查看: 490|回复: 0
[评测分享] 【Avnet | NXP FRDM-MCXN947试用活动】移植FreeRTOS并驱动LED计数
  • 签到天数: 1078 天
    发表于 2024-12-4 15:35:41 | 显示全部楼层 |阅读模式
    这篇移植FreeRTOS并驱动LED计数。
    一、下载FreeRTOS源码
    下载地址:https://www.freertos.org/
    我下载的是以下版本。
    二、添加文件到工程
    添加下载的FreeRTOS文件到项目中
    三、程序代码
    3.1、FreeRTOSConfig.h
    1. /*
    2. * FreeRTOS V202212.01
    3. * Copyright (C) 2020 Amazon.com, Inc. or its affiliates.  All Rights Reserved.
    4. *
    5. * Permission is hereby granted, free of charge, to any person obtaining a copy of
    6. * this software and associated documentation files (the "Software"), to deal in
    7. * the Software without restriction, including without limitation the rights to
    8. * use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
    9. * the Software, and to permit persons to whom the Software is furnished to do so,
    10. * subject to the following conditions:
    11. *
    12. * The above copyright notice and this permission notice shall be included in all
    13. * copies or substantial portions of the Software.
    14. *
    15. * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
    16. * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
    17. * FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
    18. * COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
    19. * IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
    20. * CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    21. *
    22. * https://www.FreeRTOS.org
    23. * https://github.com/FreeRTOS
    24. *
    25. */
    26. #ifndef FREERTOS_CONFIG_H
    27. #define FREERTOS_CONFIG_H
    28. /*-----------------------------------------------------------
    29. * Application specific definitions.
    30. *
    31. * These definitions should be adjusted for your particular hardware and
    32. * application requirements.
    33. *
    34. * THESE PARAMETERS ARE DESCRIBED WITHIN THE 'CONFIGURATION' SECTION OF THE
    35. * FreeRTOS API DOCUMENTATION AVAILABLE ON THE FreeRTOS.org WEB SITE.
    36. *
    37. * See http://www.freertos.org/a00110.html.
    38. *----------------------------------------------------------*/
    39. /* Ensure definitions are only used by the compiler, and not by the assembler. */
    40. #if defined(__ICCARM__) || defined(__CC_ARM) || defined(__GNUC__)
    41.   #include <stdint.h>
    42.   extern uint32_t SystemCoreClock;
    43. #endif
    44. #ifndef configENABLE_FPU
    45.   #define configENABLE_FPU                        1
    46. #endif
    47. #ifndef configENABLE_MPU
    48.   #define configENABLE_MPU                        0
    49. #endif
    50. #ifndef configENABLE_TRUSTZONE
    51.   #define configENABLE_TRUSTZONE                  0
    52. #endif
    53. #ifndef configRUN_FREERTOS_SECURE_ONLY
    54.   #define configRUN_FREERTOS_SECURE_ONLY          1
    55. #endif
    56. #define configUSE_PREEMPTION                                        1
    57. #define configSUPPORT_STATIC_ALLOCATION                        0//1
    58. #define configSUPPORT_DYNAMIC_ALLOCATION                1
    59. #define configUSE_IDLE_HOOK                                                0
    60. #define configUSE_TICK_HOOK                                                0
    61. #define configCPU_CLOCK_HZ                                                ( SystemCoreClock )
    62. #define configTICK_RATE_HZ                                                ( ( TickType_t ) 1000 )
    63. #define configMAX_PRIORITIES                                        ( 56 )
    64. #define configMINIMAL_STACK_SIZE                                ( ( uint16_t ) 512 )
    65. #define configTOTAL_HEAP_SIZE                                        ( ( size_t ) 15 * 1024 )
    66. #define configMAX_TASK_NAME_LEN                                        ( 16 )
    67. #define configUSE_TRACE_FACILITY                                1
    68. #define configUSE_16_BIT_TICKS                                        0
    69. #define configUSE_MUTEXES                                                1
    70. #define configQUEUE_REGISTRY_SIZE                                8
    71. #define configUSE_RECURSIVE_MUTEXES                                1
    72. #define configUSE_COUNTING_SEMAPHORES                        1
    73. #define configUSE_PORT_OPTIMISED_TASK_SELECTION        0
    74. #define configUSE_MALLOC_FAILED_HOOK                        0//1
    75. #define configCHECK_FOR_STACK_OVERFLOW                        0//2
    76. /* Defaults to size_t for backward compatibility, but can be changed
    77. * if lengths will always be less than the number of bytes in a size_t. */
    78. #define configMESSAGE_BUFFER_LENGTH_TYPE                size_t
    79. /* USER CODE END MESSAGE_BUFFER_LENGTH_TYPE */
    80. /* Software timer definitions. */
    81. #define configUSE_TIMERS                                                1
    82. #define configTIMER_TASK_PRIORITY                                ( 2 )
    83. #define configTIMER_QUEUE_LENGTH                                10
    84. #define configTIMER_TASK_STACK_DEPTH                        256
    85. /* Set the following definitions to 1 to include the API function, or zero
    86. * to exclude the API function. */
    87. #define INCLUDE_vTaskPrioritySet                                1
    88. #define INCLUDE_uxTaskPriorityGet                                1
    89. #define INCLUDE_vTaskDelete                                                1
    90. #define INCLUDE_vTaskCleanUpResources                        0
    91. #define INCLUDE_vTaskSuspend                                        1
    92. #define INCLUDE_vTaskDelayUntil                                        1
    93. #define INCLUDE_vTaskDelay                                                1
    94. #define INCLUDE_xTaskGetSchedulerState                        1
    95. #define INCLUDE_xTimerPendFunctionCall                        1
    96. #define INCLUDE_xQueueGetMutexHolder                        1
    97. #define INCLUDE_uxTaskGetStackHighWaterMark                1
    98. #define INCLUDE_eTaskGetState                                        1
    99. /* Cortex-M specific definitions. */
    100. #ifdef __NVIC_PRIO_BITS
    101.         /* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
    102.         #define configPRIO_BITS                                                __NVIC_PRIO_BITS
    103. #else
    104.         #define configPRIO_BITS                                                4
    105. #endif
    106. /* The lowest interrupt priority that can be used in a call to a "set priority"
    107. * function. */
    108. #define configLIBRARY_LOWEST_INTERRUPT_PRIORITY        15
    109. /* The highest interrupt priority that can be used by any interrupt service
    110. * routine that makes calls to interrupt safe FreeRTOS API functions.  DO NOT
    111. * CALL INTERRUPT SAFE FREERTOS API FUNCTIONS FROM ANY INTERRUPT THAT HAS A
    112. * HIGHER PRIORITY THAN THIS! (higher priorities are lower numeric values. */
    113. #define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
    114. /* Interrupt priorities used by the kernel port layer itself.  These are generic
    115. * to all Cortex-M ports, and do not rely on any particular library functions. */
    116. #define configKERNEL_INTERRUPT_PRIORITY                                ( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << ( 8 - configPRIO_BITS ) )
    117. /* !!!! configMAX_SYSCALL_INTERRUPT_PRIORITY must not be set to zero !!!!
