查看: 2309|回复: 0
[资料] 飞凌分享:Android之Touch事件分发机制
  • 签到天数: 5 天
    发表于 2014-1-24 08:40:57 | 显示全部楼层 |阅读模式
    欢迎大家来到飞凌爱板网专区,对嵌入式技术感兴趣的朋友不妨多多关注一下,我们提供了公司所有开发板的所有资料,也会更新大量技术文章,欢迎大家一块学习提高!!!
    直接进入正题,在android开发中,手势触碰是经常使用到的。这两天刚好在看这方面的资料,在这里写篇文章做个小总结。
    首先必须知道五大布局LayoutLineaLayoutRelativeLayoutFrameLayoutAbsoluteLayout都继承自ViewGroup,而TableLayout继承LinearLayout,也相当于继承于ViewGroup
    ViewGroup继承自View
    而我们最终在屏幕上显示控制的控件如TextViewButton等都直接或间接继承自View
    View中有两个方法参与到Touch事件分发
    onDispatchTouchEvent(MotionEvent event)onTouch(MotionEvent event)
    ViewGroup有三个方法参与到Touch事件分发
    onDispatchTouchEvent(MotionEvent event)onInterceptTouchEvent(MotionEvent ev)onTouch(MotionEvent event)
    当我们手指出门屏幕,手势事件最早被传递到Layout布局的dispatchTouchEvent,即ViewGroupdispatchTouchEvent
    1 public boolean dispatchTouchEvent(MotionEvent ev) {
    2     final int action = ev.getAction();
    3     final float xf = ev.getX();
    4     final float yf = ev.getY();
    5     final float scrolledXFloat = xf + mScrollX;
    6     final float scrolledYFloat = yf + mScrollY;
    7     final Rect frame = mTempRect;
    8     boolean disallowIntercept = (mGroupFlags & FLAG_DISALLOW_INTERCEPT) != 0;
    9     if (action == MotionEvent.ACTION_DOWN) {
    10         if (mMotionTarget != null) {
    11             mMotionTarget = null;
    12         }
    13         if (disallowIntercept || !onInterceptTouchEvent(ev)) {
    14             ev.setAction(MotionEvent.ACTION_DOWN);
    15             final int scrolledXInt = (int) scrolledXFloat;
    16             final int scrolledYInt = (int) scrolledYFloat;
    17             final View[] children = mChildren;
    18             final int count = mChildrenCount;
    19             for (int i = count - 1; i >= 0; i--) {
    20                 final View child = children;
    21                 if ((child.mViewFlags & VISIBILITY_MASK) == VISIBLE
    22                         || child.getAnimation() != null) {
    23                     child.getHitRect(frame);
    24                     if (frame.contains(scrolledXInt, scrolledYInt)) {
    25                         final float xc = scrolledXFloat - child.mLeft;
    26                         final float yc = scrolledYFloat - child.mTop;
    27                         ev.setLocation(xc, yc);
    28                         child.mPrivateFlags &= ~CANCEL_NEXT_UP_EVENT;
    29                         if (child.dispatchTouchEvent(ev))  {
    30                             mMotionTarget = child;
    31                             return true;
    32                         }
    33                     }
    34                 }
    35             }
    36         }
    37     }
    38     boolean isUpOrCancel = (action == MotionEvent.ACTION_UP) ||
    39             (action == MotionEvent.ACTION_CANCEL);
    40     if (isUpOrCancel) {
    41         mGroupFlags &= ~FLAG_DISALLOW_INTERCEPT;
    42     }
    43     final View target = mMotionTarget;
    44     if (target == null) {
    45         ev.setLocation(xf, yf);
    46         if ((mPrivateFlags & CANCEL_NEXT_UP_EVENT) != 0) {
    47             ev.setAction(MotionEvent.ACTION_CANCEL);
    48             mPrivateFlags &= ~CANCEL_NEXT_UP_EVENT;
    49         }
    50         return super.dispatchTouchEvent(ev);
    51     }
    52     if (!disallowIntercept && onInterceptTouchEvent(ev)) {
    53         final float xc = scrolledXFloat - (float) target.mLeft;
    54         final float yc = scrolledYFloat - (float) target.mTop;
    55         mPrivateFlags &= ~CANCEL_NEXT_UP_EVENT;
    56         ev.setAction(MotionEvent.ACTION_CANCEL);
    57         ev.setLocation(xc, yc);
    58         if (!target.dispatchTouchEvent(ev)) {
    59         }
    60         mMotionTarget = null;
