TA的每日心情 | 开心 昨天 09:05 |
签到天数: 365 天 连续签到: 13 天 [LV.9]以坛为家II
我根据软件开发指南使用SD卡升级到emmc后启动报错。信息如下:
- U-Boot SPL 2023.04-g9bdc7571c0 (May 09 2024 - 16:27:05 +0800)
- SOC: 0xa1009300
- LC: 0x2040010
- PMIC: Over Drive Voltage Mode
- DDR: 3733MTS
- M33 prepare ok
- Normal Boot
- Trying to boot from BOOTROM
- Boot Stage: Primary boot
- image offset 0x0, pagesize 0x200, ivt offset 0x0
- Load image from 0x48000 by ROM_API
- NOTICE: BL31: v2.8(release):lf-6.1.55-2.2.0-0-g08e9d4eef
- NOTICE: BL31: Built : 06:43:30, Nov 21 2023
- U-Boot 2023.04-g9bdc7571c0 (May 09 2024 - 16:27:05 +0800)
- CPU: i.MX93(52) rev1.1 1700 MHz (running at 1692 MHz)
- CPU: Industrial temperature grade (-40C to 105C) at 45C
- Reset cause: POR (0x1)
- Model: NXP i.MX93 11X11 EVK board
- DRAM: 992 MiB
- tcpc_init: Can't find device id=0x52
- setup_typec: tcpc portpd init failed, err=-19
- tcpc_init: Can't find device id=0x51
- setup_typec: tcpc port2 init failed, err=-19
- tcpc_init: Can't find device id=0x50
- setup_typec: tcpc port1 init failed, err=-19
- Module INFO:
- >>>PN=MYD-LMX9352-8E1D-170-I
- >>>SN=WKRD23120100700026Y
- Not valid MAC address in eeprom!
- Core: 218 devices, 33 uclasses, devicetree: separate
- MMC: FSL_SDHC: 0, FSL_SDHC: 1
- Loading Environment from MMC... OK
- [*]-Video Link 0fail to get display timings
- probe video device failed, ret -22
- [0] lcd-controller@4ae30000, video
- [1] dsi@4ae10000, video_bridge
- fail to get display timings
- In: serial
- Out: serial
- Err: serial
- BuildInfo:
- - ELE firmware version 0.1.0-44880904
- myir board:MYD-LMX93Xswitch to partitions #0, OK
- mmc0(part 0) is current device
- flash target is MMC:0
- Net: eth0: ethernet@42890000, eth1: ethernet@428a0000 [PRIME]
- Fastboot: Normal
- Normal Boot
- Hit any key to stop autoboot: 0
- switch to partitions #0, OK
- Scanning mmc 0:1...
- 46326 bytes read in 1 ms (44.2 MiB/s)
- Working FDT set to 83000000
- MMC: no card present
- No EFI system partition
- Failed to persist EFI variables
- BootOrder not defined
- EFI boot manager: Cannot load any image
- starting USB...
- Bus usb@4c100000: Port not available.
- Bus usb@4c200000: Port not available.
- USB is stopped. Please issue 'usb start' first.
- Running BSP bootcmd ...
- Failed to load 'boot.scr'
- 35052032 bytes read in 192 ms (174.1 MiB/s)
- Booting from mmc ...
- ## Flattened Device Tree blob at 83000000
- Booting using the fdt blob at 0x83000000
- Using Device Tree in place at 0000000083000000, end 000000008300e4f5
- Starting kernel ...
- [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
- [ 0.000000] Linux version 6.1.55+ga5c552ce6210 (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 12.3.0, GNU ld (GNU Binutils) 2.40.0.20230703) #1 SMP PREEMPT Thu Apr 11 02:15:58 UTC 2024
- [ 0.000000] Machine model: NXP i.MX93 11X11 EVK board
- [ 0.000000] efi: UEFI not found.
