板载按键(Key):
MYD-YM62X 有三个按键,S1 是 MCU 复位按键;S2 是 Soc 复位按键;S3 是用户按键,已经在设备树配置,原理图如下。
Linux 的/dev/input/eventx 设备可以用来方便地调试鼠标、键盘、触摸板等输入设备,开发板输入cat /proc/bus/input/devices 命令查看input 子系统信息,结果如下:
- root@myd-am62x:/home/workspace/usb# cat /proc/bus/input/devices
- I: Bus=0019 Vendor=0001 Product=0001 Version=0100
- N: Name="gpio-keys"
- P: Phys=gpio-keys/input0
- S: Sysfs=/devices/platform/gpio-keys/input/input0
- U: Uniq=
- H: Handlers=event0
- B: PROP=0
- B: EV=100003
- B: KEY=1 0 0 0 0
复制代码从输出信息可知 gpio-keys 对应的是event0事件,应用层读取/dev/input/event0 节点即可获取到按键状态,用户态通过input_event 结构体获取按键状态信息。 - /*
- * The event structure itself
- * Note that __USE_TIME_BITS64 is defined by libc based on
- * application's request to use 64 bit time_t.
- struct input_event {
- #if (__BITS_PER_LONG != 32 || !defined(__USE_TIME_BITS64)) && !defined(__KERNEL__)
- struct timeval time;
- #define input_event_sec time.tv_sec
- #define input_event_usec time.tv_usec
- #else
- __kernel_ulong_t __sec;
- #if defined(__sparc__) && defined(__arch64__)
- unsigned int __usec;
- unsigned int __pad;
- #else
- __kernel_ulong_t __usec;
- #endif
- #define input_event_sec __sec
- #define input_event_usec __usec
- #endif
- __u16 type;
- __u16 code;
- __s32 value;
复制代码 以下是官方文档对input_event 成员取值的描述:- .. _input-event-codes:
- Input event codes
- The input protocol uses a map of types and codes to express input device values
- to userspace. This document describes the types and codes and how and when they
- may be used.
- A single hardware event generates multiple input events. Each input event
- contains the new value of a single data item. A special event type, EV_SYN, is
- used to separate input events into packets of input data changes occurring at
- the same moment in time. In the following, the term "event" refers to a single
- input event encompassing a type, code, and value.
- The input protocol is a stateful protocol. Events are emitted only when values
- of event codes have changed. However, the state is maintained within the Linux
- input subsystem; drivers do not need to maintain the state and may attempt to
- emit unchanged values without harm. Userspace may obtain the current state of
- event code values using the EVIOCG* ioctls defined in linux/input.h. The event
- reports supported by a device are also provided by sysfs in
- class/input/event*/device/capabilities/, and the properties of a device are
- provided in class/input/event*/device/properties.
- Event types
- Event types are groupings of codes under a logical input construct. Each
- type has a set of applicable codes to be used in generating events. See the
- Codes section for details on valid codes for each type.
- * EV_SYN:
- - Used as markers to separate events. Events may be separated in time or in
- space, such as with the multitouch protocol.
- * EV_KEY:
- - Used to describe state changes of keyboards, buttons, or other key-like
- devices.
- * EV_REL:
- - Used to describe relative axis value changes, e.g. moving the mouse 5 units
- to the left.
- * EV_ABS:
- - Used to describe absolute axis value changes, e.g. describing the
- coordinates of a touch on a touchscreen.
- * EV_MSC:
- - Used to describe miscellaneous input data that do not fit into other types.
- * EV_SW:
- - Used to describe binary state input switches.
- * EV_LED:
- - Used to turn LEDs on devices on and off.
- * EV_SND:
- - Used to output sound to devices.
- * EV_REP:
- - Used for autorepeating devices.
- * EV_FF:
- - Used to send force feedback commands to an input device.
- * EV_PWR:
- - A special type for power button and switch input.
- * EV_FF_STATUS:
- - Used to receive force feedback device status.
- Event codes
- Event codes define the precise type of event.
- EV_SYN
- EV_SYN event values are undefined. Their usage is defined only by when they are
- sent in the evdev event stream.