    61         return true;
    62     }
    63     if (isUpOrCancel) {
    64         mMotionTarget = null;
    65     }
    66     final float xc = scrolledXFloat - (float) target.mLeft;
    67     final float yc = scrolledYFloat - (float) target.mTop;
    68     ev.setLocation(xc, yc);
    69     if ((target.mPrivateFlags & CANCEL_NEXT_UP_EVENT) != 0) {
    70         ev.setAction(MotionEvent.ACTION_CANCEL);
    71         target.mPrivateFlags &= ~CANCEL_NEXT_UP_EVENT;
    72         mMotionTarget = null;
    73     }
    74     return target.dispatchTouchEvent(ev);
    75 }
                                return true;
        if (isUpOrCancel) {
            return true;
        if (isUpOrCancel) {
    此段代码较长,挑重点看,第9行,但是ACTION_DOWN事件时,会进入到第13行的判断,第一个参数disallowIntercept是指是否禁用掉事件拦截的功能,默认是false,也可以通过调用requestDisallowInterceptTouchEvent方法对这个值进行修改。而第二个参数!onInterceptTouchEvent(ev)即是否进行拦截的判断,如果我们不复写这个方法,默认为false,就会进入if判断,并获得点击区域有的view,在第29行将手势事件传递给被点击到的view,如果view的dispatchTouchEvent(ev)返回true,表示手势事件被这个view消费了(view的dispatchTouchEvent后续分析),并把该view置给mMotionTarget后返回true。这里,正是因为有view消费了ACTION_DOWN事件,使得当后续的ACTION_MOVE ACTION_UP传递到这个ViewGroup的时候,mMotionTarget不为空,使得47行的target不为空,最后都会执行74行的target.dispatchTouchEvent(ev),即ACTION_DOWN事件被哪个view的onTouch或者onTouchEvent返回了true,那么后续的ACTION_MOVE,ACTION_UP事件将会直接传递给这个view执行。(onTouch和onTouchEvent后续分析)
    继续分析这个ViewGroup的dispatchTouchEvent,如果13行的onInterceptTouchEvent被我们复写返回true代表ACTION_DOWN被这个ViewGroup拦截下来,将不会进入if判断,因此mMotionTarget将为null使得target也为null,最后执行了50行的super.dispatchTouchEvent即ViewGroup的父类View的dispatchTouchEvent。并在其中调用onTouch或者onTouchEvent。
    如果我们不复写onInterceptTouchEvent让其进入if判断,但如果child的dispatchTouchEvent返回的是false,表示child没有把这个事件消费了,最终也还是调用了50行的super.dispatchTouchEvent(ev)。
    现在再来看看上面分析中经常说到的View的dispatchTouchEvent
    76 public boolean dispatchTouchEvent(MotionEvent event) {
    77     if (mOnTouchListener != null && (mViewFlags & ENABLED_MASK) == ENABLED &&
    78             mOnTouchListener.onTouch(this, event)) {
    79         return true;
    80     }
    81     return onTouchEvent(event);
    82 }
            return true;
    非常简短的几行代码,是不是比看了ViewGroup的dispatchTouchEvent轻松多了!
    首先先判断mOnTouchListener是否为空,这个mOnTouchListener是啥呢,看下源码就知道了
    83 public void setOnTouchListener(OnTouchListener l) {
    84     mOnTouchListener = l;
    85 }
    显然,就是我们设置OnTouchListener的接口实例,并在其中复写了onTouch方法。
    if判断的第二个参数用来判断当前view是否是enable为状态。而第三个参数就是我们复写的onTouch方法了,当我们返回了true,这个view的dispatchtouchEvent将返回true,从而使得调用这个dispatchTouchEvent的ViewGroup的dispatchTouchEvent确定了mMotionTarget,确定了消费了ACTION_DOWN事件的view。
    而如果我们没有设置OnTouchEvent接口或者onTouch返回false则调用了onTouchEvent。
    继续看下view的onTouchEvent
    86 public boolean onTouchEvent(MotionEvent event) {
    87     final int viewFlags = mViewFlags;
    88     if ((viewFlags & ENABLED_MASK) == DISABLED) {
    89         // A disabled view that is clickable still consumes the touch
    90         // events, it just doesn't respond to them.
    91         return (((viewFlags & CLICKABLE) == CLICKABLE ||
    92                 (viewFlags & LONG_CLICKABLE) == LONG_CLICKABLE));
    93     }
    94     if (mTouchDelegate != null) {
    95         if (mTouchDelegate.onTouchEvent(event)) {
    96             return true;
    97         }
    98     }
    99     if (((viewFlags & CLICKABLE) == CLICKABLE ||
    100             (viewFlags & LONG_CLICKABLE) == LONG_CLICKABLE)) {
    101         switch (event.getAction()) {
    102             case MotionEvent.ACTION_UP:
    103                 boolean prepressed = (mPrivateFlags & PREPRESSED) != 0;
    104                 if ((mPrivateFlags & PRESSED) != 0 || prepressed) {
    105                     // take focus if we don't have it already and we should in
    106                     // touch mode.