- [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000086000000, size 256 MiB
- [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
- [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4020000, size 1 MiB
- [ 0.000000] OF: reserved mem: initialized node vdevbuffer@a4020000, compatible id shared-dma-pool
- [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4120000, size 1 MiB
- [ 0.000000] OF: reserved mem: initialized node ele-reserved@a4120000, compatible id shared-dma-pool
- [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b0000000, size 128 MiB
- [ 0.000000] OF: reserved mem: initialized node ethosu_region@B0000000, compatible id shared-dma-pool
- [ 0.000000] earlycon: lpuart32 at MMIO32 0x0000000044380000 (options '')
- [ 0.000000] printk: bootconsole [lpuart32] enabled
- [ 0.000000] NUMA: No NUMA configuration found
- [ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x00000000bfffffff]
- [ 0.000000] NUMA: NODE_DATA [mem 0xbfdd6700-0xbfdd8fff]
- [ 0.000000] Zone ranges:
- [ 0.000000] DMA [mem 0x0000000080000000-0x00000000bfffffff]
- [ 0.000000] DMA32 empty
- [ 0.000000] Normal empty
- [ 0.000000] Movable zone start for each node
- [ 0.000000] Early memory node ranges
- [ 0.000000] node 0: [mem 0x0000000080000000-0x0000000095ffffff]
- [ 0.000000] node 0: [mem 0x0000000098000000-0x00000000a3ffffff]
- [ 0.000000] node 0: [mem 0x00000000a4000000-0x00000000a421ffff]
- [ 0.000000] node 0: [mem 0x00000000a4220000-0x00000000bfffffff]
- [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff]
- [ 0.000000] On node 0, zone DMA: 8192 pages in unavailable ranges
- [ 0.000000] psci: probing for conduit method from DT.
- [ 0.000000] psci: PSCIv1.1 detected in firmware.
- [ 0.000000] psci: Using standard PSCI v0.2 function IDs
- [ 0.000000] psci: Trusted OS migration not required
- [ 0.000000] psci: SMC Calling Convention v1.2
- [ 0.000000] percpu: Embedded 20 pages/cpu s44520 r8192 d29208 u81920
- [ 0.000000] Detected VIPT I-cache on CPU0
- [ 0.000000] CPU features: detected: GIC system register CPU interface
- [ 0.000000] CPU features: detected: Virtualization Host Extensions
- [ 0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
- [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
- [ 0.000000] alternatives: applying boot alternatives
- [ 0.000000] Fallback order for Node 0: 0
- [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 249856
- [ 0.000000] Policy zone: DMA
- [ 0.000000] Kernel command line: console=ttyLP0,115200 earlycon root=/dev/mmcblk0p3 rootwait rw
- [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
- [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
- [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
- [ 0.000000] Memory: 565136K/1015808K available (21056K kernel code, 1910K rwdata, 7676K rodata, 3456K init, 664K bss, 57456K reserved, 393216K cma-reserved)
- [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
- [ 0.000000] rcu: Preemptible hierarchical RCU implementation.
- [ 0.000000] rcu: RCU event tracing is enabled.
- [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
- [ 0.000000] Trampoline variant of Tasks RCU enabled.
- [ 0.000000] Tracing variant of Tasks RCU enabled.
- [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
- [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
- [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
- [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
- [ 0.000000] GICv3: 960 SPIs implemented
- [ 0.000000] GICv3: 0 Extended SPIs implemented
- [ 0.000000] Root IRQ handler: gic_handle_irq
- [ 0.000000] GICv3: GICv3 features: 16 PPIs
- [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000048040000
- [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
- [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
- [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
- [ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
- [ 0.008300] Console: colour dummy device 80x25
- [ 0.012530] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
- [ 0.022712] pid_max: default: 32768 minimum: 301
- [ 0.027333] LSM: Security Framework initializing
- [ 0.031955] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
- [ 0.039266] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
- [ 0.047730] cacheinfo: Unable to detect cache hierarchy for CPU 0
- [ 0.053966] cblist_init_generic: Setting adjustable number of callback queues.
- [ 0.060948] cblist_init_generic: Setting shift to 1 and lim to 1.
- [ 0.067032] cblist_init_generic: Setting adjustable number of callback queues.
- [ 0.074188] cblist_init_generic: Setting shift to 1 and lim to 1.
- [ 0.080361] rcu: Hierarchical SRCU implementation.
- [ 0.085022] rcu: Max phase no-delay instances is 1000.
- [ 0.091030] EFI services will not be available.
- [ 0.095470] smp: Bringing up secondary CPUs ...
- [ 0.100171] Detected VIPT I-cache on CPU1
- [ 0.100232] cacheinfo: Unable to detect cache hierarchy for CPU 1
- [ 0.100242] GICv3: CPU1: found redistributor 100 region 0:0x0000000048060000
- [ 0.100275] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
- [ 0.100365] smp: Brought up 1 node, 2 CPUs
- [ 0.127788] SMP: Total of 2 processors activated.
