查看: 1455|回复: 0
[评测分享] 【灵动Motor-DK电机控制板】2、串口printf输出及中断接收
    半小时前
  • 签到天数: 1970 天
    连续签到: 26 天
    [LV.Master]伴坛终老
    发表于 2023-7-22 15:59:45 | 显示全部楼层 |阅读模式
       本次实验测试一下串口的发送接收。方便后面输出调试信息。
    首先找到串口端口,PA11和PA12。
    找到PA11和PA12的复用功能表,可以看到是AF5组复用功能对应USART1.
    下面初始化串口端口:
    1. void PLATFORM_InitConsole(uint32_t Baudrate)
    2. {
    3.     GPIO_InitTypeDef  GPIO_InitStruct;
    4.     USART_InitTypeDef USART_InitStruct;
    5.     RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
    6.     GPIO_PinAFConfig(GPIOA, GPIO_PinSource11, GPIO_AF_5);
    7.     GPIO_PinAFConfig(GPIOA, GPIO_PinSource12, GPIO_AF_5);
    8.     GPIO_StructInit(&GPIO_InitStruct);
    9.     GPIO_InitStruct.GPIO_Pin   = GPIO_Pin_11 | GPIO_Pin_12;
    10.     GPIO_InitStruct.GPIO_Speed = GPIO_Speed_High;
    11.     GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_AF_PP;
    12.     GPIO_Init(GPIOA, &GPIO_InitStruct);
    13.
    14.
    15.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART1, ENABLE);
    16.     USART_StructInit(&USART_InitStruct);
    17.     USART_InitStruct.USART_BaudRate   = Baudrate;
    18.     USART_InitStruct.USART_WordLength = USART_WordLength_8b;
    19.     USART_InitStruct.USART_StopBits   = USART_StopBits_1;
    20.     USART_InitStruct.USART_Parity     = USART_Parity_No;
    21.     USART_InitStruct.USART_Mode       = USART_Mode_Tx|USART_Mode_Rx;
    22.     USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    23.     USART_Init(USART1, &USART_InitStruct);
    24.     USART_Cmd(USART1, ENABLE);
    25.
    26.     //使能UARTx RC中断
    27.     USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    28.     //优先级,无优先级分组
    29.     NVIC_SetPriority(USART1_IRQn, 0);
    30.     //UARTx中断使能
    31.     NVIC_EnableIRQ(USART1_IRQn);
    32. }
    映射到printf输出:
    1. int stdout_putchar (int ch)
    2. {
    3.     USART_SendData(USART1, (uint8_t)ch);
    4.     while (RESET == USART_GetFlagStatus(USART1, USART_FLAG_TC)){;}
    5.     return (ch);
    6. }
    7. int fputc(int ch,FILE *f)
    8. {
    9.     return stdout_putchar(ch);
    10. }
    中断接收数据,通过FIFO缓存:
    1. typedef struct fifo_buffer
    2. {
    3.     volatile uint32_t    read_i;
    4.     volatile uint32_t    write_i;
    5.     uint8_t     buff[128];
    6. }fifo_buffer;
    7. extern fifo_buffer  shell_uart_rx;
    8. fifo_buffer  shell_uart_rx=
    9. {
    10.     .read_i = 0,
    11.     .write_i = 0,
    12. };
    13. void USART1_IRQHandler(void)
    14. {
    15.     uint32_t statusFlag;
    16.     uint32_t ch;
    17.
    18.     statusFlag = USART1->SR;
    19.     if((statusFlag & USART_IT_RXNE) != 0)
    20.     {
    21.         ch = USART_ReceiveData(USART1);
    22.         if(((shell_uart_rx.write_i+1)&0x7f) != shell_uart_rx.read_i)
    23.         {
    24.             shell_uart_rx.buff[shell_uart_rx.write_i++] = ch & 0xff;
    25.             shell_uart_rx.write_i &= 0x7f;
    26.         }
    27.     }
    28.     USART1->SR &= ~statusFlag;
    29. }
    测试接收数据,将接收的数据重复发送出来。
    1. void shell_usart_loop(void)
    2. {
    3.     if(shell_uart_rx.read_i != shell_uart_rx.write_i)
    4.     {
    5.         stdout_putchar(shell_uart_rx.buff[shell_uart_rx.read_i++]);
    6.         shell_uart_rx.read_i &= 0x7f;
    7.     }
    8. }
    1. void GPIO_LED_Toggle_Sample(void)
    2. {
    3.     printf("\r\nTest %s", __FUNCTION__);
    4.     GPIO_Configure();
    5.     while (1)
    6.     {
    7.         GPIO_IO_Toggle(GPIOB, GPIO_Pin_9);
    8.         shell_usart_loop(); //串口接收并发送
    9.         PLATFORM_DelayMS(100);
    10.     }
    11. }
    GMT+8, 2024-11-22 10:04 , Processed in 0.120542 second(s), 17 queries , MemCache On.
