查看: 340|回复: 0
[经验] 斜坡补偿的经典文献
发表于 2023-2-14 12:15:22 | 显示全部楼层 |阅读模式
MODELLING, ANALYSIS AND COMPENSATION OF THE CURRENT-MODE CONVERTER
As current-mode conversion increases in popularity, several peculiarities associated with fixed-frequency, peak-current detecting schemes have surfaced These include instability above 50% duty cycle, a tendency towards subharmonic oscillation, non-ideal loop response, and an increased sensitivity to noise. This paper will attempt to show that the performance of any current-mode converter can be improved and at the same time all of the above problems reduced or eliminated by adding a fixed amount of “slope compensation” to the sensed current waveform。
斜坡补偿.pdf
186.37 KB, 下载次数: 2
GMT+8, 2024-11-22 18:09 , Processed in 0.122928 second(s), 16 queries , MemCache On.
