查看: 896|回复: 0
打印 上一主题 下一主题
[资料] WiFi FEM:三伍微GSR2303S 2.4 GHz Front End Module兼容替代SKY/RTC/KCT/...
  • 签到天数: 2 天
    跳转到指定楼层
    楼主
    发表于 2024-10-17 17:15:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    WiFi FEM:三伍微GSR2303S 2.4 GHz Front End Module兼容替代SKY/RTC/KCT/Qorvo SKY85303 RTC7626 KCT8227
    Product Description The GSR2303S is a highly integrated front end module (FEM) designed for 2.4GHz 802.11b/g/n/ac/ax systems. The device provides all the functionality of a fully matched power amplifier (PA), power detector, a 2.4G low-noise amplifier (LNA), and a single-pole, double-throw (SPDT) switches.
    The GSR2303S provides a complete 2.4 GHz WLAN RF solution from the output of the transceiver to the antenna, and from the antenna to the input of the transceiver. The LNA increases the receive sensitivity of embedded solutions to improve range or to overcome the insertion loss of cellular filters (often included for mobile applications).
    The GSR2303S also includes a transmitter power detector with 20 dB dynamic range, and a digital enable control for transmitter power ramp on/off control. The device is provided in a compact, 16-pin2.5 x2.5 mm Quad Flat No-Lead (QFN) package. Pin map is shown in Figure 1. A functional block diagram is shown in Figure 2.
    Key Features
    * Pout = +21 dBm HE40 MCS11 -43dB DEVM
    * Pout = +22 dBm HE40 MCS11 -40dB DEVM
    *Pout = +23 dBm VTH40 MCS9 -35dB DEVM
    *Pout = +24 dBm HT40/20 MCS7 -30dB DEVM
    * Integrated positive slope power detector
    * Receive gain: 15 dB
    *1.6 dB LNA Noise Figure
    Applications
    * Mobile Access Points
    * Mobile Phones
    * Consumer Electronics
    * Customer Premise Equipment
    * Internet of Things
    举报
    站长推荐上一条 3/4 下一条
    【¥150积分】2025英飞凌创新大会—分论坛机器人:智驭未来
    大会会在深圳和北京巡回进行,上午是主论坛,下午将有多个分论坛同步进行,本次活动我们将会聚焦下午分论坛的机器人主题,聚焦英飞凌如何助力机器人高速发展、氮化镓解决方案在机器人中的应用、MCU驱动机器人的进化之路等等精彩主题分享,此外还有茶歇和幸运抽奖。
    查看 »
    GMT+8, 2025-4-1 01:59 , Processed in 0.103241 second(s), 18 queries , MemCache On.