- * SYN_REPORT:
- - Used to synchronize and separate events into packets of input data changes
- occurring at the same moment in time. For example, motion of a mouse may set
- the REL_X and REL_Y values for one motion, then emit a SYN_REPORT. The next
- motion will emit more REL_X and REL_Y values and send another SYN_REPORT.
- * SYN_CONFIG:
- - TBD
- * SYN_MT_REPORT:
- - Used to synchronize and separate touch events. See the
- multi-touch-protocol.txt document for more information.
- * SYN_DROPPED:
- - Used to indicate buffer overrun in the evdev client's event queue.
- Client should ignore all events up to and including next SYN_REPORT
- event and query the device (using EVIOCG* ioctls) to obtain its
- current state.
- EV_KEY
- EV_KEY events take the form KEY_<name> or BTN_<name>. For example, KEY_A is used
- to represent the 'A' key on a keyboard. When a key is depressed, an event with
- the key's code is emitted with value 1. When the key is released, an event is
- emitted with value 0. Some hardware send events when a key is repeated. These
- events have a value of 2. In general, KEY_<name> is used for keyboard keys, and
- BTN_<name> is used for other types of momentary switch events.
- A few EV_KEY codes have special meanings:
- * BTN_TOOL_<name>:
- - These codes are used in conjunction with input trackpads, tablets, and
- touchscreens. These devices may be used with fingers, pens, or other tools.
- When an event occurs and a tool is used, the corresponding BTN_TOOL_<name>
- code should be set to a value of 1. When the tool is no longer interacting
- with the input device, the BTN_TOOL_<name> code should be reset to 0. All
- trackpads, tablets, and touchscreens should use at least one BTN_TOOL_<name>
- code when events are generated. Likewise all trackpads, tablets, and
- touchscreens should export only one BTN_TOOL_<name> at a time. To not break
- existing userspace, it is recommended to not switch tool in one EV_SYN frame
- but first emitting the old BTN_TOOL_<name> at 0, then emit one SYN_REPORT
- and then set the new BTN_TOOL_<name> at 1.
- * BTN_TOUCH:
- BTN_TOUCH is used for touch contact. While an input tool is determined to be
- within meaningful physical contact, the value of this property must be set
- to 1. Meaningful physical contact may mean any contact, or it may mean
- contact conditioned by an implementation defined property. For example, a
- touchpad may set the value to 1 only when the touch pressure rises above a
- certain value. BTN_TOUCH may be combined with BTN_TOOL_<name> codes. For
- example, a pen tablet may set BTN_TOOL_PEN to 1 and BTN_TOUCH to 0 while the
- pen is hovering over but not touching the tablet surface.
- Note: For appropriate function of the legacy mousedev emulation driver,
- BTN_TOUCH must be the first evdev code emitted in a synchronization frame.
- Note: Historically a touch device with BTN_TOOL_FINGER and BTN_TOUCH was
- interpreted as a touchpad by userspace, while a similar device without
- BTN_TOOL_FINGER was interpreted as a touchscreen. For backwards compatibility
- with current userspace it is recommended to follow this distinction. In the
- future, this distinction will be deprecated and the device properties ioctl
- EVIOCGPROP, defined in linux/input.h, will be used to convey the device type.
- * BTN_TOOL_FINGER, BTN_TOOL_DOUBLETAP, BTN_TOOL_TRIPLETAP, BTN_TOOL_QUADTAP:
- - These codes denote one, two, three, and four finger interaction on a
- trackpad or touchscreen. For example, if the user uses two fingers and moves
- them on the touchpad in an effort to scroll content on screen,
- BTN_TOOL_DOUBLETAP should be set to value 1 for the duration of the motion.
- Note that all BTN_TOOL_<name> codes and the BTN_TOUCH code are orthogonal in
- purpose. A trackpad event generated by finger touches should generate events
- for one code from each group. At most only one of these BTN_TOOL_<name>
- codes should have a value of 1 during any synchronization frame.
- Note: Historically some drivers emitted multiple of the finger count codes with
- a value of 1 in the same synchronization frame. This usage is deprecated.
- Note: In multitouch drivers, the input_mt_report_finger_count() function should
- be used to emit these codes. Please see multi-touch-protocol.txt for details.