- [ 0.132458] CPU features: detected: 32-bit EL0 Support
- [ 0.137580] CPU features: detected: 32-bit EL1 Support
- [ 0.142685] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
- [ 0.151261] CPU features: detected: Common not Private translations
- [ 0.157500] CPU features: detected: CRC32 instructions
- [ 0.162616] CPU features: detected: RCpc load-acquire (LDAPR)
- [ 0.168333] CPU features: detected: LSE atomic instructions
- [ 0.173881] CPU features: detected: Privileged Access Never
- [ 0.179427] CPU features: detected: RAS Extension Support
- [ 0.184804] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
- [ 0.191784] CPU: All CPU(s) started at EL2
- [ 0.195809] alternatives: applying system-wide alternatives
- [ 0.205325] devtmpfs: initialized
- [ 0.213071] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
- [ 0.222570] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
- [ 0.237496] pinctrl core: initialized pinctrl subsystem
- [ 0.243748] DMI not present or invalid.
- [ 0.247773] NET: Registered PF_NETLINK/PF_ROUTE protocol family
- [ 0.254226] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
- [ 0.261106] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
- [ 0.268797] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
- [ 0.276671] audit: initializing netlink subsys (disabled)
- [ 0.282191] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
- [ 0.282586] thermal_sys: Registered thermal governor 'step_wise'
- [ 0.289717] thermal_sys: Registered thermal governor 'power_allocator'
- [ 0.295838] cpuidle: using governor menu
- [ 0.306279] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
- [ 0.312886] ASID allocator initialised with 65536 entries
- [ 0.318827] Serial: AMBA PL011 UART driver
- [ 0.322709] imx mu driver is registered.
- [ 0.326564] imx rpmsg driver is registered.
- [ 0.336135] imx93-pinctrl 443c0000.pinctrl: initialized IMX pinctrl driver
- [ 0.348475] platform 4ae30000.lcd-controller: Fixed dependency cycle(s) with /soc@0/system-controller@4ac10000/dpi/ports/port@0/endpoint
- [ 0.360509] platform 4ae30000.lcd-controller: Fixed dependency cycle(s) with /soc@0/dsi@4ae10000/ports/port@0/endpoint
- [ 0.373871] platform panel: Fixed dependency cycle(s) with /soc@0/system-controller@4ac10000/dpi/ports/port@1/endpoint
- [ 0.384636] KASLR disabled due to lack of seed
- [ 0.414059] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
- [ 0.420600] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
- [ 0.426831] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
- [ 0.433586] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
- [ 0.439830] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
- [ 0.446585] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
- [ 0.452826] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
- [ 0.459585] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
- [ 0.467377] ACPI: Interpreter disabled.
- [ 0.472883] iommu: Default domain type: Translated
- [ 0.477497] iommu: DMA domain TLB invalidation policy: strict mode
- [ 0.483962] SCSI subsystem initialized
- [ 0.487788] usbcore: registered new interface driver usbfs
- [ 0.493045] usbcore: registered new interface driver hub
- [ 0.498310] usbcore: registered new device driver usb
- [ 0.504101] mc: Linux media interface: v0.10
- [ 0.508140] videodev: Linux video capture interface: v2.00
- [ 0.513610] pps_core: LinuxPPS API ver. 1 registered
- [ 0.518504] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
- [ 0.527608] PTP clock support registered
- [ 0.531598] EDAC MC: Ver: 3.0.0
- [ 0.535629] FPGA manager framework
- [ 0.538828] Advanced Linux Sound Architecture Driver Initialized.
- [ 0.545346] Bluetooth: Core ver 2.22
- [ 0.548683] NET: Registered PF_BLUETOOTH protocol family
- [ 0.553958] Bluetooth: HCI device and connection manager initialized
- [ 0.560280] Bluetooth: HCI socket layer initialized
- [ 0.565131] Bluetooth: L2CAP socket layer initialized
- [ 0.570162] Bluetooth: SCO socket layer initialized
- [ 0.575314] vgaarb: loaded
- [ 0.578230] clocksource: Switched to clocksource arch_sys_counter
- [ 0.584262] VFS: Disk quotas dquot_6.6.0
- [ 0.588002] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
- [ 0.594930] pnp: PnP ACPI: disabled
- [ 0.602989] NET: Registered PF_INET protocol family
- [ 0.607746] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
- [ 0.615686] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
- [ 0.623828] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
- [ 0.631494] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
- [ 0.639236] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear)
- [ 0.646632] TCP: Hash tables configured (established 8192 bind 8192)
- [ 0.652832] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
- [ 0.659323] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
- [ 0.666445] NET: Registered PF_UNIX/PF_LOCAL protocol family
- [ 0.672328] RPC: Registered named UNIX socket transport module.
