查看: 418|回复: 0
打印 上一主题 下一主题
[经验] ADC Design for Non-uniform Quantization
跳转到指定楼层
楼主
发表于 2022-10-17 12:33:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The thesis demonstrates a low-cost, low-bandwidth and low-resolution Analog-to-Digital Converter(ADC) in 0.35 um CMOS Process. A second-order Sigma-Delta modulator is used as the basis of the A/D Converter. A Semi-Uniform quantizer is used with the
modulator to take advantage of input distributions that are dominated by smalleramplitude signals e.g. Audio, Voice and Image-sensor signals. A Single-bit feedback topology is used with a multi-bit quantizer in the modulator. This topology avoids the use of a multi-bit DAC in the feedback loop – hence the system does not need to use digital correction techniques to compensate for a multi-bit DAC non-linearity. This attribute of the of the A/D Converter contributes to the low-cost aspect.
ADC_non-uniform_quantization.rar
1.27 MB, 下载次数: 0
举报
站长推荐上一条 2/4 下一条
【预约|参会享"豪"礼】2025慕尼黑上海设备展
查看 »
GMT+8, 2025-4-8 23:20 , Processed in 0.100421 second(s), 18 queries , MemCache On.