- EV_REL
- EV_REL events describe relative changes in a property. For example, a mouse may
- move to the left by a certain number of units, but its absolute position in
- space is unknown. If the absolute position is known, EV_ABS codes should be used
- instead of EV_REL codes.
- A few EV_REL codes have special meanings:
- * REL_WHEEL, REL_HWHEEL:
- - These codes are used for vertical and horizontal scroll wheels,
- respectively. The value is the number of detents moved on the wheel, the
- physical size of which varies by device. For high-resolution wheels
- this may be an approximation based on the high-resolution scroll events,
- see REL_WHEEL_HI_RES. These event codes are legacy codes and
- REL_WHEEL_HI_RES and REL_HWHEEL_HI_RES should be preferred where
- available.
- * REL_WHEEL_HI_RES, REL_HWHEEL_HI_RES:
- - High-resolution scroll wheel data. The accumulated value 120 represents
- movement by one detent. For devices that do not provide high-resolution
- scrolling, the value is always a multiple of 120. For devices with
- high-resolution scrolling, the value may be a fraction of 120.
- If a vertical scroll wheel supports high-resolution scrolling, this code
- will be emitted in addition to REL_WHEEL or REL_HWHEEL. The REL_WHEEL
- and REL_HWHEEL may be an approximation based on the high-resolution
- scroll events. There is no guarantee that the high-resolution data
- is a multiple of 120 at the time of an emulated REL_WHEEL or REL_HWHEEL
- event.
- EV_ABS
- EV_ABS events describe absolute changes in a property. For example, a touchpad
- may emit coordinates for a touch location.
- A few EV_ABS codes have special meanings:
- * ABS_DISTANCE:
- - Used to describe the distance of a tool from an interaction surface. This
- event should only be emitted while the tool is hovering, meaning in close
- proximity of the device and while the value of the BTN_TOUCH code is 0. If
- the input device may be used freely in three dimensions, consider ABS_Z
- instead.
- - BTN_TOOL_<name> should be set to 1 when the tool comes into detectable
- proximity and set to 0 when the tool leaves detectable proximity.
- BTN_TOOL_<name> signals the type of tool that is currently detected by the
- hardware and is otherwise independent of ABS_DISTANCE and/or BTN_TOUCH.
- * ABS_PROFILE:
- - Used to describe the state of a multi-value profile switch. An event is
- emitted only when the selected profile changes, indicating the newly
- selected profile value.
- * ABS_MT_<name>:
- - Used to describe multitouch input events. Please see
- multi-touch-protocol.txt for details.
- * ABS_PRESSURE/ABS_MT_PRESSURE:
- - For touch devices, many devices converted contact size into pressure.
- A finger flattens with pressure, causing a larger contact area and thus
- pressure and contact size are directly related. This is not the case
- for other devices, for example digitizers and touchpads with a true
- pressure sensor ("pressure pads").
- A device should set the resolution of the axis to indicate whether the
- pressure is in measurable units. If the resolution is zero, the
- pressure data is in arbitrary units. If the resolution is non-zero, the
- pressure data is in units/gram. For example, a value of 10 with a
- resolution of 1 represents 10 gram, a value of 10 with a resolution of
- 1000 represents 10 microgram.
- EV_SW
- EV_SW events describe stateful binary switches. For example, the SW_LID code is
- used to denote when a laptop lid is closed.
- Upon binding to a device or resuming from suspend, a driver must report
- the current switch state. This ensures that the device, kernel, and userspace
- state is in sync.
- Upon resume, if the switch state is the same as before suspend, then the input
- subsystem will filter out the duplicate switch state reports. The driver does
- not need to keep the state of the switch at any time.
- EV_MSC
- EV_MSC events are used for input and output events that do not fall under other
- categories.
- A few EV_MSC codes have special meaning:
- * MSC_TIMESTAMP:
- - Used to report the number of microseconds since the last reset. This event
- should be coded as an uint32 value, which is allowed to wrap around with
- no special consequence. It is assumed that the time difference between two
- consecutive events is reliable on a reasonable time scale (hours).
- A reset to zero can happen, in which case the time since the last event is
- unknown. If the device does not provide this information, the driver must
- not provide it to user space.