- [ 0.677995] RPC: Registered udp transport module.
- [ 0.682659] RPC: Registered tcp transport module.
- [ 0.687338] RPC: Registered tcp NFSv4.1 backchannel transport module.
- [ 0.694312] PCI: CLS 0 bytes, default 64
- [ 0.698530] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
- [ 0.706953] kvm [1]: IPA Size Limit: 40 bits
- [ 0.710980] kvm [1]: GICv3: no GICV resource entry
- [ 0.715731] kvm [1]: disabling GICv2 emulation
- [ 0.720161] kvm [1]: GIC system register CPU interface enabled
- [ 0.726000] kvm [1]: vgic interrupt IRQ9
- [ 0.729905] kvm [1]: VHE mode initialized successfully
- [ 0.735875] Initialise system trusted keyrings
- [ 0.740253] workingset: timestamp_bits=42 max_order=18 bucket_order=0
- [ 0.750432] squashfs: version 4.0 (2009/01/31) Phillip Lougher
- [ 0.756485] NFS: Registering the id_resolver key type
- [ 0.761312] Key type id_resolver registered
- [ 0.765436] Key type id_legacy registered
- [ 0.769470] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
- [ 0.776099] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
- [ 0.783474] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
- [ 0.789781] 9p: Installing v9fs 9p2000 file system support
- [ 0.820651] Key type asymmetric registered
- [ 0.824483] Asymmetric key parser 'x509' registered
- [ 0.829374] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
- [ 0.836703] io scheduler mq-deadline registered
- [ 0.841207] io scheduler kyber registered
- [ 0.849908] EINJ: ACPI disabled.
- [ 0.857843] Bus freq driver module loaded
- [ 0.866578] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
- [ 0.874616] 44380000.serial: ttyLP0 at MMIO 0x44380010 (irq = 18, base_baud = 1500000)[ 0.883977] printk: console [ttyLP0] enabled
- [ 0.883977] printk: console [ttyLP0] enabled
- [ 0.892386] printk: bootconsole [lpuart32] disabled
- [ 0.908698] cacheinfo: Unable to detect cache hierarchy for CPU 0
- [ 0.918340] loop: module loaded
- [ 0.922565] of_reserved_mem_lookup() returned NULL
- [ 0.927485] megasas: 07.719.03.00-rc1
- [ 0.936510] tun: Universal TUN/TAP device driver, 1.6
- [ 0.941789] CAN device driver interface
- [ 0.947309] thunder_xcv, ver 1.0
- [ 0.950579] thunder_bgx, ver 1.0
- [ 0.953822] nicpf, ver 1.0
- [ 0.957321] pps pps0: new PPS source ptp0
- [ 0.963661] fec 42890000.ethernet eth0: registered PHC device 0
- [ 0.971553] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
- [ 0.978785] hns3: Copyright (c) 2017 Huawei Corporation.
- [ 0.984157] hclge is initializing
- [ 0.987482] e1000: Intel(R) PRO/1000 Network Driver
- [ 0.992359] e1000: Copyright (c) 1999-2006 Intel Corporation.
- [ 0.998145] e1000e: Intel(R) PRO/1000 Network Driver
- [ 1.003101] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
- [ 1.009040] igb: Intel(R) Gigabit Ethernet Network Driver
- [ 1.014449] igb: Copyright (c) 2007-2014 Intel Corporation.
