查看: 2398|回复: 3
看着觉得arm好难啊 谁帮我看看这个串口收发有没有问题?
  • 签到天数: 980 天
    发表于 2014-5-27 09:27:00 | 显示全部楼层 |阅读模式
    谢谢
    #include "LPC21xx.H"                            /* LPC21xx definitions    */
    extern void init_serial (void);   /* Initialize Serial Interface       */
    extern int  putchar (int ch);    /* Write character to Serial Port   */
    extern int  getchar (void);    /* Read character from Serial Port  */
    void putstr (char *p) {                    /* Write string      */
        while (*p) {
            putchar (*p++);
    void getstr (char *q,int n) {                    /* Write string      */
        for(;n>0;n--)
      *q++=getchar();
    void delay (void) {                        /* Delay function     */
        volatile int i = 0;
    volatile int j = 0;
    for(i = 0; i < 100; ++i)
      for(j = 0; j < 100; ++j)
    int main (void) {
        unsigned int n;
    int snd[32];
        IO1DIR = 0x00FF0000;                      /* P1.16..23 defined as Outputs    */
        init_serial();      /* Initialize Serial Interface     */
    putstr("ARM-GCC Blinky Test!!!\n");
    delay ();
      getstr(snd,18);
  • 签到天数: 980 天
     楼主| 发表于 2014-5-27 09:30:12 | 显示全部楼层
    /*  SERIAL.C:  Low Level Serial Routines        */
    #define CR     0x0D
    void init_serial (void)  {                        /* Initialize Serial Interface                                */
        PINSEL0 = 0x00050000;                                        /* Enable RxD1 and TxD1                              */
        U1LCR = 0x83;                                                /* 8 bits, no Parity, 1 Stop bit                             */
        U1DLL = 97;                                                        /* 9600 Baud Rate @ 15MHz VPB Clock          */
        U1LCR = 0x03;                                                /* DLAB = 0                                                  */
    int putchar (int ch)  {                                /* Write character to Serial Port                    */
        if (ch == '\n')  {
            while (!(U1LSR & 0x20));
            U1THR = CR;                                                /* output CR                                                 */
        return (U1THR = ch);
    int getchar (void)  {                                        /* Read character from Serial Port                   */
        while (!(U1LSR & 0x01));
        return (U1RBR);
  • 签到天数: 113 天
    [LV.6]常住居民II
    发表于 2014-5-27 09:31:23 | 显示全部楼层
    非常关注,帮顶
  • 签到天数: 980 天
     楼主| 发表于 2016-8-26 11:42:32 | 显示全部楼层
    没有人帮我?
    GMT+8, 2025-1-26 11:23 , Processed in 0.133674 second(s), 21 queries , MemCache On.