- EV_LED
- EV_LED events are used for input and output to set and query the state of
- various LEDs on devices.
- EV_REP
- EV_REP events are used for specifying autorepeating events.
- EV_SND
- EV_SND events are used for sending sound commands to simple sound output
- devices.
- EV_FF
- EV_FF events are used to initialize a force feedback capable device and to cause
- such device to feedback.
- EV_PWR
- EV_PWR events are a special type of event used specifically for power
- management. Its usage is not well defined. To be addressed later.
- Device properties
- Normally, userspace sets up an input device based on the data it emits,
- i.e., the event types. In the case of two devices emitting the same event
- types, additional information can be provided in the form of device
- properties.
- INPUT_PROP_DIRECT + INPUT_PROP_POINTER
- The INPUT_PROP_DIRECT property indicates that device coordinates should be
- directly mapped to screen coordinates (not taking into account trivial
- transformations, such as scaling, flipping and rotating). Non-direct input
- devices require non-trivial transformation, such as absolute to relative
- transformation for touchpads. Typical direct input devices: touchscreens,
- drawing tablets; non-direct devices: touchpads, mice.
- The INPUT_PROP_POINTER property indicates that the device is not transposed
- on the screen and thus requires use of an on-screen pointer to trace user's
- movements. Typical pointer devices: touchpads, tablets, mice; non-pointer
- device: touchscreen.
- If neither INPUT_PROP_DIRECT or INPUT_PROP_POINTER are set, the property is
- considered undefined and the device type should be deduced in the
- traditional way, using emitted event types.
- INPUT_PROP_BUTTONPAD
- For touchpads where the button is placed beneath the surface, such that
- pressing down on the pad causes a button click, this property should be
- set. Common in Clickpad notebooks and Macbooks from 2009 and onwards.
- Originally, the buttonpad property was coded into the bcm5974 driver
- version field under the name integrated button. For backwards
- compatibility, both methods need to be checked in userspace.
- INPUT_PROP_SEMI_MT
- Some touchpads, most common between 2008 and 2011, can detect the presence
- of multiple contacts without resolving the individual positions; only the
- number of contacts and a rectangular shape is known. For such
- touchpads, the SEMI_MT property should be set.
- Depending on the device, the rectangle may enclose all touches, like a
- bounding box, or just some of them, for instance the two most recent
- touches. The diversity makes the rectangle of limited use, but some
- gestures can normally be extracted from it.
- If INPUT_PROP_SEMI_MT is not set, the device is assumed to be a true MT
- device.
- INPUT_PROP_TOPBUTTONPAD
- Some laptops, most notably the Lenovo 40 series provide a trackstick
- device but do not have physical buttons associated with the trackstick
- device. Instead, the top area of the touchpad is marked to show
- visual/haptic areas for left, middle, right buttons intended to be used
- with the trackstick.
- If INPUT_PROP_TOPBUTTONPAD is set, userspace should emulate buttons
- accordingly. This property does not affect kernel behavior.
- The kernel does not provide button emulation for such devices but treats
- them as any other INPUT_PROP_BUTTONPAD device.
- INPUT_PROP_ACCELEROMETER
- Directional axes on this device (absolute and/or relative x, y, z) represent
- accelerometer data. Some devices also report gyroscope data, which devices
- can report through the rotational axes (absolute and/or relative rx, ry, rz).
- All other axes retain their meaning. A device must not mix
- regular directional axes and accelerometer axes on the same event node.
- Guidelines
- The guidelines below ensure proper single-touch and multi-finger functionality.
- For multi-touch functionality, see the multi-touch-protocol.rst document for
- more information.
- Mice
- REL_{X,Y} must be reported when the mouse moves. BTN_LEFT must be used to report
- the primary button press. BTN_{MIDDLE,RIGHT,4,5,etc.} should be used to report
- further buttons of the device. REL_WHEEL and REL_HWHEEL should be used to report
- scroll wheel events where available.
- Touchscreens
- ABS_{X,Y} must be reported with the location of the touch. BTN_TOUCH must be
- used to report when a touch is active on the screen.
- BTN_{MOUSE,LEFT,MIDDLE,RIGHT} must not be reported as the result of touch
- contact. BTN_TOOL_<name> events should be reported where possible.
