查看: 9100|回复: 6
[Linux技术] 【原创】【飞凌嵌入式】序列之7:串口查看启动信息
  • 签到天数: 709 天
    发表于 2014-9-27 22:43:23 | 显示全部楼层 |阅读模式
    转载请注明出处和作者:版权所有!否则后果自负,谢谢!!
    本节我们主要是从下面3个方面进行讲解:
    1.准备工作
    2.启动效果和启动信息简单对比
    3.启动信息简单分析
    一、准备工作
    1.电脑一台;
    2.飞凌OK335xS-II开发板;
    3.飞凌OK335xS-II开发板自带电源;
    二、开机效果
    1.首先打开开关按钮。如下图所示:
    2.启动画面如下图所示:
    3.进入系统。如下图所示:
    4.下面是系统。如下图所示:
    三、启动信息简单分析
    1. 读取boot里面的内容,进行引导。
    1  0
    Booting from nand ...
    NAND read: device 0 offset 0xc00000, size 0x500000
    U-Boot SPL 2011.09-00000-g39b82a8-dirty (Sep 10 2014 - 12:20:14)
    Texas Instruments Revision detection unimplemented
    Booting from NAND...
    MT29F2G08
    U-Boot 2011.09-00000-g39b82a8-dirty (Sep 10 2014 - 12:20:14)
    2.检查底层驱动。
    I2C:   ready
    DRAM:  128 MiB
    WARNING: Caches not enabled
    Did not find a recognized configuration, assuming General purpose EVM in Profile 0 with Daughter board
    NAND:  HW ECC BCH16 Selected
    ONFI flash detected
    ONFI param page 0 valid
    HW ECC BCH8 Selected
    Detect MT29F2G08
    256 MiB
    MMC:   OMAP SD/MMC: 0
    Video : Drawing the logo from nand.
    NAND read: device 0 offset 0x600000, size 0x36
    54 bytes read: OK
    NAND read: device 0 offset 0x600000, size 0x5fa38
    391736 bytes read: OK
    Net:   cpsw
    Hit any key to stop autoboot:  3  2  1  0
    5242880 bytes read: OK
    ## Booting kernel from Legacy Image at 80200000 ...
       Image Name:   Linux-3.2.0
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    3715896 Bytes = 3.5 MiB
       Load Address: 80008000
       Entry Point:  80008000
       Verifying Checksum ... OK
       Loading Kernel Image ... OK
    OK
    3.启动内核。
    Starting kernel ...
    Uncompressing Linux... done, booting the kernel.
    [    0.000000] Linux version 3.2.0 (root@lf-bj) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #6 Mon Sep 1 14:31:38 CST 2014
    [    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] Machine: am335xevm
    [    0.000000] Memory policy: ECC disabled, Data cache writeback
    [    0.000000] AM335X ES2.1 (sgx neon )
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
    [    0.000000] Kernel command line: console=ttyO0,115200n8 root=ubi0:rootfs rw ubi.mtd=7,2048 rootfstype=ubifs rootwait=1 screentype=R screensize=480x272-4 calibrate=Y laohua=N
    [    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
    [    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
    [    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.000000] Memory: 128MB = 128MB total
    [    0.000000] Memory: 122188k/122188k available, 8884k reserved, 0K highmem
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    [    0.000000]     vmalloc : 0xc8800000 - 0xff000000   ( 872 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
    [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
    [    0.000000]       .text : 0xc0008000 - 0xc0699000   (6724 kB)
    [    0.000000]       .init : 0xc0699000 - 0xc06d6000   ( 244 kB)
    [    0.000000]       .data : 0xc06d6000 - 0xc0755c80   ( 512 kB)
    [    0.000000]        .bss : 0xc0755ca4 - 0xc0789af8   ( 208 kB)
    [    0.000000] NR_IRQS:396
    [    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
    [    0.000000] Total of 128 interrupts on 1 active controller
    [    0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
    [    0.000000] omap_dm_timer_switch_src: Switching to HW default clocksource(sys_clkin_ck) for timer1, this may impact timekeeping in low power state
    [    0.000000] OMAP clocksource: GPTIMER1 at 24000000 Hz
    [    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
    [    0.000000] Console: colour dummy device 80x30
    [    0.000188] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
    [    0.057162] pid_max: default: 32768 minimum: 301
    [    0.057289] Security Framework initialized
    [    0.057392] Mount-cache hash table entries: 512
