在U-Boot的官网手册中看到了2个关键的环境变量和1个命令。
bootcmd: This variable defines a command string that is automatically executed
when the initial countdown is not interrupted.
This command is only executed when the variable bootdelay is also defined!
bootargs: The contents of this variable are passed to the Linux kernel as boot
arguments (aka "command line").
run - run commands in an environment variable
bootcmd中的命令就是出现“Hit any key to stop autoboot”提示后,不按任意键,会自动运行的命令。
bootargs是传递给Linux内核的参数。
run是运行环境变量中的命令,bootcmd中包含run命令。
