查看: 590|回复: 0
打印 上一主题 下一主题
[经验] A Method to Effectively Decrease the Settling Time of Gain-Boost OTA
跳转到指定楼层
楼主
发表于 2022-9-7 20:35:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
A method was proposed to decrease the settling time of gain-boost folded cascode operational trans-conductance amplifier(OTA). Through the small-signal analysis of gain-boost OTA, the expression of pole and zero was attained successfully; then the effect of pole-zero (doublet) on settling time was revealed fully. To reduce its effect, a method was finally proposed that the unity-gain frequency (ow) of regulation amplifier should be a little larger than the unity-gain frequency (ou) of core amplifier. This method was proven to be effective by simulation result.
A Method to Effectively Decrease the Settling Time of Gain-Boost OTA.pdf
391.42 KB, 下载次数: 0
举报
站长推荐上一条 1/5 下一条
有奖活动|英飞凌智能座舱直播活动
查看 »
GMT+8, 2025-4-30 07:56 , Processed in 0.111592 second(s), 18 queries , MemCache On.
