原文在我博客:http://blog.csdn.net/andy_wsj/article/details/8515197
拿到Cubieboard已经蛮久了,平时上班比较忙,只能晚上玩一会,年关将近,周末都要加班呀....
所谓U-boot 移植,其实别人都做好了,我只不过是做了一个启动卡
系统环境:电脑二台,台式机XP;笔记本RHEL5,平时就用这个,懒得整ubuntu
代码工具:XP上: Source Insight 3.5
RHEL5上: Vim,编译工具链arm-2009q3,这个应该有更高版本;串口工具minicom,我的版本是2.1
资源: 支持Cubieboard的U-boot下载网址:https://github.com/linux-sunxi/u-boot-sunxi ,
我直接从网页按zip格式下载到XP下
制作方法参考网站:https://github.com/linux-sunxi/u-boot-sunxi/wiki
硬件: 串口线,淘宝Cubieboard自带USB串口线,RHEL5下不用装驱动就能使用,XP下可以用驱动精灵自动安装
microSD卡一枚,2G,读卡器一只,华强北出品,居然比淘宝贵...
开工:
首先观察Cubiebord预装的U-Boot,设置好minicom(具体方法请自己百度),连接串口(使用淘宝配的线),连线顺序:
黑色 ---- GND
绿色 ---- RX
白色 ---- TX
红色不接
将串口USB端插入笔记本,打开终端输入命令“minicom”,启动minicom之后,再将电源线插入笔记本USB,启动过程中按键盘任意键,进入U-boot,可以看到:
HELLO! BOOT0 is starting!
boot0 version : 1.5.1
dram size =1024
Succeed in opening nand flash.
Succeed in reading Boot1 file head.
The size of Boot1 is 0x0003c000.
The file stored in 0X00000000 of block 2 is perfect.
Check is correct.
Ready to disable icache.
Succeed in loading Boot1. //第1阶段bootloader
Jump to Boot1.
[ 0.133] boot1 version : 1.4.0
[ 0.133] pmu type = 3
[ 0.135] bat vol = 0
[ 0.161] axi:ahb:apb=3:2:2
[ 0.161] set dcdc2=1400, clock=1008 successed
[ 0.163] key
[ 0.175] no key found
[ 0.175] flash init start
[ 0.227] flash init finish
[ 0.228] fs init ok
[ 0.229] fattype FAT16
[ 0.229] fs mount ok
[ 0.236] script finish
[ 0.238] power finish
[ 0.245] BootMain start
[ 0.245] 0
[ 0.264] key value = 0
[ 0.264] recovery key high 6, low 4
[ 0.265] unable to find fastboot_key key_max value
[ 0.274] test for multi os boot with display
[ 0.275] show pic finish
[ 0.278] load kernel start
[ 0.302] load kernel successed
[ 0.302] start address = 0x4a00000
U-Boot 2011.09-rc1 (Nov 26 2012 - 14:01:52) Allwinner Technology //第2阶段bootloader
CPU: SUNXI Family
Board: A10-EVB
DRAM: 512 MiB
NAND: 3776 MiB
In: serial
Out: serial
Err: serial
--------fastboot partitions--------
-total partitions:11-
-name- -start- -size-
bootloader : 1000000 1000000
env : 2000000 1000000
boot : 3000000 2000000
system : 5000000 14000000
data : 19000000 20000000
misc : 39000000 1000000
recovery : 3a000000 2000000
cache : 3c000000 8000000
private : 44000000 1000000
sysrecovery : 45000000 14000000
UDISK : 59000000 93000000
Hit any key to stop autoboot: 0
sunxi#
输入命令 version,可以看到:
sunxi#version
