查看: 991|回复: 0
打印 上一主题 下一主题
[经验] Design of Low power Parallel Pipeline ADC
跳转到指定楼层
楼主
发表于 2022-10-16 21:28:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Abstract- This work describes a 9bit 200MSPS 0.18J1m CMOS process four-stage parallel pipeline ADC with 2.5 bit per stage. Primary objective of the design has been to make a trade-off between power consumption and resolution while keeping the sampling rate high. The parallel-pipeline architecture was best fit for such requirements. A new sub-ADC scheme has been introduced here to remove possible switch generated charge injection error in order to maintain good overall accuracy. The designed ADC in this paper employs parallel architecture based on double sampling sample hold topology (DSSH) and shares the OTA between the same stages of two channels of the ADC. The ADC achieves 55.5dB SNDR and 41.3dB SFDR with 29.5mW power consumption from 1.8 V supply. The resulting FOM is 0.304 PJ/conversion step. The high speed specification of the system requires the design of low offset comparator.
Design of Low power Parallel Pipeline ADC.pdf
1.52 MB, 下载次数: 0
举报
站长推荐上一条 4/4 下一条
2025智能制造赋能产业发展论坛
大会将围绕智能感知在智能制造中的具体实践、智能能效管理打造绿色工厂等方向展开研讨。同时主办方还邀请多位行业领域顶尖的代表参会,分享前沿数字化技术及应用解决方案。参会还有精美伴手礼和活动抽奖~
查看 »
GMT+8, 2025-4-15 17:13 , Processed in 0.101773 second(s), 18 queries , MemCache On.
