查看: 5944|回复: 2
发一个arduino的pid电机调速
  • 签到天数: 287 天
    发表于 2013-12-27 14:29:00 | 显示全部楼层 |阅读模式
    程序:
    #include <SoftwareSerial.h>
    // define some constants
    int ActPos = A0;    // select the input pin for feedback signal
    int DesPos = A1;    // select the input pin for control signal
    byte PWMOutput;
    long Error[10];
    long Accumulator;
    long PID;
    int PTerm;
    int ITerm;
    int DTerm;
    byte Divider;
    The FIRSTBOT has a PIC16F1829 controller that controls the
    two MC33926 H-bridges on the board.  A oftware serial interface
    is used to control that part.
    SoftwareSerial mySerial(2, 3); // Receive data on 2, send data on 3
    byte SerialTXBuffer[5];
    byte SerialRXBuffer[5];
    void setup()
    // Open serial communications and wait for port to open:
      Serial.begin(9600);
      mySerial.begin(9600);
    /* GetError():
    Read the analog values, shift the Error array down
    one spot, and load the new error value into the
    top of array.
    void GetError(void)
      byte i = 0;
      // read analogs
      word ActualPosition = analogRead(ActPos);
    // comment out to speed up PID loop
    //  Serial.print("ActPos= ");
    //  Serial.println(ActualPosition,DEC);
      word DesiredPosition = analogRead(DesPos);
    //  Serial.print("DesPos= ");
    //  Serial.println(DesiredPosition,DEC);
      // shift error values
      for(i=0;i<10;i++)
        Error[i+1] = Error;
      // load new error into top array spot
      Error[0] = (long)DesiredPosition-(long)ActualPosition;
    //  Serial.print("Error= ");
    //  Serial.println(Error[0],DEC);
    /* CalculatePID():
    Error[0] is used for latest error, Error[9] with the DTERM
    void CalculatePID(void)
    // Set constants here
      PTerm = 2000;
      ITerm = 25;
      DTerm = 0;
      Divider = 10;
    // Calculate the PID
      PID = Error[0]*PTerm;     // start with proportional gain
      Accumulator += Error[0];  // accumulator is sum of errors
      PID += ITerm*Accumulator; // add integral gain and error accumulation
      PID += DTerm*(Error[0]-Error[9]); // differential gain comes next
      PID = PID>>Divider; // scale PID down with divider
    //Serial.print("PID= ");
    //  Serial.println(PID,DEC);
    // limit the PID to the resolution we have for the PWM variable
      if(PID>=127)
        PID = 127;
      if(PID<=-126)
        PID = -126;
    //PWM output should be between 1 and 254 so we add to the PID
      PWMOutput = PID + 127;
    //  Serial.print("PWMOutput= ");
    //  Serial.println(PWMOutput,DEC);
    /* WriteRegister():
    Writes a single byte to the PIC16F1829,
    "Value" to the register pointed at by "Index".
    Returns the response
    byte WriteRegister(byte Index, byte Value)
    byte i = 0;
    byte checksum = 0;
    byte ack = 0;
    SerialTXBuffer[0] = 210;
    SerialTXBuffer[1] = 1;
    SerialTXBuffer[2] = 3;
    SerialTXBuffer[3] = Index;
    SerialTXBuffer[4] = Value;
    for (i=0;i<6;i++)
      if (i!=5)
        mySerial.write(SerialTXBuffer);
        checksum += SerialTXBuffer;
      else
        mySerial.write(checksum);
      delay(5);
      if (mySerial.available())
        ack = mySerial.read();
      return ack;
    void loop() // run over and over
         GetError();       // Get position error
         CalculatePID();   // Calculate the PID output from the error
         WriteRegister(9,PWMOutput);  // Set motor speed
    接线图:
    集成arduino的电机驱动板RIRSTBOT的原理图详见如下。
    SCHEMATIC_FIRSTBOT_ATMEL_1.pdf
    19.22 KB, 下载次数: 14
    原理图uno部分
    SCHEMATIC_FIRSTBOT_MCHIP_2.pdf
    21.4 KB, 下载次数: 17
    原理图电机驱动部分
  • 签到天数: 16 天
    [LV.4]偶尔看看III
    发表于 2013-12-27 18:32:46 | 显示全部楼层
    赞,有没有做的成品实物?
  • 签到天数: 287 天
     楼主| 发表于 2013-12-27 19:29:20 | 显示全部楼层
    这个是国外的一个开源项目。原文地址:http://blog.solutions-cubed.com/pid-motor-control-with-an-arduino/  版主能申精不?
    GMT+8, 2024-12-25 03:48 , Processed in 0.136651 second(s), 20 queries , MemCache On.
