查看: 4242|回复: 3
Cubieboard1智能云计划开启!
发表于 2014-9-2 18:05:48 | 显示全部楼层 |阅读模式
因为前面我跟大家说过,Cb1我不打算继续支持它的CbOS了,所以我决定,拿他当Cloud Server
以前智能家居的帖子我也发了,后面因为手机升级了iOS7,siriproxy不能用了,所以暂停了。
我现在给cb弄了个盒子,准备安装smb,开始计划咯~
这是盒子,本来里面装姜母鸭的:
亮亮的,看到了吗
里面其实有个灯
上面写的是Cubie,用电烙铁切的,万能烙铁,被我拿去焊锡,切亚克力,切塑料,熔松香粘
然后ssh登录,我这是有给cb固定ip的,105
因为以前不玩文件共享,所以这是第一次安装samba:
  • apt-get install samba -y
[color=rgb(46, 166, 255) !important]复制代码
顺便说下,我用mac系统,没法使用这个协议,因此安装另一个软件——vsftpd
  • apt-get install vsftpd -y
我的配置:
  • # Example config file /etc/vsftpd.conf
  • # The default compiled in settings are fairly paranoid. This sample file
  • # loosens things up a bit, to make the ftp daemon more usable.
  • # Please see vsftpd.conf.5 for all compiled in defaults.
  • # READ THIS: This example file is NOT an exhaustive list of vsftpd options.
  • # Please read the vsftpd.conf.5 manual page to get a full idea of vsftpd's
  • # capabilities.
  • # Run standalone?  vsftpd can run either from an inetd or as a standalone
  • # daemon started from an initscript.
  • listen=YES
  • # Run standalone with IPv6?
  • # Like the listen parameter, except vsftpd will listen on an IPv6 socket
  • # instead of an IPv4 one. This parameter and the listen parameter are mutually
  • # exclusive.
  • #listen_ipv6=YES
  • # Allow anonymous FTP? (Beware - allowed by default if you comment this out).
  • anonymous_enable=YES
  • # Uncomment this to allow local users to log in.
  • local_enable=YES
  • # Uncomment this to enable any form of FTP write command.
  • write_enable=YES
  • # Default umask for local users is 077. You may wish to change this to 022,
  • # if your users expect that (022 is used by most other ftpd's)
  • local_umask=077
  • # Uncomment this to allow the anonymous FTP user to upload files. This only
  • # has an effect if the above global write enable is activated. Also, you will
  • # obviously need to create a directory writable by the FTP user.
  • #anon_upload_enable=YES
  • # Uncomment this if you want the anonymous FTP user to be able to create
  • # new directories.
  • #anon_mkdir_write_enable=YES
  • # Activate directory messages - messages given to remote users when they
  • # go into a certain directory.
  • dirmessage_enable=YES
  • # If enabled, vsftpd will display directory listings with the time
  • # in  your  local  time  zone.  The default is to display GMT. The
  • # times returned by the MDTM FTP command are also affected by this
  • # option.
  • use_localtime=YES
  • # Activate logging of uploads/downloads.
  • xferlog_enable=YES
  • # Make sure PORT transfer connections originate from port 20 (ftp-data).
  • connect_from_port_20=YES
  • # If you want, you can arrange for uploaded anonymous files to be owned by
  • # a different user. Note! Using "root" for uploaded files is not
  • # recommended!
  • #chown_uploads=YES
  • #chown_username=whoever
  • # You may override where the log file goes if you like. The default is shown
  • # below.
  • #xferlog_file=/var/log/vsftpd.log
  • # If you want, you can have your log file in standard ftpd xferlog format.
  • # Note that the default log file location is /var/log/xferlog in this case.
  • #xferlog_std_format=YES
  • # You may change the default value for timing out an idle session.
  • #idle_session_timeout=600
  • # You may change the default value for timing out a data connection.
  • #data_connection_timeout=120
  • # It is recommended that you define on your system a unique user which the
  • # ftp server can use as a totally isolated and unprivileged user.
  • #nopriv_user=ftpsecure
  • # Enable this and the server will recognise asynchronous ABOR requests. Not
  • # recommended for security (the code is non-trivial). Not enabling it,
  • # however, may confuse older FTP clients.
  • #async_abor_enable=YES
  • # By default the server will pretend to allow ASCII mode but in fact ignore
  • # the request. Turn on the below options to have the server actually do ASCII
  • # mangling on files when in ASCII mode.
  • # Beware that on some FTP servers, ASCII support allows a denial of service
  • # attack (DoS) via the command "SIZE /big/file" in ASCII mode. vsftpd
  • # predicted this attack and has always been safe, reporting the size of the
  • # raw file.
  • # ASCII mangling is a horrible feature of the protocol.
  • #ascii_upload_enable=YES
  • #ascii_download_enable=YES
  • # You may fully customise the login banner string:
  • #ftpd_banner=Welcome to blah FTP service.