    [    0.057782] CPU: Testing write buffer coherency: ok
    [    0.058543] devtmpfs: initialized
    [    0.078569] omap_hwmod: pruss: failed to hardreset
    [    0.079672] print_constraints: dummy:
    [    0.080023] NET: Registered protocol family 16
    [    0.082199] OMAP GPIO hardware version 0.1
    [    0.084773] omap_mux_init: Add partition: #1: core, flags: 0
    [    0.086581]  omap_i2c.1: alias fck already exists
    [    0.087731]  omap_hsmmc.0: alias fck already exists
    [    0.087998]  omap_hsmmc.1: alias fck already exists
    [    0.088548]  da8xx_lcdc.0: alias fck already exists
    [    0.088829]  omap_i2c.2: alias fck already exists
    [    0.090301]  d_can.0: alias fck already exists
    [    0.090551]  d_can.1: alias fck already exists
    [    0.092059]  omap2_mcspi.1: alias fck already exists
    [    0.092285]  omap2_mcspi.2: alias fck already exists
    [    0.092558]  edma.0: alias fck already exists
    [    0.092580]  edma.0: alias fck already exists
    [    0.092599]  edma.0: alias fck already exists
    [    0.128259] bio: create slab <bio-0> at 0
    [    0.130475] SCSI subsystem initialized
    [    0.132465] usbcore: registered new interface driver usbfs
    [    0.132782] usbcore: registered new interface driver hub
    [    0.132978] usbcore: registered new device driver usb
    [    0.133288] registerd cppi-dma Intr @ IRQ 17
    [    0.133303] Cppi41 Init Done Qmgr-base(c887a000) dma-base(c8878000)
    [    0.133313] Cppi41 Init Done
    [    0.133341] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
    [    0.133629] mus[    0.942082] brd: module loaded
    [    0.950410] loop: module loaded
    [  [    3.730895] UBI: max. sequence number:       318
    [    3.754657] UBI: attached mtd7 to ubi0
    [    3.758575] UBI: MTD device name:            "File System"
    [    3.764340] UBI: MTD device size:            236 MiB
    [    3.769511] UBI: number of good PEBs:        1888
    [    3.774419] UBI: number of bad PEBs:         0
    [    3.779048] UBI: number of corrupted PEBs:   0
    [    3.783684] UBI: max. allowed volumes:       128
    [    3.788491] UBI: wear-leveling threshold:    4096
    [    3.793399] UBI: number of internal volumes: 1
    [    3.798025] UBI: number of user volumes:     1
    [    3.802659] UBI: available PEBs:             0
    [    3.807285] UBI: total number of reserved PEBs: 1888
    [    3.812465] UBI: number of PEBs reserved for bad PEB handling: 18
    [    3.818812] UBI: max/mean erase counter: 2/0
    [    3.823266] UBI: image sequence number:  752561228
    [    3.828342] UBI: background thread "ubi_bgt0d" started, PID 642
    [    3.835746] CAN device driver interface
    [    3.839745] CAN bus driver for Bosch D_CAN controller 1.0
    [    3.846279] d_can d_can.0: device registered (irq=52, irq_obj=53)
    [    3.853339] d_can d_can.1: device registered (irq=55, irq_obj=56)
    [    3.901834] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
    [    3.908286] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
    [    3.915499] davinci_mdio.0: probed
    [    3.919048] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
    [    3.926580] PPP generic driver version 2.4.2
    [    3.931481] PPP BSD Compression module registered
    [    3.936409] PPP Deflate Compression module registered
    [    3.941927] usbcore: registered new interface driver rtl8192cu
    [    3.948166] usbcore: registered new interface driver zd1201
    [    3.954179] usbcore: registered new interface driver cdc_ether
    [    3.960422] usbcore: registered new interface driver cdc_eem
    [    3.966495] usbcore: registered new interface driver dm9601
    [    3.972361] cdc_ncm: 04-Aug-2011
    [    3.975886] usbcore: registered new interface driver cdc_ncm
    [    3.981784] Initializing USB Mass Storage driver...
    [    3.987103] usbcore: registered new interface driver usb-storage
    [    3.993381] USB Mass Storage support registered.
