TA的每日心情 | 奋斗 前天 01:36 |
签到天数: 2 天 连续签到: 2 天 [LV.1]初来乍到
【飞凌OK3562J-C开发板体验】+ 性能测试一、音视频播放测试音频和视频播放
root@ok3562:/# gst-play-1.0 /userdata/media/1080p_60fps_h264-30S.mp4
Press 'k' to see a list of keyboard shortcuts.
Now playing /userdata/media/1080p_60fps_h264-30S.mp4
Redistribute latency...
0:00:30.0 / 0:00:30.0
Reached end of play list.
二、DDR测试查看DDR容量
测试DDR速度
查看DDR频率
查看DDR带宽利用率
10表示当前带宽利用率为10
三、GPU测试root@ok3562:/# glmark2-es2-wayland --fullscreen --visual-config='a=0:buf=24' --a nnotate
arm_release_ver: g13p0-01eac0, rk_so_ver: 10
glmark2 2023.01
OpenGL Information
GL_VENDOR: ARM
GL_RENDERER: Mali-G52
GL_VERSION: OpenGL ES 3.2 v1.g13p0-01eac0.98c5dad4e3309b873e3189000b74ea 36
Surface Config: buf=24 r=8 g=8 b=8 a=0 depth=24 stencil=0 samples=0
Surface Size: 1024x600 fullscreen
[build] use-vbo=false: FPS: 708 FrameTime: 1.413 ms
[build] use-vbo=true: FPS: 775 FrameTime: 1.291 ms
[texture] texture-filter=nearest: FPS: 954 FrameTime: 1.048 ms
[texture] texture-filter=linear: FPS: 956 FrameTime: 1.047 ms
[texture] texture-filter=mipmap: FPS: 968 FrameTime: 1.034 ms
[shading] shading=gouraud: FPS: 586 FrameTime: 1.707 ms
[shading] shading=blinn-phong-inf: FPS: 664 FrameTime: 1.506 ms
[shading] shading=phong: FPS: 588 FrameTime: 1.702 ms
[shading] shading=cel: FPS: 593 FrameTime: 1.688 ms
[bump] bump-render=high-poly: FPS: 306 FrameTime: 3.276 ms
[bump] bump-render=normals: FPS: 992 FrameTime: 1.009 ms
[bump] bump-render=height: FPS: 962 FrameTime: 1.040 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 392 FrameTime: 2.551 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 165 FrameTime: 6.081 ms
[pulsar] light=false:quads=5:texture=false: FPS: 944 FrameTime: 1.060 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 230 FrameTime: 4.349 ms
[desktop] effect=shadow:windows=4: FPS: 667 FrameTime: 1.499 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5: update-method=map: FPS: 132 FrameTime: 7.633 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5: update-method=subdata: FPS: 130 FrameTime: 7.728 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:u pdate-method=map: FPS: 218 FrameTime: 4.593 ms
[ideas] speed=duration: FPS: 342 FrameTime: 2.926 ms
[jellyfish] <default>: FPS: 450 FrameTime: 2.223 ms
[terrain] <default>: FPS: 34 FrameTime: 29.429 ms
[shadow] <default>: FPS: 302 FrameTime: 3.312 ms
[refract] <default>: FPS: 82 FrameTime: 12.270 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 900 FrameTime: 1.111 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 767 FrameTime: 1.304 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 901 FrameTime: 1.110 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 831 FrameTime: 1.203 m s
[function] fragment-complexity=medium:fragment-steps=5: FPS: 607 FrameTime: 1.64 8 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 833 FrameTime: 1.201 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 825 FrameTim e: 1.212 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 744 FrameTime : 1.344 ms
glmark2 Score: 591
四、WiFi测试 root@ok3562:/# fltest_wifi.sh -i wlan0 -s ZTE_FDAE7C -p YJL17346763359
wifi wlan0
ssid ZTE_FDAE7C
pasw YJL17346763359
waiting...
[ 2535.924380] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 2539.231085] RTW: wlan0- hw port(0) mac_addr =5c:c5:63:66:e1:26
[ 2539.249613] ========== ACS (VER-3) ==========
[ 2539.249677] Best 24G Channel:1
[ 2539.249697] Best 5G Channel:36
[ 2539.249697]
[ 2539.257358] RTW: rtw_set_802_11_connect(wlan0) fw_state=0x00000008
[ 2539.545293] RTW: start auth
[ 2539.862051] RTW: auth success, start assoc
[ 2539.866683] RTW: assoc success
[ 2539.868675] RTW: ============ STA [54:1f:8d:fd:ae:7c] ===================
[ 2539.868733] RTW: mac_id : 0
[ 2539.868753] RTW: wireless_mode : 0x0b
[ 2539.868770] RTW: mimo_type : 0
[ 2539.868786] RTW: static smps : N
[ 2539.868847] RTW: bw_mode : 20MHz, ra_bw_mode : 20MHz
[ 2539.868864] RTW: rate_id : 3
[ 2539.868883] RTW: rssi : -1 (%), rssi_level : 0
[ 2539.868902] RTW: is_support_sgi : Y, is_vht_enable : N
[ 2539.868920] RTW: disable_ra : N, disable_pt : N
[ 2539.868937] RTW: is_noisy : N
[ 2539.868952] RTW: txrx_state : 0
[ 2539.868970] RTW: curr_tx_rate : CCK_1M (L)
[ 2539.868986] RTW: curr_tx_bw : 20MHz
[ 2539.869004] RTW: curr_retry_ratio : 0
[ 2539.869021] RTW: ra_mask : 0x00000000000fffff
[ 2539.869021]
[ 2539.873557] RTW: recv eapol packet 1/4
[ 2539.874581] RTW: send eapol packet 2/4
[ 2539.905778] RTW: recv eapol packet 3/4
[ 2539.906351] RTW: send eapol packet 4/4
[ 2539.906982] RTW: set pairwise key camid:0, addr:54:1f:8d:fd:ae:7c, kid:0, type:AES
[ 2539.907494] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 2539.908718] RTW: set group key camid:1, addr:54:1f:8d:fd:ae:7c, kid:1, type:AES
udhcpc: started, v1.36.0
udhcpc: broadcasting discover
udhcpc: broadcasting select for 192.168.0.241, server 192.168.0.1
udhcpc: lease of 192.168.0.241 obtained from 192.168.0.1, lease time 86399
deleting routers
adding dns 192.168.0.1
connect ok连接成功后分配的IP为192.168.0.241 在路由器后台可以看到连接的设备信息
