查看: 417|回复: 0
打印 上一主题 下一主题
[经验] LDO new compensation
跳转到指定楼层
楼主
发表于 2022-9-1 21:30:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Abstract- A novel scheme is presented for achieving high performance low-dropout (LDO) voltage regulators under the constraint of low supply voltage. This scheme makes use of a frequency-dependent feedback factor (FDFF). The FDFF has simple circuit structure and frequency-dependent gain. When it is used in the proposed LDO, the low voltage operation ability, wide-band high power–supply rejection (PSR) characteristic and excellent transient response performance can be obtained. Simulation results show that this LDO can work properly at 1.2-V supply voltage, and the overshoot is only 1mV, while the PSR is better than -40dB from dc to 100-MHz. Therefore, the FDFF based LDO is well suited for low-voltage ripple-sensitive applications.
Design of High-Performance Voltage Regulators Based on Frequency-Dependent Feedback.pdf
1.62 MB, 下载次数: 1
举报
站长推荐上一条 1/4 下一条
有奖活动|英飞凌智能座舱直播活动
查看 »
GMT+8, 2025-4-15 16:17 , Processed in 0.107095 second(s), 18 queries , MemCache On.
