查看: 3172|回复: 3
[原创] 兼容树莓派的Banana Pi
发表于 2014-3-26 18:34:50 | 显示全部楼层 |阅读模式
Banana PI 是为了配合Elastos.org开源OS推广而推出开源硬件平台,Banana PI 是一款比树莓派更强悍的双核Android4.2产品。Banana PI 支持 Android系统,,Debian linux系统,Ubuntu linux系统, Raspberry Pi 系统 cubieboard 系统.
Banana PI 硬件:1Ghz ARM7双核处理器,1GB DDR3内存,千兆以太网口,SATA Socket,流畅运行Android4.2.2。Banana PI M1体积如信用卡大小,轻松运行《雷神之锤三:竞技场》这样的游戏,支持1080P高清视频输出,GPIO兼容Raspberry Pi并直接运行其ROM Image。并兼容Arduino 外围接口板。
CPU
A20 ARM® Cortex™-A7 Dual-Core
GPU
ARM Mali400MP2Complies with OpenGL ES 2.0/1.1
Memory (SDRAM)
1GB DDR3 (shared with GPU)
Onboard Storage
SD (Max. 64GB) / MMC card slot UP to 2T on 2.5 SATA disk
Onboard Network
10/100/1000 Ethernet RJ45 (optional USB WIFI Dongle)
Camera Input
A CSI input connector allows for the connection of a designed camera module
Sound Input
Mic
Video Outputs
HDMI, CVBS , LVDS/RGB
Audio Output
3.5 mm Jack and HDMI
Power Source
5 volt via MicroUSB(DC In Only) and/or MicroUSB (OTG)
USB 2.0 Ports
2 (direct from Allwinner A20 chip)
Buttons
Reset button: Next to MicroUSB connector
Power button: Next to Reset button
UBoot button (optional): Behind HDMI connector
GPIO(2X13) pin
GPIO,UART,I2C bus,SPI bus with two chip selects,
CAN bus,ADC,PWM,+3.3v,+5v,ground.
LED
Power Status LED (Red)
Ethernet Status LED (Blue)
User Define LED (Green)
Remote
IR
Supported OS
Android Android 4.4 Debian Ubuntu RaspberryPi
www.banana-pi.org
QQ:812214783
    难过
    2014-3-27 11:05
    发表于 2014-3-27 11:10:37 | 显示全部楼层
    顶一下,Banana PI !!
  • 签到天数: 581 天
    发表于 2014-3-27 11:19:24 | 显示全部楼层
    多少钱啊,有人民币售价吗。
  • 签到天数: 886 天
    发表于 2014-3-27 13:24:33 | 显示全部楼层
    很有意思!
    GMT+8, 2024-11-19 13:34 , Processed in 0.143842 second(s), 24 queries , MemCache On.
