查看: 4138|回复: 9
[入门] 这样的门禁你见过没?
    郁闷
    2024-10-28 10:11
  • 签到天数: 1703 天
    [LV.Master]伴坛终老
    发表于 2012-10-16 12:11:27 | 显示全部楼层 |阅读模式
    看代码:
    1. #include <Password.h>
    2. #include <LiquidCrystal.h>
    3. #include <Keypad.h>
    4. LiquidCrystal lcd(2,3,4,9,10,11,12);
    5. Password password = Password( "4321" );
    6. const byte ROWS = 4; // Four rows
    7. const byte COLS = 3; // Three columns
    8. // Define the Keymap
    9. char keys[ROWS][COLS] = {
    10.   {'1','2','3',},
    11.   {'4','5','6',},
    12.   {'7','8','9',},
    13.   {'*','0',' ',}
    14. };
    15. // Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
    16. byte rowPins[ROWS] = {25, 24, 23, 22}; //connect to the row pinouts of the keypad
    17. byte colPins[COLS] = {28, 27, 26}; //connect to the column pinouts of the keypad
    18. const int buttonPin = 7;
    19. int buttonState = 0;
    20. // Create the Keypad
    21. Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
    22. #define ledPin 13
    23. void setup(){
    24.    pinMode(buttonPin, INPUT);
    25. lcd.begin(16, 2);
    26. digitalWrite(ledPin, LOW); // sets the LED on
    27. Serial.begin(9600);
    28. keypad.addEventListener(keypadEvent); //add an event listener for this keypad
    29. keypad.setDebounceTime(250);
    30. }
    31. void loop(){
    32. keypad.getKey();
    33. buttonState = digitalRead(buttonPin);
    34. if (buttonState == HIGH) {
    35. lcd.clear();
    36. }
    37. }
    38. //take care of some special events
    39. void keypadEvent(KeypadEvent eKey){
    40. switch (keypad.getState()){
    41. case PRESSED:
    42. lcd.print(eKey);
    43. switch (eKey){
    44. case ' ': guessPassword(); break;
    45. default:
    46. password.append(eKey);
    47. }
    48. }}
    49. void guessPassword(){
    50. if (password.evaluate()){
    51. digitalWrite(ledPin,HIGH); //activates garaged door relay
    52. delay(500);
    53. digitalWrite(ledPin,LOW); //turns off door relay after .5 sec
    54. lcd.print("VALID PASSWORD "); //
    55. password.reset(); //resets password after correct entry
    56. delay(600);
    57. lcd.print("Welcome");
    58. delay(2000);
    59. lcd.clear();
    60. }
    61. else{
    62. digitalWrite(ledPin,LOW);
    63. lcd.print("INVALID PASSWORD ");
    64. password.reset(); //resets password after INCORRECT entry
    65. delay(600);
    66. lcd.clear();
    67. }
    68. }
    用到的库在这里:https://docs.google.com/folder/d/0B8GceIlOmvRoNWZmNWExYTMtYjVmNS00MzE5LWFlMWQtNDM3MTY1MTcyZTUx/edit?hl=en_US&pli=1
  • 签到天数: 1018 天
    发表于 2012-10-16 13:21:27 | 显示全部楼层
    板子用的什么啊?
    郁闷
    2024-10-28 10:11
  • 签到天数: 1703 天
    [LV.Master]伴坛终老
    发表于 2012-10-16 13:38:56 | 显示全部楼层
    xinxincaijq 发表于 2012-10-16 13:21
    板子用的什么啊?
    arduino,不知用chipKIT是不是也可以呢
  • 签到天数: 26 天
    [LV.4]偶尔看看III
    发表于 2012-10-25 20:23:34 | 显示全部楼层
    呵呵,比较简单
  • 签到天数: 1341 天
    发表于 2012-10-25 23:47:10 | 显示全部楼层
    哇 佩服佩服
    无聊
    2016-12-20 15:08
  • 签到天数: 510 天
    发表于 2012-10-27 11:26:43 | 显示全部楼层
    呵呵,以前也做过
    擦汗
    2020-3-19 13:22
  • 签到天数: 805 天
    发表于 2012-12-24 20:10:41 | 显示全部楼层
    观摩一下!!!
  • 签到天数: 1730 天
    [LV.Master]伴坛终老
    发表于 2013-10-8 11:22:57 | 显示全部楼层
    还是头一次见到...
  • 签到天数: 430 天
    发表于 2013-11-20 17:19:33 | 显示全部楼层
    没见过,看起来很牛逼的说
  • 签到天数: 295 天
    发表于 2014-1-2 22:18:31 | 显示全部楼层
    赞一个~~~~~~~~~~~~~~··
    GMT+8, 2024-12-21 16:36 , Processed in 0.198695 second(s), 32 queries , MemCache On.
