查看: 347|回复: 0
打印 上一主题 下一主题
[经验] Power-Efficient Metastability Error Reduction in CMOS Flash AD Converters
跳转到指定楼层
楼主
发表于 2022-10-17 12:23:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Abstruct- A power and area efficient technique to reduce metastability errors in high-speed Hash A/D converters is described. Pipelining to reduce error rates in an n-bit Hash converter is accomplished with a bit pipeline scheme requiring n latches per pipeline stage instead of 2” - 1. A 7-b, 80- MHz prototype converter is implemented in 1.2-pm CMOS with measured metastability error rates of less than lo-’’ errorskycle. The measured power is 307.2 mW with an 80-MHz sampling frequency. Without metastability error reduction circuitry, the estimated metastability error rate for the converter is 10W4 errorskycle. Achieving an equivalent error rate with two pipeline stages of 2” - 1 latches would require 3.48 times the power for the metastability error reduction circuitry. This corresponds to a reduction in total power by a factor of 1.24 compared with the comparator pipelined converter for Nyquist frequency inputs.
Power-Efficient Metastability Error Reduction in CMOS Flash AD Converters.pdf
1.28 MB, 下载次数: 0
举报
站长推荐上一条 3/5 下一条
【预约|参会享"豪"礼】2025慕尼黑上海设备展
查看 »
GMT+8, 2025-4-30 04:38 , Processed in 0.111250 second(s), 18 queries , MemCache On.
