查看: 630|回复: 0
[评测分享] 【飞凌RZG2L开发板测评】- 测试
  • 签到天数: 16 天
    [LV.4]偶尔看看III
    发表于 2022-10-25 20:39:58 | 显示全部楼层 |阅读模式
    1. ATF版本信息
    1. NOTICE:  Auth Success!
    2. NOTICE:  BL2: v2.5(release):v1.1
    3. NOTICE:  BL2: Built : 01:00:50, May 23 2022
    4. NOTICE:  BL2: Booting BL31
    5. NOTICE:  BL31: v2.5(release):v1.1
    6. NOTICE:  BL31: Built : 01:00:51, May 23 2022
    2. Uboot版本信息
    1. U-Boot 2020.10 (May 23 2022 - 01:01:36 +0000)
    2. CPU: Renesas Electronics E rev 16.15
    3. Model: OKG2L-C
    4. DRAM:  1.9 GiB
    5. MMC:   sh-sdhi: 0, sh-sdhi: 1
    6. Loading Environment from MMC... *** Warning - bad CRC, using default environment
    7. In:    serial@1004b800
    8. Out:   serial@1004b800
    9. Err:   serial@1004b800
    10. Net:
    11. Error: ethernet@11c20000 address not set.
    12. No ethernet found.
    13. Autoboot in 1 seconds
    14. Card did not respond to voltage select!
    15. 15555072 bytes read in 693 ms (21.4 MiB/s)
    16. 30186 bytes read in 19 ms (1.5 MiB/s)
    17. ## Flattened Device Tree blob at 48000000
    18.    Booting using the fdt blob at 0x48000000
    19.    Loading Device Tree to 00000000bbf30000, end 00000000bbf3a5e9 ... OK
    20. Starting kernel ...
    3. Linux版本信息
    用户名: root 密码: 无密码
    1. root@okg2l:~# uname -a
    2. Linux okg2l 4.19.165-cip41-arm64-renesas #1 SMP PREEMPT Mon Jun 13 02:34:03 UTC 2022 aarch64 GNU/Linux
    4. 系统实时性测试
    1. [        DISCUZ_CODE_543        ]nbsp;git clone https://git.kernel.org/pub/scm/utils/rt-tests/rt-tests.git -b v0.92 # 下载源码
    5. **带宽测试
    1. # 此处的IP是主机的地址,在主机上需要用iperf3 -s运行一个服务器
    # 总结
    由于时间比较紧,目前只能进行这些测试,后续有时间继续更新其他外设测试.
    不过从目前这些测试的数据来看系统实时性还是可以的,后续还能打上prermpt rt补丁提升实时性
    **也能满足很多场景需求,也有可能是我的路由器为百兆,导致只能测试出百兆性能
    GMT+8, 2025-1-12 07:00 , Processed in 0.101584 second(s), 16 queries , MemCache On.
