查看: 1865|回复: 0
[原创] 中断向量表写成这样,会有问题吗
  • 签到天数: 1014 天
    发表于 2014-5-23 10:05:45 | 显示全部楼层 |阅读模式
    __Vectors       DCD     __initial_sp              ; Top of Stack
                    DCD     Reset_Handler             ; Reset Handler
                    DCD     Reset_Handler;NMI_Handler               ; NMI Handler
                    DCD     Reset_Handler;HardFault_Handler         ; Hard Fault Handler
                    DCD     Reset_Handler;MemManage_Handler         ; MPU Fault Handler
                    DCD     Reset_Handler;BusFault_Handler          ; Bus Fault Handler
                    DCD     Reset_Handler;UsageFault_Handler        ; Usage Fault Handler
                    DCD      0                         ; Reserved ;;注视掉就跑不起来了,不知道为什么
                    ;DCD     0                         ; Reserved
                    ;DCD     0                         ; Reserved
                    ;DCD     0                         ; Reserved
                    ;DCD     SVC_Handler               ; SVCall Handler
                    ;DCD     DebugMon_Handler          ; Debug Monitor Handler
                    ;DCD     0                         ; Reserved
                    ;DCD     PendSV_Handler            ; PendSV Handler
                    ;DCD     SysTick_Handler           ; SysTick Handler
    整个程序不使用中断,当然,我这么做,只是闲得无聊....
    GMT+8, 2025-1-11 16:52 , Processed in 0.118892 second(s), 15 queries , MemCache On.
