查看: 535|回复: 0
[经验] 斜坡补偿的经典文献
发表于 2022-12-17 16:19:04 | 显示全部楼层 |阅读模式
As current-mode conversion increases in popularity, several peculiarities associated with fixed-frequency, peak-currentdetecting schemes have surfaced These include instability above 50% duty cycle, a tendency towards subharmonicoscillation, non-ideal loop response, and an increased sensitivity to noise. This paper will attempt to show that theperformance of any current-mode converter can be improved and at the same time all of the above problems reduced oreliminated by adding a fixed amount of “slope compensation” to the sensed current waveform.
斜坡补偿.pdf
186.37 KB, 下载次数: 0
GMT+8, 2024-11-23 08:42 , Processed in 0.113020 second(s), 16 queries , MemCache On.
