查看: 478|回复: 0
打印 上一主题 下一主题
[经验] 电流环路控制方法的快速响应LDO
跳转到指定楼层
楼主
发表于 2022-11-28 21:49:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Abstract: A transient performance optimized CCL-LDO regulator is proposed. In the CCL-LDO, the controlmethod of the charge pump phase-locked loop is adopted. A current control loop has the feedback signal andreference current to be compared, and then a loop filter generates the gate voltage of the power MOSFET by integrating the error current. The CCL-LDO has the optimized damping coefficient and natural resonant frequency,while its output voltage can be sub-1-V and is not restricted by the reference voltage. With a 1 F decouplingcapacitor, the experimental results based on a 0.13 m CMOS process show that the output voltage is 1.0 V; whenthe workload changes from 100 A to 100 mA transiently, the stable dropout is 4.25 mV, the settling time is 8.2 sand the undershoot is 5.11 mV; when the workload changes from 100 mA to 100 A transiently, the stable dropoutis 4.25 mV, the settling time is 23.3 s and the overshoot is 6.21 mV. The PSRR value is more than
电流环路控制方法的快速响应LDO.pdf
1.26 MB, 下载次数: 0
举报
站长推荐上一条 3/5 下一条
【预约|参会享"豪"礼】2025慕尼黑上海设备展
查看 »
GMT+8, 2025-4-30 06:04 , Processed in 0.110914 second(s), 18 queries , MemCache On.
