查看: 5153|回复: 4
STM32F0 #01进程帖(四)——TFT液晶屏显示
  • 签到天数: 1982 天
    [LV.Master]伴坛终老
    发表于 2012-11-10 22:12:42 | 显示全部楼层 |阅读模式
    前段时间一直很忙,今天正好是周末,继续来写点进程吧。
    今天写的主要是TFT液晶屏显示,本次主要是完成了图片显示(如下图中的我们爱板网的图标),并且这个图片可以定义显示的大小和显示的坐标;汉字的显示(“爱”“板”“网”三个字),汉字显示可以定义汉字的显示坐标以及显示的颜色;画线和圆(可以定义线的坐标,颜色,圆的颜色和圆心的坐标,圆的半径);可以显示字符串和数字符号,这些都可以定义字符的颜色和背景色,比如EEbord几个字定义的就是蓝色的背景。
    由于该程序还打算修改,暂时不把整个程序传上来,等以后修改好后在传,目前先把驱动部分发出来。
    void LCD_Init(void)
    LCD_CS_H();
    LCD_WR_H();
    delay_ms(150);
    write_cmd_data(0x0000,0x0001);
    delay_ms(150);
    DeviceCode = LCD_ReadReg(0x0000);  //¶ÁÈ¡ÈκεØÖ·¶¼¿ÉÒÔ
    write_cmd_data(0x0000,0x0000);
    write_cmd_data(0x0001,0x0100);  //ÖðÐÐɨÃ裬Êä³öµÄÒƶ¯·½Ïò´ÓS720µ½S1
    write_cmd_data(0x0002,0x0400);  //Ðе¹ÖÃ
    write_cmd_data(0x0003,0x1030);  //
    write_cmd_data(0x0004,0x0000);  //±ÈÀýËõ·ÅÉèÖ㺲»Ëõ·Å
    write_cmd_data(0x0008, 0x0202); // set the back porch and front porch
      write_cmd_data(0x0009, 0x0000); // set non-display area refresh cycle ISC[3:0]
      write_cmd_data(0x000A, 0x0000); // FMARK function
      write_cmd_data(0x000C, 0x0001); // 16Bit RGB interface setting
      write_cmd_data(0x000D, 0x0000); // Frame marker Position
      write_cmd_data(0x000F, 0x0000); // RGB interface polarity
    delay_ms(50);
    write_cmd_data(0x0007, 0x0101);
    delay_ms(50);
    write_cmd_data(0x10,(1<<12)|(0<<8)|(1<<7)|(1<<6)|(0<<4)); //Power Control 1.(0x16b0)
    write_cmd_data(0x11,0x0007);        //Power Control 2.(0x0001)
    write_cmd_data(0x12,(1<<8)|(1<<4)|(0<<0));    //Power Control 3.(0x0138)
    write_cmd_data(0x13,0x0b00);        //Power Control 4.
    write_cmd_data(0x29,0x0000);        //Power Control 7.
    write_cmd_data(0x2b,(1<<14)|(1<<4));
    write_cmd_data(0x50,0); //Set X Star
      //ˮƽGRAMÖÕֹλÖÃSet X End.
    write_cmd_data(0x51,239); //Set Y Star
    write_cmd_data(0x52,0); //Set Y End.t.
    write_cmd_data(0x53,319); //
    write_cmd_data(0x60,0x2700); //Driver Output Control.
    write_cmd_data(0x61,0x0001); //Driver Output Control.
    write_cmd_data(0x6a,0x0000); //Vertical Srcoll Control.
    write_cmd_data(0x80,0x0000); //Display Position? Partial Display 1.
    write_cmd_data(0x81,0x0000); //RAM Address Start? Partial Display 1.
    write_cmd_data(0x82,0x0000); //RAM Address End-Partial Display 1.
    write_cmd_data(0x83,0x0000); //Displsy Position? Partial Display 2.
    write_cmd_data(0x84,0x0000); //RAM Address Start? Partial Display 2.
    write_cmd_data(0x85,0x0000); //RAM Address End? Partial Display 2.
    write_cmd_data(0x90,(0<<7)|(16<<0)); //Frame Cycle Contral.(0x0013)
    write_cmd_data(0x92,0x0000); //Panel Interface Contral 2.(0x0000)
    write_cmd_data(0x93,0x0001); //Panel Interface Contral 3.
    write_cmd_data(0x95,0x0110); //Frame Cycle Contral.(0x0110)
    write_cmd_data(0x97,(0<<8)); //
    write_cmd_data(0x98,0x0000); //Frame Cycle Contral.
    write_cmd_data(0x07,0x0173); //(0x0173)    ¿ªÏÔʾ
    LCD_BK_ON();//µãÁÁ±³¹â
    LCD_Clear(WHITE);
    void write_cmd(unsigned int cmd)
    LCD_RS_L();
    LCD_CS_L();
    DATAOUT(cmd);
    LCD_WR_L();
    LCD_WR_H();
    LCD_CS_H();
    void write_data(unsigned int data)
    LCD_RS_H();
    LCD_CS_L();
    DATAOUT(data);
    LCD_WR_L();
    LCD_WR_H();
    LCD_CS_H();
    void write_cmd_data(unsigned int cmd,u16 data)
    write_cmd(cmd);
    write_data(data);
    显示汉字所用的取模软件是PCtolcd2002
    图片显示所用的取模软件是Image2lcd
  • 签到天数: 281 天
    发表于 2012-11-10 22:19:45 | 显示全部楼层
    ,哎呀,这个必须顶啊。连logo都画出来了。等代码
  • 签到天数: 1018 天
    发表于 2013-1-12 11:23:57 | 显示全部楼层
    楼主有视频演示没?
  • 签到天数: 1982 天
    [LV.Master]伴坛终老
    发表于 2013-1-13 13:42:37 | 显示全部楼层
    没有做视频,就是照了几张照片
    发表于 2013-8-23 13:49:59 | 显示全部楼层
    有程序下载不
    GMT+8, 2025-1-12 01:44 , Processed in 0.179034 second(s), 25 queries , MemCache On.
