查看: 540|回复: 0
打印 上一主题 下一主题
[经验] A Low Noise CMOS Voltage Reference
跳转到指定楼层
楼主
发表于 2022-10-9 19:44:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Recent research in CMOS integrated noise generators has resulted in the development of components that make possible the design of a high performance linear CMOS bandgap reference with low output noise. The effects of output noise on the performance of previously reported CMOS bandgap references are calculated and compared, and a low noise linear CMOS bandgap reference is proposed, simulated,
fabricated, and tested. This circuit uses lateral bipolar transistors as floating p-n diodes and differential input devices to create a low noise bandgap reference with a temperature coefficient comparable to previous CMOS bangap circuits and output noise nearly an
order of magnitude lower. The operation and performance of these lateral bipolar transistors and the low noise amplifiers built from them are discussed. A new method of higher-order temperature coefficient compensation for bandgap references is also derived and simulated。
A Low Noise CMOS Voltage Reference.pdf
1.09 MB, 下载次数: 0
举报
站长推荐上一条 1/5 下一条
有奖活动|英飞凌智能座舱直播活动
查看 »
GMT+8, 2025-4-30 08:53 , Processed in 0.112745 second(s), 18 queries , MemCache On.
