都是AES上的文章.
1.
Oversampled Analogue-to-Digital Conversion for Digital Audio Systems
A Stereo 16-Bit Delta-Sigma AD Converter for Digital Audio
Higher Order One Bit Coder for Audio Applications
Design and Implementation of an Audio 18-Bit Analog-to-Digital Converter Using Oversampling Techniques
2. Theory and Practical Implementation of a 5th-Order Sigma-Delta AD Converter
A Fifth-Order Delta-Sigma Modulator with 110 dB Audio-Band Dynamic Range
Techniques to Measure and Maximize the Performance of a 120 dB, 24-Bit, 96-kHz AD Converter Integrated Circuit
Mismatch-Shaping Digital-to-Analog Conversion
3.
Optimizing the Performance of 20-Bit Audio ADCs
Psychoacoustically Optimal Sigma-Delta Modulation
A 116 dB SNR Multi-Bit Noise-Shaping DAC with 192 kHz Sample Rate
A Stereo 24-bit Audio Digital-to-Analog Converter with 120 dB Dynamic Range
4.
A Single-Chip Three-Channel 112 dB Audio DAC with Audio dsp Capability
A Low-Cost, All-SMD Chip Set for High-Performance, True-Digital Audio Power Amplification Class D Audio Power Amplifiers
A New Approach to Effective Dither in Delta-Sigma Modulation Systems
