查看: 477|回复: 0
打印 上一主题 下一主题
[经验] A precision curvature-compensated CMOS bandgap reference
跳转到指定楼层
楼主
发表于 2022-9-27 11:16:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
A precision curvature-compensated switched-capacitor bandgap reference is described which employs a standard digital CMOS process
and achieves temperature stability significantly lower than has previously been reported for CMOS circuits. The theoretically achievable temperature coefficient approaches 10 ppm/ 0 C over the commercial temperature range utilizing a straightforward room temperature trim procedure. Experimental data from monolithic prototype samples are presented which are consistent with theoretical predictions. The experimental prototype circuit occupies 3500 milsz and dissipates 12 mWwith+5 Vpowersupplies,The proposedreferenceis helieved to be suited for use in monolithic data acquisition systems with resolutions of 10 to 12 bits
A precision curvature-compensated CMOS bandgap reference.pdf
1.41 MB, 下载次数: 0
举报
站长推荐上一条 3/5 下一条
【预约|参会享"豪"礼】2025慕尼黑上海设备展
查看 »
GMT+8, 2025-4-30 07:56 , Processed in 0.112529 second(s), 18 queries , MemCache On.
