查看: 4339|回复: 2
在pcDuino上使用1602 LCD
发表于 2014-1-17 16:50:05 | 显示全部楼层 |阅读模式
LCD 1602 液晶也叫LCD1602 字符型液晶,它是一种专门用来显示字母,数字,符号等的点阵型液晶模块。
一:实验器件
1.pcDuino实验平台
2.LCD1602液晶模块:1
3.可调电位器:1
4.导线
5.面包板:1
二:连接图
具体关系对应下:
1 LCD模块的D4(也就是接口11连到 pcDuino D4(数字4
2 LCD模块的D5(也就是接口12连到 pcDuino D5(数字5
3 LCD模块的D6(也就是接口13连到 pcDuino D6(数字6
4 LCD模块的D7(也就是接口14连到 pcDuino D7(数字7
5 LCD模块的RS(也就是接口4连到 pcDuino D8(数字8
6 LCD模块的E(也就是接口6连到 pcDuino D9(数字9
7 可调电位器我选用的是三孔的,插在面包板的26-28这个位置,同时分别连接两根导线,一根插正极,一根插负极
8 LCD接口3我连接在面包板的27号位置
9 面包板1-2接口(1连接负极,2连接正极)
10 面包板5接口插负极
11 面包板15号连接正极,16号插负极
12 在正负极上连接两根导线,正极连接pcDuino5V,负极连接pcDuinoGND
三:输入代码
打开Arduino IDE ,代码如下:
#include "core.h"
#define RS 8
#define EN 9
#define backlight 10
#define RS_L digitalWrite(RS,LOW)
#define RS_H digitalWrite(RS,HIGH)
#define EN_L digitalWrite(EN,LOW)
#define EN_H digitalWrite(EN,HIGH)
int DB[] = {7,6,5,4};
void write_command(int command)
int i,temp;
RS_L;
EN_L;
temp=command & 0xf0;
for (i=0; i < 4; i++)
if(temp&0x80)
digitalWrite(DB,HIGH);
else digitalWrite(DB,LOW);
temp <<= 1;
delayMicroseconds(10);
EN_H;
delay(1);
EN_L;
temp=(command & 0x0f)<<4;
if(temp&0x80)
temp <<= 1;
EN_H;
delay(1);
EN_L;
void write_data(int dat)
int i=0,temp;
RS_H;
EN_L;
temp=dat & 0xf0;
if(temp&0x80)
temp <<= 1;
EN_H;
delay(1);
EN_L;
temp=(dat & 0x0f)<<4;
if(temp&0x80)
temp <<= 1;
EN_H;
delay(1);
EN_L;
void LCD_write_char( int x,int y,int dat)
int address;
if (x ==0) address = 0x80 + y;
else address = 0xC0 + y;
write_command(address);
write_data(dat);
void lcd1602_init()
int i = 0;
pinMode(RS,OUTPUT);
pinMode(EN,OUTPUT);
pinMode(backlight,OUTPUT);
digitalWrite(backlight,HIGH);
pinMode(DB,OUTPUT);
delay(100);
write_command(0x28);
delay(50);
write_command(0x06);
delay(50);
write_command(0x0c);
delay(50);
write_command(0x80);
delay(50);
write_command(0x01);
delay(100);
void setup (void)
lcd1602_init();
void loop (void)
write_command(0x02);
LCD_write_char(0,2,'W');
LCD_write_char(0,3,'e');
LCD_write_char(0,4,'l');
LCD_write_char(0,5,'c');
LCD_write_char(0,6,'o');
LCD_write_char(0,7,'m');
LCD_write_char(0,8,'e');
LCD_write_char(0,10,'t');
LCD_write_char(0,11,'o');
LCD_write_char(1,4,'p');
LCD_write_char(1,5,'c');
LCD_write_char(1,6,'D');
LCD_write_char(1,7,'u');
LCD_write_char(1,8,'i');
LCD_write_char(1,9,'n');
LCD_write_char(1,10,'o');
//while(1)
delay(100);
四:实验结果
哈哈 大功告成 要是想要换其他字母或者数字可以直接在代码里面改哦!
发表于 2014-1-17 19:45:38 | 显示全部楼层
赞一个
发表于 2014-1-22 13:15:37 | 显示全部楼层
不错啊,受教了,自己试一下
GMT+8, 2024-12-21 18:05 , Processed in 0.153618 second(s), 22 queries , MemCache On.
