查看: 831|回复: 0
SL1588降压恒压 DC12V降压5V 3.3V/ 2A同步降压恒压芯片
    慵懒
    2023-7-20 10:52
  • 签到天数: 6 天
    发表于 2022-11-11 10:30:08 | 显示全部楼层 |阅读模式
    18V2A500 KHz同步降压调节器方案:低功耗同步降压恒压IC
    18V 2A 500KHz Synchronous Step-Down Regulator
    General Description
    The SL1588 is a high frequency, synchronous, rectified, step-down, switch-mode converter with internal power
    MOSFETs. It offers a very compact solution to achieve a 3A peak output current over a wide input supply range,
    with excellent load and line regulation.
    The SL1588 requires a minimal number of readily available, external components and is available in a space saving
    SOT23-6 package.
    Features
    • Wide 4V to 18V Operating Input Range
    • 2A Continuous Output Current
    • 500kHz Switching Frequency
    • Short Protection with Hiccup-Mode
    • Built-in Over Current Limit
    • Built-in Over Voltage Protection
    • Internal Power-Save Mode (PFM/PWM)
    • Internal Soft-Start
    • Output Adjustable from 0.8V
    • No Schottky Diode Required
    • Integrated internal compensation
    • Thermal Shutdown
    • Available in SOT23-6 Package
    • -40°C to +85°C Temperature Range
    Applications
    • Digital Set-top Box (STB)
    • Tablet Personal Computer (Pad)
    • Flat-Panel Television and Monitor
    • Wi-Fi Router / AP
    • Digital Video Recorder (DVR)
    • Portable Media Player (PMP)
    • Cable Modem / XDSL
    • General Purposes
    Typical Application Circuit
    GMT+8, 2024-12-30 04:04 , Processed in 0.118199 second(s), 15 queries , MemCache On.