    118. See http://www.FreeRTOS.org/RTOS-Cortex-M3-M4.html. */
    119. #define configMAX_SYSCALL_INTERRUPT_PRIORITY                ( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << ( 8 - configPRIO_BITS ) )
    120. /* Normal assert() semantics without relying on the provision of an assert.h
    121. * header file. */
    122. #define configASSERT( x )                                                        if ( ( x ) == 0 ) { taskDISABLE_INTERRUPTS(); for( ;; ); }
    123. /* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
    124. * standard names. */
    125. #define vPortSVCHandler        SVC_Handler
    126. #define xPortPendSVHandler                                                        PendSV_Handler
    127. #define xPortSysTickHandler                                                        SysTick_Handler
    128. /* Allow system call from within FreeRTOS kernel only. */
    129. #define configENFORCE_SYSTEM_CALLS_FROM_KERNEL_ONLY        1
    130. /* STM32H743 has 16 MPU regions and therefore it is necessary to configure
    131. * configTOTAL_MPU_REGIONS correctly. */
    132. #define configTOTAL_MPU_REGIONS                                                16
    133. /* The default TEX,S,C,B setting marks the SRAM as shareable and as a result,
    134. * disables cache. Do not mark the SRAM as shareable because caching is being
    135. * used. TEX=0, S=0, C=1, B=1. */
    136. #define configTEX_S_C_B_SRAM                                                ( 0x03UL )
    137. #endif /* FREERTOS_CONFIG_H */
    3.2、f_task.c
    1. <blockquote>#include "main.h"
    3.3、main.c
    1. #include "main.h"
    2. int main(void)
    3. {
    4.         uint8_t i;
    5.   CLOCK_EnableClock(kCLOCK_Gpio0);
    6.         BOARD_InitDEBUG_UARTPins();
    7.         BOARD_PowerMode_OD();
    8.         BOARD_InitBootClocks();
    9.         BOARD_InitDebugConsole();
    10.         init_led();
    11.         task_create();
    12.         while (1)
    13.         {
    14.         }
    15. }
    3.3、lm8168.c
    2. const uint8_t led_num[10]={0xfc,0x60,0xda,0xf2,0x66,0xb6,0xbe,0xe0,0xfe,0xf6 };
    3. uint32_t dt=0;
    4. uint8_t cnt=0;
    5. uint8_t jsflag=0;
    6. uint8_t disp_temp[4]={0,0,0,0};
    7. uint8_t disp_js=0;
    8. void delay(void)
    9. {
    10.         volatile uint32_t i = 0;
    11.         for (i = 0; i < 100; ++i)
    12.         {
    13.                 __asm("NOP"); /* delay */
    14.         }
    15. }
    16. void init_lm8168(void)
    17. {
    18.         init_lm8168b_pins();
    19.         LM8168_CLK_L();
    20.         LM8168_DAT_L();
    21.         LM8168_EN_L();
    22. }
    23. void lm8168_writebyte(uint32_t dat)
    24. {
    25.         uint8_t i=0;
    26.         LM8168_CLK_L();
    27.         LM8168_DAT_L();
    28.         LM8168_EN_L();
    29.
    30.         for(i=0;i<18;i++)
    31.         {
    32.                 if(dat&0x01)
    33.                 {
    34.                         LM8168_DAT_H();
    35.                 }
    36.                 else
    37.                 {
    38.                         LM8168_DAT_L();
    39.                 }
    40.                 dat=dat>>1;
    41.                 LM8168_CLK_L();
    42.                 delay();
    43.                 LM8168_CLK_H();
    44.                 delay();
    45.         }
    46. }
    47. void lm8168_writedat(uint8_t dat, uint8_t seg)
    48. {
    49.         uint32_t dt=0;
    50.
    51.         dt |= (seg&0x3f)<<1;
    52.         dt |= dat<<10;
    53.         lm8168_writebyte(dt);
    54.         LM8168_EN_H();
    55.         delay();
    56.         LM8168_EN_L();
    57. }
    四、程序运行
    下载程序后,串口输出
    LED显示
    GMT+8, 2025-1-29 05:54 , Processed in 0.117487 second(s), 16 queries , MemCache On.