- [ 1.020062] igbvf: Intel(R) Gigabit Virtual Function Network Driver
- [ 1.026336] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
- [ 1.032466] sky2: driver version 1.30
- [ 1.036694] PPP generic driver version 2.4.2
- [ 1.041102] PPP BSD Compression module registered
- [ 1.045813] PPP Deflate Compression module registered
- [ 1.051042] PPP MPPE Compression module registered
- [ 1.055838] NET: Registered PF_PPPOX protocol family
- [ 1.060890] usbcore: registered new interface driver rndis_wlan
- [ 1.066839] usbcore: registered new interface driver catc
- [ 1.072246] usbcore: registered new interface driver kaweth
- [ 1.077824] usbcore: registered new interface driver r8152
- [ 1.083326] usbcore: registered new interface driver cdc_ether
- [ 1.089169] usbcore: registered new interface driver cdc_eem
- [ 1.094837] usbcore: registered new interface driver net1080
- [ 1.100510] usbcore: registered new interface driver rndis_host
- [ 1.106436] usbcore: registered new interface driver cdc_subset
- [ 1.112367] usbcore: registered new interface driver zaurus
- [ 1.117960] usbcore: registered new interface driver sierra_net
- [ 1.123896] usbcore: registered new interface driver cdc_ncm
- [ 1.129565] usbcore: registered new interface driver qmi_wwan
- [ 1.135321] usbcore: registered new interface driver cdc_mbim
- [ 1.141077] usbcore: registered new interface driver r8153_ecm
- [ 1.147133] VFIO - User Level meta-driver version: 0.3
- [ 1.155111] usbcore: registered new interface driver cdc_wdm
- [ 1.160993] usbcore: registered new interface driver uas
- [ 1.166354] usbcore: registered new interface driver usb-storage
- [ 1.172415] usbcore: registered new interface driver usbserial_generic
- [ 1.178942] usbserial: USB Serial support registered for generic
- [ 1.184954] usbcore: registered new interface driver ftdi_sio
- [ 1.190699] usbserial: USB Serial support registered for FTDI USB Serial Device
- [ 1.198013] usbcore: registered new interface driver option
- [ 1.203586] usbserial: USB Serial support registered for GSM modem (1-port)
- [ 1.210561] usbcore: registered new interface driver usb_serial_simple
- [ 1.217089] usbserial: USB Serial support registered for carelink
- [ 1.223180] usbserial: USB Serial support registered for flashloader
- [ 1.229538] usbserial: USB Serial support registered for funsoft
- [ 1.235544] usbserial: USB Serial support registered for google
- [ 1.241459] usbserial: USB Serial support registered for hp4x
- [ 1.247204] usbserial: USB Serial support registered for kaufmann
- [ 1.253296] usbserial: USB Serial support registered for libtransistor
- [ 1.259823] usbserial: USB Serial support registered for moto_modem
- [ 1.266089] usbserial: USB Serial support registered for motorola_tetra
- [ 1.272703] usbserial: USB Serial support registered for nokia
- [ 1.278540] usbserial: USB Serial support registered for novatel_gps
- [ 1.284891] usbserial: USB Serial support registered for siemens_mpi
- [ 1.291245] usbserial: USB Serial support registered for suunto
- [ 1.297159] usbserial: USB Serial support registered for vivopay
- [ 1.303169] usbserial: USB Serial support registered for zio
- [ 1.308842] usbcore: registered new interface driver usb_ehset_test
- [ 1.317522] bbnsm_pwrkey 44440000.bbnsm:pwrkey: KEY_POWER without setting in dts
- [ 1.325736] input: 44440000.bbnsm:pwrkey as /devices/platform/soc@0/44000000.bus/44440000.bbnsm/44440000.bbnsm:pwrkey/input/input0
- [ 1.340443] bbnsm_rtc 44440000.bbnsm:rtc: registered as rtc0
- [ 1.346498] bbnsm_rtc 44440000.bbnsm:rtc: setting system clock to 1970-01-01T00:00:00 UTC (0)
- [ 1.355777] i2c_dev: i2c /dev entries driver
- [ 1.363071] imx7ulp-wdt 42490000.wdog: imx93 wdt probe
- [ 1.393788] Bluetooth: HCI UART driver ver 2.3
- [ 1.398249] Bluetooth: HCI UART protocol H4 registered
- [ 1.403378] Bluetooth: HCI UART protocol BCSP registered
- [ 1.408696] Bluetooth: HCI UART protocol LL registered
- [ 1.413822] Bluetooth: HCI UART protocol ATH3K registered
- [ 1.419229] Bluetooth: HCI UART protocol Three-wire (H5) registered
- [ 1.425619] Bluetooth: HCI UART protocol Broadcom registered
- [ 1.431284] Bluetooth: HCI UART protocol QCA registered
- [ 1.437888] sdhci: Secure Digital Host Controller Interface driver
- [ 1.444095] sdhci: Copyright(c) Pierre Ossman
- [ 1.448952] Synopsys Designware Multimedia Card Interface Driver
- [ 1.455383] sdhci-pltfm: SDHCI platform and OF driver helper
- [ 1.462525] ledtrig-cpu: registered to indicate activity on CPUs
- [ 1.469682] fsl-ele-mu soc@0:ele-mu: ele_mu_probe: Not able to read cmd_tag
- [ 1.476671] fsl-ele-mu soc@0:ele-mu: ele_mu_probe: Not able to read rsp_tag
- [ 1.484074] fsl-ele-mu soc@0:ele-mu: assigned reserved memory node ele-reserved@a4120000
- [ 1.492269] fsl-ele-mu soc@0:ele-mu: registering ele-trng
- [ 1.493327] mmc0: SDHCI controller on 42850000.mmc [42850000.mmc] using ADMA
- [ 1.497903] fsl-ele-mu soc@0:ele-mu: Successfully registered ele-trng
- [ 1.511257] random: crng init done
- [ 1.511363] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
- [ 1.521284] usbcore: registered new interface driver usbhid
- [ 1.526857] usbhid: USB HID core driver
- [ 1.531988] mxc-md 42800000.bus:camera: deferring cap_device registration
- [ 1.539384] usbcore: registered new interface driver rtl8733bu
- [ 1.584557] cs_system_cfg: CoreSight Configuration manager initialised
- [ 1.592610] optee: probing for conduit method.