  • # You may specify a file of disallowed anonymous e-mail addresses. Apparently
  • # useful for combatting certain DoS attacks.
  • #deny_email_enable=YES
  • # (default follows)
  • #banned_email_file=/etc/vsftpd.banned_emails
  • # You may restrict local users to their home directories.  See the FAQ for
  • # the possible risks in this before using chroot_local_user or
  • # chroot_list_enable below.
  • chroot_local_user=YES
  • # You may specify an explicit list of local users to chroot() to their home
  • # directory. If chroot_local_user is YES, then this list becomes a list of
  • # users to NOT chroot().
  • # (Warning! chroot'ing can be very dangerous. If using chroot, make sure that
  • # the user does not have write access to the top level directory within the
  • # chroot)
  • #chroot_local_user=YES
  • chroot_list_enable=YES
  • chroot_list_file=/etc/vsftpd.chroot_list
  • # You may activate the "-R" option to the builtin ls. This is disabled by
  • # default to avoid remote users being able to cause excessive I/O on large
  • # sites. However, some broken FTP clients such as "ncftp" and "mirror" assume
  • # the presence of the "-R" option, so there is a strong case for enabling it.
  • #ls_recurse_enable=YES
  • # Customization
  • # Some of vsftpd's settings don't fit the filesystem layout by
  • # default.
  • # This option should be the name of a directory which is empty.  Also, the
  • # directory should not be writable by the ftp user. This directory is used
  • # as a secure chroot() jail at times vsftpd does not require filesystem
  • # access.
  • secure_chroot_dir=/var/run/vsftpd/empty
  • # This string is the name of the PAM service vsftpd will use.
  • pam_service_name=vsftpd
  • # This option specifies the location of the RSA certificate to use for SSL
  • # encrypted connections.
  • rsa_cert_file=/etc/ssl/private/vsftpd.pem
之后可以用user用户登录,账户允许chroot文件:
  • root@cubieboard:~/source_code/cloudserver# cat /etc/vsftpd.chroot_list
  • user
试了下phpmailer,没成功,就是一直卡着,不知道为啥
然后我自己写的ledc程序,用cron启动,每5分钟ping一次谷歌,当然我觉得ping百度更好,因为谷歌有时候不通,通就亮灯,不通灭灯,通过GPIO控制,引入的文件就是gpio的控制文件
  • #include <stdlib.h>
  • #include <stdio.h>
  • #include "gpio_lib.c"
  • #include <string.h>
  • int dy(int port)
  •     //printf("SUNXI GPIO tool\n");
  •     if(SETUP_OK!=sunxi_gpio_init()){
  •         printf("Failed to initialize GPIO\n");
  •         return 1;
  •     if(SETUP_OK!=sunxi_gpio_set_cfgpin(SUNXI_GPD(port),OUTPUT)){
  •         printf("Failed to config GPIO pin\n");
  •         return 1;
  •     if(system("ping google.com -c 1") != 0){
  •         //Is network OK?
  •     printf("No network!\n");
  •     if(sunxi_gpio_output(SUNXI_GPD(port),LOW)){
  •         printf("Failed to set GPIO pin value\n");
  •         return 1;
  •     }else{
  •         printf("Fine!\n");
  •         if(sunxi_gpio_output(SUNXI_GPD(port),HIGH)){
  •             return 1;
  •     sunxi_gpio_cleanup();
  •     return 0;
  • int main(int argc,char* argv[]){
  •     dy(0);
用crontab -e编辑文件,增加:
  •   */5 *   *   *   *    /root/source_code/cloudserver/ledc > /tmp/netlog
好了,大家慢慢玩~
原文作者:tll
原文链接:http://forum.cubietech.com/forum.php?mod=viewthread&tid=1223&extra=page%3D2
  • 签到天数: 31 天
    [LV.5]常住居民I
    发表于 2014-9-3 10:23:03 | 显示全部楼层
    楼主你是 TLL吗? cbOS听说已经不维护了。
     楼主| 发表于 2014-9-3 11:39:32 | 显示全部楼层
    您好,我不是tll,如果您有需要跟tll联系的话,可以直接去我们中文论坛里面的帖子找他哦。“原文链接”就可以转到原始的帖子
  • 签到天数: 31 天
    [LV.5]常住居民I
    发表于 2014-9-6 19:22:48 | 显示全部楼层
    cubieboards 发表于 2014-9-3 11:39
    您好,我不是tll,如果您有需要跟tll联系的话,可以直接去我们中文论坛里面的帖子找他哦。“原文链接”就 ...
    因为前面我跟大家说过,Cb1我不打算继续支持它的CbOS了   因为你说这句话,所以我以为你是TLL。
    GMT+8, 2024-12-22 20:40 , Processed in 0.135580 second(s), 21 queries , MemCache On.
