查看: 2153|回复: 0
4×4 keypad For pcDuino
发表于 2014-3-25 10:51:29 | 显示全部楼层 |阅读模式
键盘是人机对话不可缺少的组件之一,在按键比较少时,我们可以一个pcDuino的I/O口接一个按键,但当按键需要很多,而pcDuino的I/O资源又比较紧张时,使用矩阵式键盘无疑是最好的选择。下面来介绍如何在pcDuino上使用4×4矩阵键盘。
一、硬件清单:
  • pcDuino V2       x1
  • 4×4 keyboard   x1
  • Wire                  x8
  • 二、接线说明
  • 三、测试代码:
#include "core.h"
int rowpins[4] = {2,3,4,5};
int colpins[4] = {6,7,8,9};
int key_value=0x00;
int row_value=0,col_value=0;
void clean_pins(int p[])
  for(int i=0;i<4;i++)
    pinMode(p,OUTPUT);
    digitalWrite(p,HIGH);
void SetPinMode(int p[],int mode)
    pinMode(p,mode);
    if(mode==OUTPUT)
      digitalWrite(p,LOW);
int ReadPin(int p[])
  int value=0;
  int pin=0;
    pin = digitalRead(p);
    if(pin == 0)
      delay(50);
      if(pin == 0)
        if(i==0) value = 0x01;
        if(i==1) value = 0x02;
        if(i==2) value = 0x04;
        if(i==3) value = 0x08;
  return value;
void ReadRow()
  row_value = 0;
  SetPinMode(rowpins,OUTPUT);
  clean_pins(colpins);
  SetPinMode(colpins,INPUT);
  row_value = ReadPin(colpins);
void ReadCol()
  col_value = 0;
  SetPinMode(colpins,OUTPUT);
  clean_pins(rowpins);
  SetPinMode(rowpins,INPUT);
  col_value = ReadPin(rowpins);
void setup()
    printf("4x4 keypad test:\n");
void loop()
   char key;
   ReadRow();
   if(row_value!=0)
     delay(20);
     ReadCol();
     key_value = (row_value<<4) + col_value;
     switch(key_value)
       case 0x11: key = '1' ; break;
       case 0x21: key = '2' ; break;
       case 0x41: key = '3' ; break;
       case 0x81: key = 'A' ; break;
       case 0x12: key = '4' ; break;
       case 0x22: key = '5' ; break;
       case 0x42: key = '6' ; break;
       case 0x82: key = 'B' ; break;
       case 0x14: key = '7' ; break;
       case 0x24: key = '8' ; break;
       case 0x44: key = '9' ; break;
       case 0x84: key = 'C' ; break;
       case 0x18: key = '*' ; break;
       case 0x28: key = '0' ; break;
       case 0x48: key = '#' ; break;
       case 0x88: key = 'D' ; break;
       default : 0x00;
     if(key!=0x00)
       printf("key value = %c\n+++++++++\n",key);
       //delay(100);
  • 四、测试运行:(1)按照接线图接线: 图片20140325104938.jpg
  • (2)打开Arduino IDE,输入测试代码: 图片418.png
  • (3)编译运行代码,按下任意按键,在终端可以看到打印的键值: 图片517.png
GMT+8, 2024-12-21 21:02 , Processed in 0.117046 second(s), 16 queries , MemCache On.
