查看: 1596|回复: 0
打印 上一主题 下一主题
bananapi
跳转到指定楼层
楼主
发表于 2022-10-14 09:23:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
BPI-R2 Pro[size=0.9]
[url=]BPI-R2 Pro[/url][url=]Hardware spec[/url][url=]Hardware interface[/url][url=]Getting started guide[/url][url=]Android/Linux[/url][url=]Load the image on eMMC[/url][url=]Preparation[/url][url=]Install image with USB Download tool[/url][url=]Boot from eMMC[/url][url=]Install the image to a SD card[/url]
Hardware spec
Components
Parameters
CPU
Rockchip RK3568 Quad-core ARM Cortex-A55 CPU 2GHz
GPU
Mali-G52 1-Core-2EE OpenGL ES3.2 Vu1kn 1.1 OpenCL 2.0
Memory
2G DDR3 SDRAM (option 4G)
Storage
Onboard 16GB eMMC Flash, Micro SD-Card slot, SATA 3.0 Port,SPI flash
Network
5 x 10/100/1000 Mbit/s Ethernet
Display
1 HDMI port, 2 DSI interface(1 DSI can change to LVDS by software)
Camera
1 CSI camera interfact
Audio output
HDMI & I2S & Speaker & Headphone
USB port
USB 3.0 PORT (x2), micro USB OTG (x1)
Mini PCIE
1 mini pcie interface & 1 M.2 key-e interface
Remote
IR Receiver (x1)
Power source
12 volt @2A via DC Power and/or Micro USB (OTG)
OS
OpenWRT, Linux and others OS
Hardware interface
Getting started guideAndroid/LinuxLoad the image on eMMCPreparation
  • Double male USB data cable for image download or abd debug.
  • MicroUSB cable or usb to ttl cable if you need console debug message print, default baudrate is 1500000.
  • Windows PC.
  • Download the latest OS image, and confirm that the md5 checknum is correct before flashing.
This tool defaults language is Chinese. You can change it to English after extract the package. Open RKDevTool_Release_v2.84/config.ini with an text editor (like notepad). The starting lines are:
#Language Selection: Selected=1(Chinese); Selected=2(English)
[Language]
Kinds=2
Selected=1
LangPath=Language\
  • Open RKDevTool.exe, Switch to the “upgrade firmware” page. Press the “firmware” button to open the image file to be upgraded. The upgrade tool displays detailed firmware information.
  • Disconnect power adapter, connect dual male usb cable from the top usb host port to PC.
  • There have two usb download mode for image upgrade.
  • Uboot USB Download Mode (loader mode)
It's supposed to use this way if board already flashed a bootable uboot before.
  • Maskrom USB Download Mode (maskrom mode)
Press the Recovery button or Maskrom button beside 3pin uart header and hold, connect the power adapter or press the RST button if power adapter already connected, about two seconds later, release the button. PC will Identify the device if RK usb driver installed correctly.
The download tool also show the download mode if device connected.
  • Press the "upgrade" button to start the upgrade.
  • If the upgrade fails, yu can try to erase the eMMC by clicking on te "EraseFlash" button, and upgrade image again.
Boot from eMMC
Power on and establish a new serial session on MobaXter.
  • The port is COM5 CH340.
  • The speed we choose 1500000.
  • Download the Rockchip SDDiskTool.
  • Connect SD card reader to Windows PC. The size of micro SD card should be at least 8GB.
  • Run SD_Firmaware_Tool, check the "Upgrade Firmware"  box and select the correct removable disk device. Choose firmware image, then click on "Create" button to make it and wait until it is finshed.
  • Safely remove the microSD card, insert it into the R2Pro board, power on the board, it will start upgrading automatically.
  • After upgrading, it will prompt you to remove the SD card.
  • Remove the card and wait for bootup.
举报
站长推荐上一条 2/4 下一条
【预约|参会享"豪"礼】2025慕尼黑上海设备展
查看 »
GMT+8, 2025-4-3 13:37 , Processed in 0.105120 second(s), 17 queries , MemCache On.
