查看: 376|回复: 0
打印 上一主题 下一主题
[经验] 经典带隙设计
跳转到指定楼层
楼主
发表于 2022-11-10 16:48:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Abstract — This paper describes the design of a precision on-chip bandgap voltage reference for applications with CMOS analog circuits. Thecircuit uses naturally occurring vertical n-p-n bipolar transistors as reference diodes. P-tub diffusions are nsed as temperature-dependent resistorsto provide current bias, and an op-amp is used for voltage gain. The circuitis simple. Only two reference diodes, three p-tub resistors, and one op-ampare necessary to produce a reference with fixed voltage of – 1.3 V. An
additional op-amp with two p-tnb resistors will adjust the output to any desired value
绝好的经典带隙设计.pdf
984.99 KB, 下载次数: 0
举报
站长推荐上一条 2/5 下一条
「工聚四方·创见未来」欧时RS入驻四方维创新中心线下沙龙
查看 »
GMT+8, 2025-4-30 03:45 , Processed in 0.112103 second(s), 18 queries , MemCache On.
