查看: 2872|回复: 0
Usb HOST口 识别的 OTG usb hub
    无聊
    2014-2-27 20:09
  • 签到天数: 2 天
    发表于 2014-2-27 19:59:53 | 显示全部楼层 |阅读模式
    root@clanton:~#
    [  239.180479] usb 2-1: new high-speed USB device number 2 using ehci-pci
    [  239.361884] hub 2-1:1.0: USB hub found
    [  239.371424] hub 2-1:1.0: 4 ports detected
    [  239.670677] usb 2-1.4: new high-speed USB device number 3 using ehci-pci
    [  239.833244] scsi0 : usb-storage 2-1.4:1.0
    [  240.877604] scsi 0:0:0:0: Direct-Access     USB Mass  Storage Device       PQ: 0 ANSI: 0 CCS
    [  240.995108] sd 0:0:0:0: [sda] Attached SCSI removable disk
    [  241.006523] sd 0:0:0:0: Attached scsi generic sg0 type 0
    这下方便多了,省区了好多转接头
    GMT+8, 2024-12-21 18:54 , Processed in 0.114923 second(s), 16 queries , MemCache On.