- [ 1.597146] optee: revision 4.0 (a303fc80)
- [ 1.597667] optee: dynamic shared memory is enabled
- [ 1.606947] optee: initialized driver
- [ 1.614530] mmc0: new HS400 Enhanced strobe MMC card at address 0001
- [ 1.616893] imx93-pinctrl 443c0000.pinctrl: pin IMX93_IOMUXC_GPIO_IO26 already requested by 4ac10000.system-controller:dpi; cannot claim for 42660000.sai
- [ 1.621467] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
- [ 1.634628] imx93-pinctrl 443c0000.pinctrl: pin-30 (42660000.sai) status -22
- [ 1.634635] imx93-pinctrl 443c0000.pinctrl: could not request pin 30 (IMX93_IOMUXC_GPIO_IO26) from group sai3grp on device 443c0000.pinctrl
- [ 1.634640] fsl-sai 42660000.sai: Error applying setting, reverse things back
- [ 1.635512] NET: Registered PF_LLC protocol family
- [ 1.670948] mmcblk0: p1 p2
- [ 1.674364] NET: Registered PF_INET6 protocol family
- [ 1.674372] mmcblk0boot0: mmc0:0001 8GUF4R 31.9 MiB
- [ 1.675467] mmcblk0boot1: mmc0:0001 8GUF4R 31.9 MiB
- [ 1.680139] Segment Routing with IPv6
- [ 1.685236] mmcblk0rpmb: mmc0:0001 8GUF4R 4.00 MiB, chardev (234:0)
- [ 1.689367] In-situ OAM (IOAM) with IPv6
- [ 1.703196] NET: Registered PF_PACKET protocol family
- [ 1.708270] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
- [ 1.721204] can: controller area network core
- [ 1.725587] NET: Registered PF_CAN protocol family
- [ 1.730378] can: raw protocol
- [ 1.733334] can: broadcast manager protocol
- [ 1.737509] can: netlink gateway - max_hops=1
- [ 1.742111] Bluetooth: RFCOMM TTY layer initialized
- [ 1.747003] Bluetooth: RFCOMM socket layer initialized
- [ 1.752150] Bluetooth: RFCOMM ver 1.11
- [ 1.755941] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
- [ 1.761243] Bluetooth: BNEP filters: protocol multicast
- [ 1.766463] Bluetooth: BNEP socket layer initialized
- [ 1.771417] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
- [ 1.777330] Bluetooth: HIDP socket layer initialized
- [ 1.782496] 8021q: 802.1Q VLAN Support v1.8
- [ 1.786704] lib80211: common routines for IEEE802.11 drivers
- [ 1.792458] 9pnet: Installing 9P2000 support
- [ 1.796809] Key type dns_resolver registered
- [ 1.801431] registered taskstats version 1
- [ 1.805541] Loading compiled-in X.509 certificates
- [ 1.824942] usb_phy_generic soc@0:usbphynop1: supply vcc not found, using dummy regulator
- [ 1.833727] usb_phy_generic soc@0:usbphynop1: dummy supplies not allowed for exclusive requests
- [ 1.842593] usb_phy_generic soc@0:usbphynop2: supply vcc not found, using dummy regulator
- [ 1.850857] usb_phy_generic soc@0:usbphynop2: dummy supplies not allowed for exclusive requests
- [ 1.871755] imx-dwmac 428a0000.ethernet: IRQ eth_lpi not found
- [ 1.878022] imx-dwmac 428a0000.ethernet: User ID: 0x10, Synopsys ID: 0x52