    [    3.998544] usbcore: registered new interface driver usbserial
    [    4.004780] USB Serial support registered for generic
    [    4.010218] usbcore: registered new interface driver usbserial_generic
    [    4.017037] usbserial: USB Serial Driver core
    [    4.021704] USB Serial support registered for GSM modem (1-port)
    [    4.028237] usbcore: registered new interface driver option
    [    4.034070] option: v0.7.2:USB Driver for GSM modems
    [    4.039438]  gadget: Mass Storage Function, version: 2009/09/11
    [    4.045639]  gadget: Number of LUNs=1
    [    4.049460]  lun0: LUN: removable file: (no medium)
    [    4.054581]  gadget: Mass Storage Gadget, version: 2009/09/11
    [    4.060583]  gadget: userspace failed to provide iSerialNumber
    [    4.066685]  gadget: g_mass_storage ready
    [    4.070879] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
    [    4.076486] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
    [    4.084351] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
    [    4.091433] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    4.098976] usb usb2: Product: MUSB HDRC host driver
    [    4.104157] usb usb2: Manufacturer: Linux 3.2.0 musb-hcd
    [    4.109693] usb usb2: SerialNumber: musb-hdrc.0
    [    4.115348] hub 2-0:1.0: USB hub found
    [    4.119278] hub 2-0:1.0: 1 port detected
    [    4.124609] mousedev: PS/2 mouse device common for all mice
    [    4.131059] [wds tsc probe]x.min=140,x.max=3946,y.min=319,y.max=3865,x.inverted=0,y.inverted=1
    [    4.140491] input: ti-tsc as /devices/platform/omap/ti_tscadc/tsc/input/input0
    [    4.151535] rtc-ds1307 2-0068: rtc core: registered ds1307 as rtc0
    [    4.158030] rtc-ds1307 2-0068: 56 bytes nvram
    [    4.162739] i2c /dev entries driver
    [    4.nitial timeout 60 sec
    [    4.189978] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
    [    4.196546] usbcore: [    4.526003] UBIFS: recovery needed
    [    4.813160] UBIFS: recovery completed
    [    4.817006] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
    [    4.823284] UBIFS: file system size:   235540480 bytes (230020 KiB, 224 MiB, 1855 LEBs)
    [    4.831631] UBIFS: journal size:       9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
    [    4.839257] UBIFS: media format:       w4/r0 (latest is w4/r0)
    [    4.845342] UBIFS: default compressor: lzo
    [    4.849610] UBIFS: reserved for root:  0 bytes (0 KiB)
    [    4.856474] VFS: Mounted root (ubifs filesystem) on device 0:14.
    [    4.867557] devtmpfs: mounted
    [    4.871015] Freeing init memory: 244K
    [    4.884366] mmc0: host does not support reading read-only switch. assuming write-enable.
    [    4.984958] mmc0: new high speed SD card at address c788
    [    5.002382] mmcblk0: mmc0:c788 SD02G 1.83 GiB
    [    5.011713]  mmcblk0: p1
    INIT: version 2.88 booting
    4.启动界面。
    Starting udev
    [    6.038431] udev[784]: starting version 164
    Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or directory
    bootlogd.
    Configuring network interfaces... [    9.318474] net eth0: CPSW phy found : id is : 0x20005c90
    done.
    INIT: Entering runlevel: 5
    Starting system message bus: dbus.
    Starting telnet daemon.
    Starting inetd daemon.
    Starting syslogd/klogd: done
    2012-03-24 08:54:26: (log.c.166) server started
    Stopping Bootlog daemon: bootlogd.
    _____   _____   _____    _       _   __   _  __    __
    |  ___| /  _   |  _    | |     | | |   | |    / /
    | |__   | | | | | |_| |  | |     | | |   | |   / /
    |  __|  | | | | |  _  /  | |     | | | |   |   }  {
    | |     | |_| | | |    | |___  | | | |   |  / /
    |_|     _____/ |_|  _ |_____| |_| |_|  _| /_/  _
    ok335x login:
    一个好的电子工程师一定要学会利用串口来查看一些信息,这个对调试也是至关重要的。
    慵懒
    2015-3-4 09:55
  • 签到天数: 26 天
    [LV.4]偶尔看看III
    发表于 2014-9-28 15:40:41 | 显示全部楼层
    楼主厉害啊
  • 签到天数: 709 天
     楼主| 发表于 2014-9-28 21:34:58 | 显示全部楼层
    Cain丶ST 发表于 2014-9-28 15:40
    楼主厉害啊
    过奖了  菜鸟一个
    无聊
    2015-2-13 10:50
  • 签到天数: 72 天
    [LV.6]常住居民II
    发表于 2014-10-8 10:29:06 | 显示全部楼层
    outstanding1573 发表于 2014-9-28 21:34
    过奖了  菜鸟一个
    期待着和大家分享下一个系列。
  • 签到天数: 709 天
     楼主| 发表于 2014-10-8 13:17:14 | 显示全部楼层
    邦德老王 发表于 2014-10-8 10:29
    期待着和大家分享下一个系列。
    ok
      努力。。。。。。。。。。。。。。。。。。。。
    11 小时前
  • 签到天数: 2160 天
    连续签到: 3 天
    [LV.Master]伴坛终老
    发表于 2015-1-9 22:11:57 | 显示全部楼层
    串口查看启动信息
  • 签到天数: 709 天
     楼主| 发表于 2015-1-10 11:06:29 | 显示全部楼层
    ahljj 发表于 2015-1-9 22:11
    串口查看启动信息
    GMT+8, 2025-1-27 22:11 , Processed in 0.168229 second(s), 28 queries , MemCache On.
