查看: 4354|回复: 1
PIC32MZ的硬件I2C
  • 签到天数: 175 天
    [LV.7]常住居民III
    发表于 2014-8-2 15:51:54 | 显示全部楼层 |阅读模式
    我现在调到PIC32MZ的I2C,本来想用PIC官方的harmony库函数来写一个初始化MPU6050的程序。但试了两三天也不行,无奈之下看了PIC32MZ的I2C参考手册的那部分。写了一个寄存器版的读取MPU6050的程序。当还是有问题。
    我的代码是:
    void I2C1_Init()
        uint32_t actualClock;
        PLIB_I2C_BaudRateSet ( MY_I2C_ID, MY_CLOCK_FREQUENCY, MY_BAUD_RATE);
        actualClock = PLIB_I2C_BaudRateGet ( MY_I2C_ID, MY_CLOCK_FREQUENCY );
        if(abs(actualClock-MY_BAUD_RATE) > MY_BAUD_RATE/10);
            while(1);
        I2C1CONbits.A10M = 0;
        I2C1CONbits.SMEN = 0;
        I2C1CONbits.ON = 1;
    void I2C1_Start()
        I2C1CONbits.SEN = 1;
        while(I2C1STATbits.P);
    void I2C1_SendData(uint8_t Data)
        I2C1TRNbits.I2CTRN = Data;
        while(I2C1STATbits.TBF);
    void I2C1_Stop()
        I2C1CONbits.PEN = 1;
    #define OAR1_ADD0_Set ((uint16_t)0x0001)
    #define OAR1_ADD0_Reset ((uint16_t)0xFFFE)
    void Send7bitsAddress(uint8_t Address,uint8_t I2C_Direction)
        if(I2C_Direction == 0)
            Address |= OAR1_ADD0_Set;
        else
            Address &= OAR1_ADD0_Reset;
        I2C1TRNbits.I2CTRN = Address;
    void I2C_Byte_Write(uint8_t SlaveAddress,uint8_t REG_Address,uint8_t REG_data)
        I2C1_Start();
        Send7bitsAddress(SlaveAddress,1);
        while(I2C1STATbits.R_W);
        I2C1_SendData(REG_Address);
        I2C1_SendData(REG_data);
        I2C1_Stop();
    void MPU_6050_Init(void)
        I2C_Byte_Write(MPU6050_SlaveAddress,PWR_MGMT_1,0x00);
        delay(50000);
        I2C_Byte_Write(MPU6050_SlaveAddress,SMPLRT_DIV,0x07);
        delay(50000);
        I2C_Byte_Write(MPU6050_SlaveAddress,MPU6050_CONFIG,0x06);
        delay(50000);
        I2C_Byte_Write(MPU6050_SlaveAddress,GYRO_CONFIG,0x08);
        delay(50000);
        I2C_Byte_Write(MPU6050_SlaveAddress,ACCEL_CONFIG,0x08);
    int main ( void )
        SYS_DEVCON_PerformanceConfig(SYS_CLK_FREQUENCY);
        I2C1_Init();
        while(1)
           MPU_6050_Init();
       Initialize the application. */
    /* SYS_Initialize(NULL);
        while (true)
            // Maintain the application's state machine.
            SYS_Tasks();
        /* Should not come here during normal operation */
        PLIB_ASSERT(false, "leaving main");
        return (EXIT_FAILURE);
    但总是卡死在了while(1)的那句话,我想也想不明白我已经设置了100K的SCL频率,但还是有超过10%的误差。
    求大神解救呀,希望我的问题能得到解决。
  • 签到天数: 3 天
    发表于 2014-8-19 22:54:31 | 显示全部楼层
    PIC的没用过,帮不了,等大神
    GMT+8, 2024-11-27 13:06 , Processed in 0.121623 second(s), 17 queries , MemCache On.