- [ 1.884823] imx-dwmac 428a0000.ethernet: DWMAC4/5
- [ 1.889606] imx-dwmac 428a0000.ethernet: DMA HW capability register supported
- [ 1.896732] imx-dwmac 428a0000.ethernet: RX Checksum Offload Engine supported
- [ 1.903856] imx-dwmac 428a0000.ethernet: TX Checksum insertion supported
- [ 1.910543] imx-dwmac 428a0000.ethernet: Wake-Up On Lan supported
- [ 1.916681] imx-dwmac 428a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
- [ 1.924325] imx-dwmac 428a0000.ethernet: Enabled L3L4 Flow TC (entries=8)
- [ 1.931102] imx-dwmac 428a0000.ethernet: Enabled RFS Flow TC (entries=10)
- [ 1.937885] imx-dwmac 428a0000.ethernet: Enabling HW TC (entries=256, max_off=256)
- [ 1.945445] imx-dwmac 428a0000.ethernet: Using 32/32 bits DMA host/device width
- [ 1.958883] ci_hdrc ci_hdrc.0: EHCI Host Controller
- [ 1.963790] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
- [ 1.986238] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
- [ 1.992125] hub 1-0:1.0: USB hub found
- [ 1.995900] hub 1-0:1.0: 1 port detected
- [ 2.003775] isi-capture 4ae40000.isi:cap_device: deferring 4ae40000.isi:cap_device device registration
- [ 2.013225] mxc-isi 4ae40000.isi: mxc_isi.0 registered successfully
- [ 2.020279] mxc-md 42800000.bus:camera: deferring cap_device registration
- [ 2.028914] remoteproc remoteproc0: imx-rproc is available
- [ 2.038767] regulator-panel_powr1 GPIO handle specifies active low - ignored
- [ 2.045853] reg-fixed-voltage regulator-panel_powr1: nonexclusive access to GPIO for regulator-panel_powr1
- [ 2.056757] i2c 0-003c: Fixed dependency cycle(s) with /soc@0/bus@42800000/camera/csi@4ae00000/port@0/endpoint
- [ 2.067185] ov5640 0-003c: supply DOVDD not found, using dummy regulator
- [ 2.073997] ov5640 0-003c: supply AVDD not found, using dummy regulator
- [ 2.080627] ov5640 0-003c: supply DVDD not found, using dummy regulator
- [ 2.124536] ov5640 0-003c: ov5640_read_reg: error: reg=300a
- [ 2.130130] ov5640 0-003c: ov5640_check_chip_id: failed to read chip identifier
- [ 2.137619] ov5640: probe of 0-003c failed with error -5
- [ 2.143943] sgtl5000 0-000a: sgtl5000 revision 0x11
- [ 2.154090] at24 0-0050: supply vcc not found, using dummy regulator
- [ 2.160772] at24 0-0050: 4096 byte 24c32 EEPROM, writable, 32 bytes/write
- [ 2.168379] rtc-rx8025t 0-0032: registered as rtc1
- [ 2.173674] ptn5150 0-003d: No VBUS GPIO, ignoring VBUS control
- [ 2.180256] OF: graph: no port node found in /soc@0/bus@44000000/i2c@44340000/typec@3d
- [ 2.188387] i2c i2c-0: LPI2C adapter registered
- [ 2.194024] i2c 1-0039: Fixed dependency cycle(s) with /soc@0/dsi@4ae10000/ports/port@1/endpoint
- [ 2.203188] myir i2c_gpio probe
- [ 2.206336] at9555 gpio_base=130
- [ 2.210524] at9555_gpio 1-0020: probed
- [ 2.214430] nxp-pca9450 1-0025: No IRQ configured?