    107                     boolean focusTaken = false;
    108                     if (isFocusable() && isFocusableInTouchMode() && !isFocused()) {
    109                         focusTaken = requestFocus();
    110                     }
    111                     if (!mHasPerformedLongPress) {
    112                         // This is a tap, so remove the longpress check
    113                         removeLongPressCallback();
    114                         // Only perform take click actions if we were in the pressed state
    115                         if (!focusTaken) {
    116                             // Use a Runnable and post this rather than calling
    117                             // performClick directly. This lets other visual state
    118                             // of the view update before click actions start.
    119                             if (mPerformClick == null) {
    120                                 mPerformClick = new PerformClick();
    121                             }
    122                             if (!post(mPerformClick)) {
    123                                 performClick();
    124                             }
    125                         }
    126                     }
    127                     if (mUnsetPressedState == null) {
    128                         mUnsetPressedState = new UnsetPressedState();
    129                     }
    130                     if (prepressed) {
    131                         mPrivateFlags |= PRESSED;
    132                         refreshDrawableState();
    133                         postDelayed(mUnsetPressedState,
    134                                 ViewConfiguration.getPressedStateDuration());
    135                     } else if (!post(mUnsetPressedState)) {
    136                         // If the post failed, unpress right now
    137                         mUnsetPressedState.run();
    138                     }
    139                     removeTapCallback();
    140                 }
    141                 break;
    142             case MotionEvent.ACTION_DOWN:
    143                 if (mPendingCheckForTap == null) {
    144                     mPendingCheckForTap = new CheckForTap();
    145                 }
    146                 mPrivateFlags |= PREPRESSED;
    147                 mHasPerformedLongPress = false;
    148                 postDelayed(mPendingCheckForTap, ViewConfiguration.getTapTimeout());
    149                 break;
    150             case MotionEvent.ACTION_CANCEL:
    151                 mPrivateFlags &= ~PRESSED;
    152                 refreshDrawableState();
    153                 removeTapCallback();
    154                 break;
    155             case MotionEvent.ACTION_MOVE:
    156                 final int x = (int) event.getX();
    157                 final int y = (int) event.getY();
    158                 // Be lenient about moving outside of buttons
    159                 int slop = mTouchSlop;
    160                 if ((x < 0 - slop) || (x >= getWidth() + slop) ||
    161                         (y < 0 - slop) || (y >= getHeight() + slop)) {
    162                     // Outside button
    163                     removeTapCallback();
    164                     if ((mPrivateFlags & PRESSED) != 0) {
    165                         // Remove any future long press/tap checks
    166                         removeLongPressCallback();
    167                         // Need to switch from pressed to not pressed
    168                         mPrivateFlags &= ~PRESSED;
    169                         refreshDrawableState();
    170                     }
    171                 }
    172                 break;
    173         }
    174         return true;
    175     }
    176     return false;
    177 }
                return true;
                        // touch mode.
                            if (!focusTaken) {
                                    performClick();
                        if (prepressed) {
                    break;
                    break;
                    break;
                        // Outside button
                    break;
            return true;
        return false;
    这段代码同样很长,同样挑重点看。
    第14行当这个view是可点击的就会进入if判断,否则直接返回false,因此很有可能这个onTouchEvent的代码如果在第14行进入了if判断,很可能里面会有点击事件的执行。我们往下看,第38行执行ACTION_UP手势时,执行的performClick
    178 public boolean performClick() {
    179     sendAccessibilityEvent(AccessibilityEvent.TYPE_VIEW_CLICKED);
    180     if (mOnClickListener != null) {
    181         playSoundEffect(SoundEffectConstants.CLICK);
    182         mOnClickListener.onClick(this);
    183         return true;
    184     }
    185     return false;
    186 }
            return true;
        return false;
    没错,performClick确实执行了mOnClickListener.onClikc(this);就是执行我们设置的onClick事件。并且在onTouchEvent的89行返回了true。
    在这部分分析中我们也发现了一个小秘密,如果我们复写了onTouchListener中的onTouch让它返回false,这样dispatchTouchEvent将不会执行到onTouchEvent方法,使得onClick事件永远得不到执行。
    好了,全部分析完毕,做几点小总结
    1、onTouch优先于onTouchEvent执行,且onTouch返回true将不执行onTouchEvent,并导致onTouchEvent里的点击事件得不到执行
    2、手势事件从最外部的ViewGroup的dispatchTouchEvent开始分发,如果onInterceptTouchEvent拦截了该手势事件,即返回true,手势事件将不会往下分发,即不执行view的dispatchTouchEvent,而是让该ViewGroup的的父类dispatchTouchEvent来消费该手势事件。
    3、如果View的dispatchTouchEvent消费了ACTION_DOWN事件,即对ACTION_DOWN返回true,后续的的ACTION_MOVE和ACTION_UP将直接被分发到这个view来消费。
    GMT+8, 2025-1-11 19:50 , Processed in 0.118186 second(s), 15 queries , MemCache On.