- For new hardware, INPUT_PROP_DIRECT should be set.
- Trackpads
- Legacy trackpads that only provide relative position information must report
- events like mice described above.
- Trackpads that provide absolute touch position must report ABS_{X,Y} for the
- location of the touch. BTN_TOUCH should be used to report when a touch is active
- on the trackpad. Where multi-finger support is available, BTN_TOOL_<name> should
- be used to report the number of touches active on the trackpad.
- For new hardware, INPUT_PROP_POINTER should be set.
- Tablets
- BTN_TOOL_<name> events must be reported when a stylus or other tool is active on
- the tablet. ABS_{X,Y} must be reported with the location of the tool. BTN_TOUCH
- should be used to report when the tool is in contact with the tablet.
- BTN_{STYLUS,STYLUS2} should be used to report buttons on the tool itself. Any
- button may be used for buttons on the tablet except BTN_{MOUSE,LEFT}.
- BTN_{0,1,2,etc} are good generic codes for unlabeled buttons. Do not use
- meaningful buttons, like BTN_FORWARD, unless the button is labeled for that
- purpose on the device.
- For new hardware, both INPUT_PROP_DIRECT and INPUT_PROP_POINTER should be set.
input_event信息 主要成员描述。
用来描述event类型,我们本次实验主要会用到以下两个类型,EV_SYN和EV_KEY 两个事件,EV_SYN 用于分割事件标记代表上报按键事件的结束,EV_KEY : 用于描述键盘、按键或其他类似按键设备的状态变化。
- * EV_SYN:
- * EV_KEY:
- devices.
复制代码 根据type 不同含义不同,本次实验会上报按键的code 码。- Event codes
- EV_SYN
- EV_KEY
复制代码 对应的事件的value值,1对应按键按下,0对应按键抬起。
实机验证:
我们在应用层添加如下测试代码,读取event0 节点的event数据,将读取到的数据打印输出。
- #include <stdio.h>
- #include <sys/types.h>
- #include <sys/stat.h>
- #include <fcntl.h>
- #include <linux/input.h>
- #include <unistd.h>
- #include <time.h>
- typedef struct input_event input;
- #define MY_EVENT "/dev/input/event0"
- int main() {
- int fd = -1;
- int ret = -1;
- struct input_event ev = { 0 };
- const int size = sizeof(input);
- fd = open(MY_EVENT, O_RDONLY);
- if (fd < 0) {
- perror("open");
- return -1;
- while (1) {
- ret = read(fd, &ev, size);
- if (ret != size) {
- close(fd);
- return -1;
- printf("type = %x, code = %x, value = %x\n", ev.type, ev.code,
- ev.value);
- struct tm t;
- char date_time[64] = { 0 };
- strftime(date_time, sizeof(date_time), "%Y-%m-%d %H:%M:%S",
- localtime_r(&ev.time.tv_sec, &t));
- printf("gettimeofday: date_time = %s\n", date_time);
- close(fd);
复制代码 将上述程序交叉编译后上板运行输出结果如下。
上面log里的type 值分别为0和1,从如下代码type 的定义说明(myir-ti-linux-myd-am62x-linux-6.1.46\include\uapi\linux\input-event-codes.h)可知对应的分别为EV_SYN 和 EV_KEY 事件- /*
- * Event types
- #define EV_SYN 0x00
- #define EV_KEY 0x01
- #define EV_REL 0x02
- #define EV_ABS 0x03
- #define EV_MSC 0x04
- #define EV_SW 0x05
- #define EV_LED 0x11
- #define EV_SND 0x12
- #define EV_REP 0x14
- #define EV_FF 0x15
- #define EV_PWR 0x16
- #define EV_FF_STATUS 0x17
