查看: 1525|回复: 0
[评测分享] 【Silicon Labs EFR32xG24 开发套件】+创建工程点灯
    3 天前
  • 签到天数: 642 天
    连续签到: 3 天
    发表于 2022-12-19 00:03:14 | 显示全部楼层 |阅读模式
    下面准备创建新工程开发测试。选择一个点灯demo进行创建新工程。点击CREATE.
    正在生成工程代码。
    下面是生成好的代码了。
    先编译一下,看看效果。
    结果到最后链接蓝牙lib库文件出现了错误,对lib库文件不识别了。
    唉,找了半天没头绪了。。。。。
    d:/siliconlabs/simplicitystudio-v5/developer/toolchains/gnu_arm/10.3_2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe:E:/Silicon_Labs/gecko_sdk-gsdk_4.2//protocol/bluetooth/lib/EFR32MG24/GCC/libbluetooth.a: file format not recognized; treating as linker script
    d:/siliconlabs/simplicitystudio-v5/developer/toolchains/gnu_arm/10.3_2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe:E:/Silicon_Labs/gecko_sdk-gsdk_4.2//protocol/bluetooth/lib/EFR32MG24/GCC/libbluetooth.a:1: syntax error
    collect2.exe: error: ld returned 1 exit status
    make: *** [makefile:79: bt_soc_blinky_2.axf] Error 1
    "make -j4 all" terminated with exit code 2. Build might be incomplete.
    GMT+8, 2025-1-27 08:55 , Processed in 0.112250 second(s), 17 queries , MemCache On.
