IN,FM-IN,HP-IN. |
On board Network | 10/100/1000Mbps ethernet (Realtek RTL8211E/D) |
Wifi Module | WiFi 802.11 b/g/n |
Bluetooth | Optional |
On board Storage | MicroSD (TF) card,SATA 2.0 |
Display | Supports multi-channel HD display: HDMI 1.4 (Type A - full) LVDS/RGB/CPU display interface (DSI) for raw LCD panels Composite video (PAL and NTSC) (via 3.5 mm TRRS jack shared with audio out) 11 HDMI resolutions from 640×480 to 1920×1080 plus various PAL and NTSC standards |
Video | HD H.264 2160p video decoding Mutil-format FHD video decoding, including Mpeg1/2, Mpeg4, H.263, H.264, etc H.264 high profile 1080p@30fps or 720p@60fps encoding |
Audio outputs | HDMI,analog audio (via 3.5 mm TRRS jack shared with composite video out),I2S audio (also potentially for audio input) |
Camera | Parallel 8-bit camera interface |
Audio input | On board micphone
USB | 2 USB 2.0 host, 1 USB 2.0 OTG (all direct from A20 chip) |
Buttons | Reset button Power button U-boot button |
Leds | Power status led (red) Ethernet status led (blue) User defined led (green) |
Other | IR reciever |
Interface definition |
Sizes | 92 mm × 60mm |
Weight | 45g |
Banana ProTM and Banana PiTM are trademarks of LeMaker
