查看: 2007|回复: 0
[项目分享] 【N32G430开发板】+ usart shell移植
    慵懒
    2025-1-7 21:17
  • 签到天数: 775 天
    发表于 2023-9-14 15:28:02 | 显示全部楼层 |阅读模式
       上次玩了一下N32G430开发板点亮了led灯,这次就试试串口。实现串口的发送接收。然后尝试移植了nr_micro_shell。
    移植shell首先要把串口发送接收搞定。
    下面就是我使用USART1测试,初始化USART1如下:使用中断接收串口数据,这样就不会丢失数据了。
    1. void uart_init(void)
    2. {
    3.     GPIO_InitType GPIO_InitStructure;
    4.     USART_InitType USART_InitStructure;
    5.     NVIC_InitType NVIC_InitStructure;
    6.     RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOA);
    7.     RCC_APB2_Peripheral_Clock_Enable(RCC_APB2_PERIPH_AFIO | RCC_APB2_PERIPH_USART1);
    8.     GPIO_Structure_Initialize(&GPIO_InitStructure);
    9.     GPIO_InitStructure.Pin            = GPIO_PIN_9;
    10.     GPIO_InitStructure.GPIO_Mode      = GPIO_MODE_AF_PP;
    11.     GPIO_InitStructure.GPIO_Alternate = GPIO_AF5_USART1;
    12.     GPIO_Peripheral_Initialize(GPIOA, &GPIO_InitStructure);
    13.     GPIO_InitStructure.Pin             = GPIO_PIN_10;
    14.     GPIO_InitStructure.GPIO_Alternate  = GPIO_AF5_USART1;
    15.     GPIO_Peripheral_Initialize(GPIOA, &GPIO_InitStructure);
    16.     USART_InitStructure.BaudRate            = 115200;
    17.     USART_InitStructure.WordLength          = USART_WL_8B;
    18.     USART_InitStructure.StopBits            = USART_STPB_1;
    19.     USART_InitStructure.Parity              = USART_PE_NO;
    20.     USART_InitStructure.HardwareFlowControl = USART_HFCTRL_NONE;
    21.     USART_InitStructure.Mode                = USART_MODE_TX | USART_MODE_RX;
    22.     /* init uart */
    23.     USART_Initializes(USART1, &USART_InitStructure);
    24.     /* enable uart */
    25.     USART_Enable(USART1);
    26.
    27.     USART_Interrput_Enable(USART1, USART_INT_RXDNE);
    28. //    USART_Interrput_Enable(USART1, USART_INT_TXDE);
    29.     NVIC_Priority_Group_Set(NVIC_PER2_SUB2_PRIORITYGROUP);
    30.     /* Enable the USARTy Interrupt */
    31.     NVIC_InitStructure.NVIC_IRQChannel                   = USART1_IRQn;
    32.     NVIC_InitStructure.NVIC_IRQChannelSubPriority        = 0;
    33.     NVIC_InitStructure.NVIC_IRQChannelCmd                = ENABLE;
    34.     NVIC_Initializes(&NVIC_InitStructure);
    35.
    36. }
    为了方便接收数据,下面封装了简单的FIFO缓存,用于串口接收。
    1. typedef struct fifo_buffer
    2. {
    3.     volatile uint32_t    read_i;
    4.     volatile uint32_t    write_i;
    5.     uint8_t     buff[128];
    6. }fifo_buffer;
    7. fifo_buffer  uart_rx = {
    8.     .read_i = 0,
    9.     .write_i = 0,
    10. };
    11. fifo_buffer  uart_tx = {
    12.     .read_i = 0,
    13.     .write_i = 0,
    14. };
    15. void fifo_init(fifo_buffer *fifo)
    16. {
    17.     fifo->read_i = 0;
    18.     fifo->write_i = 0;
    19. }
    20. int fifo_push(fifo_buffer *fifo, uint8_t ch)
    21. {
    22.     if(((fifo->write_i+1)&0x7f) != fifo->read_i)
    23.     {
    24.         fifo->buff[fifo->write_i++] = ch;
    25.         fifo->write_i &= 0x7f;
    26.         return 0;
    27.     }else return 1; //full
    28. }
    29. int fifo_pop(fifo_buffer *fifo, uint8_t *ch)
    30. {
    31.     if(fifo->read_i != fifo->write_i)
    32.     {
    33.         *ch = fifo->buff[fifo->read_i++];
    34.         fifo->read_i &= 0x7f;
    35.         return 0;
    36.     }else return 1; //empty
    37. }
    串口中断如下:将接收的数据存入FIFO缓存,然后在主循环中取出数据。
    1. void USART1_IRQHandler(void)
    2. {
    3.     uint8_t ch;
    4.     if (USART_Interrupt_Status_Get(USART1, USART_INT_RXDNE) != RESET)
    5.     {
    6.         /* Read one byte from the receive data register */
    7.         ch = USART_Data_Receive(USART1);
    8.         fifo_push(&uart_rx,ch);
    9.     }
    10. //    if (USART_Interrupt_Status_Get(USART1, USART_INT_TXDE) != RESET)
    11. //    {
    12. //        /* Write one byte to the transmit data register */
    13. //        if(fifo_pop(&uart_tx,&ch) == 0)
    14. //        {
    15. //            USART_Data_Send(USART1, ch);
    16. //        }
    17. //    }
    18. }
    串口发送,重定向到printf输出。
    1. int stdout_putchar (int ch)
    2. {
    3.     while (0 == USART_Flag_Status_Get(USART1,USART_FLAG_TXDE));
    4.     USART_Data_Send(USART1, ch);
    5.     return ch;
    6. }
    7. int fputc(int ch,FILE *f)
    8. {
    9.     return stdout_putchar(ch);
    10. }
    可以通过如下程序测试一下发送接收数据:将接收的数据重新发送出去。测试完成OK后,就可以进行nr_micro_shell移植了。
    1. int main(void)
    2. {
    3.     uint8_t ch;
    4.     SysTick_Config(SystemClockFrequency/1000);
    5.     /* Initialize Led1~Led3 as output push-pull mode */
    6.     LED_Initialize(LED1_GPIO_PORT, LED1_GPIO_PIN | LED2_GPIO_PIN );
    7.     /* Turn off Led1~Led3 */
    8.     LED_Off(LED1_GPIO_PORT, LED1_GPIO_PIN | LED2_GPIO_PIN );
    9.
    10.     uart_init();
    11.     printf("N32G430 USART1 TEST.\r\n");
    12.
    13.     while(1)
    14.     {
    15.         if(fifo_pop(&uart_rx,&ch) == 0)
    16.         {
    17.             LED_Toggle(LED2_GPIO_PORT, LED2_GPIO_PIN);
    18.             stdout_putchar(ch);
    19.         }
    20.     }
    21. }
    下面开始移植nr_micro_shell。首先下载shell源码,将源码添加到工程中:
    添加源码头文件路径
    然后配置shell功能,配置在nr_micro_shell_config.h文件中。主要配置串口shell输出打印函数
    下一步就是初始化shell以及读取串口接收数据并传给shell解析。
    然后编译下载即可。烧写成功后,打开串口测试一下。
    程序:
    n32_g430.zip (1.4 MB, 下载次数: 0)
    GMT+8, 2025-1-20 01:13 , Processed in 0.115297 second(s), 16 queries , MemCache On.