- [ 2.219221] nxp-pca9450: probe of 1-0025 failed with error -22
- [ 2.225425] i2c i2c-1: LPI2C adapter registered
- [ 2.225622] edt_ft5x06 1-0038: supply vcc not found, using dummy regulator
- [ 2.231308] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
- [ 2.236944] edt_ft5x06 1-0038: supply iovcc not found, using dummy regulator
- [ 2.244783] [drm:drm_bridge_attach] *ERROR* failed to attach bridge /soc@0/dsi@4ae10000 to encoder DSI-34: -517
- [ 2.261863] dw-mipi-dsi-imx 4ae10000.dsi: [drm:dw_mipi_dsi_imx_bind] *ERROR* failed to attach bridge: -517
- [ 2.262245] usb 1-1: new high-speed USB device number 2 using ci_hdrc
- [ 2.271738] dw-mipi-dsi-imx 4ae10000.dsi: [drm:dw_mipi_dsi_imx_probe] *ERROR* failed to register component: -517
- [ 2.296578] sdhci-esdhc-imx 42860000.mmc: Got CD GPIO
- [ 2.297093] mx8-img-md: Registered mxc_isi.0.capture as /dev/video0
- [ 2.307982] mxc-md 42800000.bus:camera: deferring csi device registration
- [ 2.315908] dwc-mipi-csi2-host 4ae00000.csi: lanes: 2, name: mxc-mipi-csi2.0
- [ 2.329043] regulator-panel GPIO handle specifies active low - ignored
- [ 2.330454] mmc1: SDHCI controller on 42860000.mmc [42860000.mmc] using ADMA
- [ 2.335932] debugfs: Directory 'panel-power1' with parent 'regulator' already present!
- [ 2.443394] hub 1-1:1.0: USB hub found
- [ 2.447290] hub 1-1:1.0: 4 ports detected
- [ 2.550831] lt9611 1-0039: LT9611 revision: 0xe2
- [ 2.561183] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
- [ 2.569320] imx-drm display-subsystem: bound 4ae10000.dsi (ops dw_mipi_dsi_imx_ops)
- [ 2.577099] imx-drm display-subsystem: bound 4ac10000.system-controller:dpi (ops imx93_pdf_ops)
- [ 2.578623] input: generic ft5x06 (79) as /devices/platform/soc@0/44000000.bus/44350000.i2c/i2c-1/1-0038/input/input1
- [ 2.586163] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
- [ 2.605483] imx-drm display-subsystem: [drm] fb0: imx-drmdrmfb frame buffer device
- [ 2.614823] mx8-img-md: Registered mxc_isi.0.capture as /dev/video0
- [ 2.621267] unregister ISI channel: mxc_isi.0
- [ 2.626773] input: gpio-keys as /devices/platform/gpio-keys/input/input2
- [ 2.634189] cfg80211: Loading compiled-in X.509 certificates for regulatory database
- [ 2.643321] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
- [ 2.649958] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
- [ 2.654999] ALSA device list:
- [ 2.658584] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
- [ 2.661601] #0: SGTL5000-Card
- [ 2.673104] /dev/root: Can't open blockdev
- [ 2.677240] VFS: Cannot open root device "mmcblk0p3" or unknown-block(179,3): error -6
- [ 2.685165] Please append a correct "root=" boot option; here are the available partitions:
- [ 2.693640] b300 7634944 mmcblk0
- [ 2.693645] driver: mmcblk
- [ 2.700451] b301 512000 mmcblk0p1 d514cfe4-01
- [ 2.700456]
- [ 2.707248] b302 7020544 mmcblk0p2 d514cfe4-02
- [ 2.707252]
- [ 2.714058] b320 32640 mmcblk0boot0
- [ 2.714062] (driver?)
- [ 2.720846] b340 32640 mmcblk0boot1
- [ 2.720849] (driver?)
- [ 2.727638] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,3)
- [ 2.736060] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 6.1.55+ga5c552ce6210 #1
- [ 2.743182] Hardware name: NXP i.MX93 11X11 EVK board (DT)
- [ 2.748651] Call trace:
- [ 2.751086] dump_backtrace.part.0+0xe0/0xf0
- [ 2.755358] show_stack+0x18/0x30
- [ 2.758669] dump_stack_lvl+0x64/0x80
- [ 2.762326] dump_stack+0x18/0x34
- [ 2.765628] panic+0x18c/0x344
- [ 2.768670] mount_block_root+0x188/0x238
- [ 2.772674] mount_root+0x20c/0x24c
- [ 2.776149] prepare_namespace+0x130/0x170
- [ 2.780231] kernel_init_freeable+0x258/0x284
- [ 2.784573] kernel_init+0x24/0x12c
- [ 2.788048] ret_from_fork+0x10/0x20
- [ 2.791612] SMP: stopping secondary CPUs
- [ 2.795524] Kernel Offset: disabled
- [ 2.799003] CPU features: 0x60000,000400a4,6600721b
- [ 2.803865] Memory Limit: none
- [ 2.806912] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,3) ]---
复制代码 重新下载了好几次也不行。