- #define EV_MAX 0x1f
- #define EV_CNT (EV_MAX+1)
从上述的输出的日志可知对应的code值定义为0x100,这个值是在哪定义的呢,从设备树的gpio_key 节点可知,定义的值为linux,code = <BTN_0>。- gpio-keys {
- compatible = "gpio-keys";
- autorepeat;
- pinctrl-names = "default";
- pinctrl-0 = <&main_user_key_pins_default>;
- user: user {
- label = "GPIO Key USER1";
- linux,code = <BTN_0>;
- gpios = <&main_gpio0 36 GPIO_ACTIVE_LOW>;
复制代码 从上述的节点可知对应的linux,code = <BTN_0> 按键值定义的为BTN_0 从include\uapi\linux\input-event-codes.h 定义的button 键值可知BTN_0 定义的为0x100。
- /* Code 255 is reserved for special needs of AT keyboard driver */
- #define BTN_MISC 0x100
- #define BTN_0 0x100
- #define BTN_1 0x101
- #define BTN_2 0x102
- #define BTN_3 0x103
- #define BTN_4 0x104
- #define BTN_5 0x105
- #define BTN_6 0x106
- #define BTN_7 0x107
- #define BTN_8 0x108
- #define BTN_9 0x109
- #define BTN_MOUSE 0x110
- #define BTN_LEFT 0x110
- #define BTN_RIGHT 0x111
- #define BTN_MIDDLE 0x112
- #define BTN_SIDE 0x113
- #define BTN_EXTRA 0x114
- #define BTN_FORWARD 0x115
- #define BTN_BACK 0x116
- #define BTN_TASK 0x117
- #define BTN_JOYSTICK 0x120
- #define BTN_TRIGGER 0x120
- #define BTN_THUMB 0x121
- #define BTN_THUMB2 0x122
- #define BTN_TOP 0x123
- #define BTN_TOP2 0x124
- #define BTN_PINKIE 0x125
- #define BTN_BASE 0x126
- #define BTN_BASE2 0x127
- #define BTN_BASE3 0x128
- #define BTN_BASE4 0x129
- #define BTN_BASE5 0x12a
- #define BTN_BASE6 0x12b
- #define BTN_DEAD 0x12f
- #define BTN_GAMEPAD 0x130
- #define BTN_SOUTH 0x130
- #define BTN_A BTN_SOUTH
- #define BTN_EAST 0x131
- #define BTN_B BTN_EAST
- #define BTN_C 0x132
- #define BTN_NORTH 0x133
- #define BTN_X BTN_NORTH
- #define BTN_WEST 0x134
- #define BTN_Y BTN_WEST
- #define BTN_Z 0x135
- #define BTN_TL 0x136
- #define BTN_TR 0x137
- #define BTN_TL2 0x138
- #define BTN_TR2 0x139
- #define BTN_SELECT 0x13a
- #define BTN_START 0x13b
- #define BTN_MODE 0x13c
- #define BTN_THUMBL 0x13d
- #define BTN_THUMBR 0x13e
- #define BTN_DIGI 0x140
- #define BTN_TOOL_PEN 0x140
- #define BTN_TOOL_RUBBER 0x141
- #define BTN_TOOL_BRUSH 0x142
- #define BTN_TOOL_PENCIL 0x143
- #define BTN_TOOL_AIRBRUSH 0x144
- #define BTN_TOOL_FINGER 0x145
- #define BTN_TOOL_MOUSE 0x146
- #define BTN_TOOL_LENS 0x147
- #define BTN_TOOL_QUINTTAP 0x148 /* Five fingers on trackpad */
- #define BTN_STYLUS3 0x149
- #define BTN_TOUCH 0x14a
- #define BTN_STYLUS 0x14b
- #define BTN_STYLUS2 0x14c
- #define BTN_TOOL_DOUBLETAP 0x14d
- #define BTN_TOOL_TRIPLETAP 0x14e
- #define BTN_TOOL_QUADTAP 0x14f /* Four fingers on trackpad */
- #define BTN_WHEEL 0x150
- #define BTN_GEAR_DOWN 0x150
- #define BTN_GEAR_UP 0x151
根据上面的定义,我们更新下DTS文件,修改键值定义为BTN_1
源码目录下输入make dtbs 编译DTB文件,发现会更新如下dtb 文件,我们更新6252的至我们的开发板
更新开发板后再次运行之前的event函数,查看下按键的键值是否按照预期的发生改变,运行结果如下:
更新后发现event 的code 值已经按照预期的由BTN_0(0x100)更新为BTN_1(0x101)