arm-none-linux-gnueabi-gcc (Sourcery G++ Lite 2010.09-50) 4.5.1
GNU ld (Sourcery G++ Lite 2010.09-50) 2.20.51.20100809
sunxi#
使用的编译器是arm-none-linux-gnueabi-gcc,版本4.5.1,但是俺的是4.3.2版本,为此我费了了老大劲,换成4.4.1时才编译成功
有了上面的基本情况,开始编译制作,在XP下解压下载的u-boot-sunxi-sunxi.zip,删除board文件夹下除了allwinner文件的其他文件,board/allwinner文件夹内只需要保留common和Cubieboard两个文件夹,其他不需要;删除arch文件夹内除了arm文件的其他文件,arch/arm/cpu文件夹下只保留armv7和u-boot.lds,arch/arm/cpu/armv7内文件和sunxi文件夹保留,其他文件夹删除。这样做可以在Source Insight关联时减少关联项目,便于查阅,若还想更进一步,将include目录下与A10无关的头文件一并删除,关联时更加清晰。使用Source Insight 3.5建立一个工程,添加文件时选择u-boot解压文件夹,选择“add tree”,将全部文件加入工程,再选Project->Rebuilt Project...,如此一来,XP下的代码查阅工程就建立啦。
linux下解压U-boot到自己工作目录,不需要删除操作。
安装arm-2009q3.tar.bz2,在arm-2009q3.tar.bz2目录下输入命令:tar -jxvf arm-2009q3.tar.bz2 -C /usr/local/arm/
将编译器设置为默认arm编译器: vim /etc/profile
在末尾增加一行: export=$PATH:/usr/local/arm/arm-2009q3/bin
保存退出之后执行:source /etc/profile
或者重启,或者logoout一下,使设置生效。以上设置适合RHEL5,其他linux系统请百度解决。
编译U-boot: make cubieboard CROSS_COMPILE=arm-none-linux-gnueabi-
等待.........
生成三个.bin文件,分别是u-boot.bin和spl目录下的sunxi-spl.bin、u-boot-spl.bin
第1阶段bootloader:sunxi-spl.bin
第2阶段bootloader:u-boot.bin
u-boot-spl.bin我没试过,应该也是第一阶段的bootloader
SD卡准备(我机器上是/dev/sdb),linux下操作:
前面1M给bootloader使用(为什么?要仔细查查资料,目前我还不明白,望高人指点),先清零:
dd if=/dev/zero of=/dev/sdb bs=1M count=1
后面剩余的可以不管,也可分区,具体做法请百度
将u-boot写入,只写入第1阶段bootloader,在u-boot目录操作:
dd if=spl/sunxi-spl.bin of=/dev/sdb bs=1024 seek=8
取下SD卡,插到板子上,上电,minicom有输出如下:
U-Boot SPL 2012.10 (Jan 23 2013 - 21:18:42)
DRAM: 1024MB
SUNXI SD/MMC : 0
然后就死掉了,那是因为没有写入第2阶段,即u-boot.bin。
将u-boot写入,写入第2阶段bootloader,在u-boot目录操作:
dd if=u-boot.bin of=/dev/sdb bs=1024 seek=32
取下SD卡插到板子上,上电,minicom有输出如下:
U-Boot SPL 2012.10 (Jan 24 2013 - 21:42:50)
DRAM: 1024MB
SUNXI SD/MMC: 0
U-Boot 2012.10 (Jan 24 2013 - 21:42:50) Allwinner Technology
CPU: SUNXI Family
Board: Cubieboard
I2C: ready
DRAM: 1 GiB
MMC: SUNXI SD/MMC : 0
*** Warning - bad CRC, using default environment //没做参数文件,使用默认参数
In: serial
Out: serial
Err: serial
start main_loop...Hit any key to stop autoboot: 0
sun4i#
输入ersion命令:
sun4i#version
arm-none-linux-gnueabi-gcc (Sourcery G++ Lite 2009q3-67) 4.4.1
GNU ld (Sourcery G++ Lite 2009q3-67) 2.19.51.20090709
sun4i#
可以看到我使用的编译器是4.4.1版本的,低于原来板子自带u-boot编译器的版本
至此,U-boot的启动SD卡基本制作完成
原文作者:andy 原文链接:http://forum.cubietech.com/forum.php?mod=viewthread&tid=110&extra=page%3D2
